11-19-2012, 12:40 PM
#1 |
SRG
Oddometer: 894
Heat Shield Clamp
I'm looking for hose clamps w/ an attachment point/nut to use holding on a self made heat shield. Something like the ones shown here:
http://www.motorcycle-superstore.com...at-Shield.aspx All I want is the clamps - anyone got a source?
Lazy Traveler |
11-19-2012, 01:13 PM
#2 |
Pushin forward back
Oddometer: 2,825
Adjustable band brackets...cant find anything to fit smaller the 4" posts though.
Reality is merely an illusion, albeit a very persistent one. |
11-19-2012, 05:15 PM
#3 |
SRG
Oddometer: 894
Some more searching and I found Flatland Racing sells these:
http://www.flatlandracing.com/Mercha...Code=Universal
Lazy Traveler |
11-21-2012, 02:40 AM
#4 |
Oddometer: 159
Use these type of nuts with a standard large hose clamp that can wrap around the exhaust can.
http://www.dormanproducts.com/catalo...ec20_Part5.pdf Go to the 8th line down and you can see what I'm talking about, you can get them at Lowes or HD in the hardware dept, You can slide the tab of the nut under the hose clamp to hold it then you can make your own heat shield up and mount it with matching sized bolts or screws. Length of bolt or screw is critical. Ron W.
DRZ 400SM DL-650 Gone but not forgotten |
