Old 11-29-2010, 03:30 PM   #1
fiep OP
fiep's Avatar
Oddometer: 1,914
cam chain tentioner XR250L
help
how do I release tention in the cam chain tentioner of a 94 XR250L?
I remotely do remember something about pliers and a piece of wire
thanks
fiep
fiep is offline   Reply With Quote
Old 11-29-2010, 08:51 PM   #2
leadthrower21
Oddometer: 38
This is from an XL250R service manual, it should be the same, and sounds like what you're describing. *shrug*
I just did this on my own bike, and I ended up shoving a flat screwdriver down between the chain and tensioner to get the dealie up far enough to get it with a pair of vise grips. YMMV
leadthrower21 is offline   Reply With Quote
Old 11-30-2010, 03:19 AM   #3
fiep OP
fiep's Avatar
Oddometer: 1,914
thanks, ran into this description before
ony
there is no pinhole in my tentioner
I think the XR650L does have the same mechanism
Old 11-30-2010, 05:55 AM   #4
mcma111
mcma111's Avatar
Oddometer: 12,434
Nope
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-01-2010, 06:55 AM   #5
sporthog93
Sporthog93
sporthog93's Avatar
Oddometer: 805
I use a small pair of needle nose vise grips to grip the piece that comes up when the wedge is realeased.
Are we gonna ride or just dick around all day?
sporthog93 is offline   Reply With Quote
Old 12-01-2010, 01:26 PM   #6
leadthrower21
Oddometer: 38
You have to pull it up really far to see it on mine, let alone get anything through it.
Parts fiche says they're the same part: http://www.cheapcycleparts.com/produ...oner-cam-chain
Old 12-01-2010, 06:49 PM   #7
creaky
creaky's Avatar
Oddometer: 186
The 250L tensioner is the same as the 250R. You have to push down on the front wedge to release tension on the rear wedge. While you are pushing the front one, grab the rear one with vise grips and pull up until you see the hole in the wedge and slip a cotter pin or a HD paper clip into the hole. If the chain is extremely worn, it can be difficult to get hold of the rear wedge because it will be deep into the tensioner body. It makes things easier if you remove the tensioner set plate first. If you continue to have difficulty, PM me and I'll go into detail.
'98 BMW F650
'96 XR400
'98 Moto Guzzi V11
"Once you go over the hill, you start picking up speed!"
creaky is offline   Reply With Quote
Old 12-02-2010, 03:18 AM   #8
fiep OP
fiep's Avatar
Oddometer: 1,914
thanks for the offer, Creaky
a Michelin tire iron, a large screw driver and a set of vice grips later the cam is installed
but:
no hole
no matter how far I pull
had to keep the tentioner 'relaxed' with the vice grips
Old 11-20-2012, 12:30 PM   #9
foofer0013
foofer0013's Avatar
Oddometer: 2
93' XR250L Engine Rebuild...
Hello everyone and thanks for the feedback... I too, am having similar problems with this cam chain tentioner. No hole is present. How exactly did you position the Vice-grips?? Thanks in advance! ~Dave
foofer0013 is offline   Reply With Quote
Times are GMT -7.   It's 01:14 AM.
