Old 11-19-2012, 06:40 PM   #1
nick2ny OP
nick2ny's Avatar
Oddometer: 545
Did I screw up these Honda C70 fork bushings?
Howdy--I'm nearly done refreshing the fork on my C70. I got a kit from DRATV kit, removed all the old parts, and put in the new parts. I pressed in the outer bushings and now the inner ones don't fit (I used a press, and they went straight in with a little force. It felt fine).
They would probably go in with pressure, but then the suspension wouldn't work very well.
Was I supposed to use heat on the suspension arms and get the interference fit to work with heat? I can't imagine I damaged them with the press, they went in really easily. The inner pieces also fit easily before I pressed the outer pieces in. Ugh.
The bike!
The suspension arms, still on the bike
That stupid press that I thought I was so lucky to find.
The old, worn bushings.
Success! (or so I thought)
It looks so easy. Look how loose the tolerances are.
The mess I'm in now.
speed limit zero
nick2ny is offline   Reply With Quote
Old 11-20-2012, 06:37 AM   #2
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 944
I expect the fit of the inner bushing within the outer is very close, so
as to not have play or looseness. You say the two fit together ok before
installation of the outer bushing..? Then perhaps the pressing procedure
upset the edge of the outer bushing a bit. It would take very little to do so.
So, look carefully at the outer bushing edges(s), and remove any imperfections....
CycleDoc59 is offline   Reply With Quote
Old 11-20-2012, 07:15 AM   #3
nick2ny OP
nick2ny's Avatar
Oddometer: 545
Thanks for the reply. Pressing didn't mess up the edges though. The rims of the outer bushings have a ~0.5mm chamfer, and it isn't deformed or damaged or nicked all the way around, either on the inside or outside edge of the chamfer.
It's like the outer bushings are either squished in 0.001", or are slightly ovalized.
Woe!
speed limit zero
Old 11-21-2012, 08:40 PM   #4
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,288
If you are looking for a simple and cheap fix, just use a round file and lightly remove enough of the inside that you get your clearance. As long as you use your brain and your eyes you'll do fine.
Or else you can buy an adjustable reamer to get your clearance:
http://www1.mscdirect.com/eCommerce/...mers/_/N-77ha8
GreaseMonkey is offline   Reply With Quote
Old 11-22-2012, 05:28 PM   #5
ttpete
Rectum Non Bustibus
Oddometer: 5,753
Better yet, go to an automotive machine shop and have them hone the bushings on their Sunnen honing machine. Bring a pin so they can check the fit. It should only take a few minutes.
15 BMW RnineT
09 Kaw Versys
Old 11-22-2012, 05:38 PM   #6
ragtoplvr
Oddometer: 6,055
brake hone. They only cost a few dollars.
Rod
ragtoplvr is offline   Reply With Quote
Times are GMT -7.   It's 08:06 AM.
