Old 11-20-2012, 07:24 AM   #16
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,551
Remove the tank and remove the fittings. Fill the tank with hot water and Super Clean, a very strong alkaline industrial cleaner. Wear gloves to protect your skin, Super Clean loves protein and will dry your skin uncomfortably. Agitate the tank.
Repeat as needed.
Super Clean is available at Wal-Mart and auto-parts stores. It is water soluable and will leave your tank very clean. I would follow with fresh fuel and a bit of Techron.
While you're at it, the remaining Super Clean will remove grease and oil from your driveway.
def is offline   Reply With Quote
Old 11-20-2012, 03:47 PM   #17
MathewC OP
All adders are puffs
MathewC's Avatar
Oddometer: 424
Lots of good suggestions. I think I'll call a few radiator shops and see what they can do. If not that, then I'll go the hot water and mild soap route, followed by gas.
I don't want to put anything but liquid in the tank, and I don't want to strip it's coating.
Thanks for the advice guys.
No, I don't need help with my tent.
MathewC is offline   Reply With Quote
Old 11-20-2012, 07:07 PM   #18
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,329
Have you tried taking a pressure washer wand to it?
If it is flaking off, get some flakes out of it and just see what dissolves them easily. As mentioned it might just be gasoline.
GreaseMonkey is offline   Reply With Quote
Old 11-20-2012, 08:12 PM   #19
MathewC OP
MathewC's Avatar
Oddometer: 424
Another great idea. Thanks.
Old 11-23-2012, 04:59 AM   #20
kraven
Hegelian Scum
kraven's Avatar
Oddometer: 4,912
Radiator shop, vinegar, or trisodium phosphate. You can buy TSP at any hardware stores. It's the detergent additive that they removed from laundry detergent, but in the 70's it really got whites white. It does great on any kind of petrol based stuff.
I used it on the tank of a 54 Ford that had been sitting for a dozen years.
Wish I'd thought of a radiator shop. Time:money is right with the rad shop, but if you're a DIY guy, it's hard to beat vinegar (for rust and scale) or TSP for petroleum based removal.
So there I was walking into a biker bar in Chattanooga with liberty spikes on my head and a drag queen beside me... - bcurvin
kraven is offline   Reply With Quote
Old 11-23-2012, 04:51 PM   #21
Green427
Comfortably Dumb
Green427's Avatar
Oddometer: 1,090
Interesting. I have a '38 Chevy that has been sitting for the same amount of time. Mechanic took the original gas tank off and cleaned it out, not sure how...my Dad thinks he boiled it. Sad thing is, after the engine was restored, fuel line and tank were cleaned, my Dad left it that way again. I don't know how much fuel is in it now, and I will be doing a lot of cleaning.
2011 DL650A
Green427 is offline   Reply With Quote
Old 11-23-2012, 06:52 PM   #22
darkstarmoto
Am I evil? Yes I am
darkstarmoto's Avatar
Oddometer: 403
Pull the tank and slosh some kerosene in there for a bit. Drain and repeat...it works.
05 KTM 950ADV - 08 KTM 690 SMR - 07 Ducati MTS1100S - Redneck Engineering Mutant
darkstarmoto is offline   Reply With Quote
Old 11-24-2012, 08:56 AM   #23
El Duque
El Duque's Avatar
Oddometer: 123
i hear is is safe and effective...cleaner and rust remover
http://www.harborfreight.com/1-gallo...ver-96431.html
it is what it is
El Duque is offline   Reply With Quote
Old 11-25-2012, 03:22 AM   #24
AndyGilbert
AndyGilbert's Avatar
Oddometer: 32
I looked through and saw a lot of good ideas. I do caution about vinegar though: if left in the tank it can cause rust. We use it at work to take care of baking soda left after the blast cabinet and when it gets on steel it rusts badly and much quicker than water.
It looks like your sludge should come out nicely with hot water/detergent but if it doesn't, don't sweat. Resealing the tank is pretty easy with this stuff: http://www.eastwood.com/ew-gas-tank-...or-cycles.html
I have used it on a friends MC tank and it worked awesome. When we did the job, the instructions called for muriatic acid to clean the tank in prep for the new sealant. THAT, is wicked stuff but works well.
AndyGilbert is offline   Reply With Quote
Old 11-25-2012, 10:30 AM   #25
showkey
Oddometer: 1,972
Originally Posted by CycleDoc59 View Post
Not good; acetone is extremely flammable, pricey, melts brain cells... Any detergent will
remove old gasoline sludge.
Any detergent.......not likely..........if it was that easy we would not be here..........
Disagree...........get the facts straight.........flammable yes.....but not any more than gas.........melting brain cells guess that why it is the main solvent in nail polish remover.
Acetone is used as a paint thiner and solvent very common.
http://en.wikipedia.org/wiki/Acetone
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 11-25-2012, 11:13 AM   #26
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 981
I see no point in using acetone, or similar, to clean petrol residue from tanks. Having cleaned/sealed over 200 tanks
(one yesterday..) the only time acetone or some other solvent is needed, is when the tank has
already been sealed, and the coating failed... I use a cheap detergent that is suggested for pressure washing,
($7 a gallon), usually with 8 oz to a gallon of water. If the gunk in the tank is thick, I drop in a 300
watt immersion heater. Give it a shake from time to time, let it sit a few hours, rinse and it's clean...
CycleDoc59 is offline   Reply With Quote
Times are GMT -7.   It's 02:40 AM.
