Old 11-21-2012, 06:33 AM   #1
Jeff B OP
Socially Awkward
Jeff B's Avatar
Oddometer: 5,655
Aerostitch Roadcrafter
Anyone here have experience w/the 2pc Roadcrafter?
My "try" suit arrived from Stitch yesterday and I'm having a hell of a time getting the pants to jacket zipper started. When I'm lucky enough to get it engaged, it is awfully difficult to zip around. [I put some silicone on it and this helped some]
The pants are prolly a size to big and I'm thinking this is part of the problem. The pants zipper is a longer and bunched up path than the jacket zipper.
I really like the basic construction of this suit and want it to work, but unless I can resolve this issue I'll have to try another plan.
My old suit is a Revit Dakar and it took about a 5 minute learning curve to master zipping the top to the bottom.
Jeff B is offline   Reply With Quote
Old 11-21-2012, 07:11 AM   #2
StuartV
Motorcyclist
StuartV's Avatar
Oddometer: 1,396
I had a 2 pc RC for years. What you described sounds normal. It should get easier over time. Also, if you are zipping it together before you put it on, that may be part of the problem, too. Try putting on the jacket and pants and then zipping them together.
Personally, I finally got too tired of the fit and got a 1 pc RC instead. I like that much better. But then I got tired of how hot the Roadcrafters are and got a 2 pc Motoport mesh Kevlar suit and now that's all I wear until it gets down to around freezing or colder.
- Stu
'09 R12GS, '05 GSX-R1000
Iron Butt # 4999, WERA/CCS EX # 666 (currently, expired), AMA Life Member
Racer, Drummer, Bassist, Software Engineer
StuartV is offline   Reply With Quote
Old 11-21-2012, 07:38 AM   #3
Jeff B OP
Socially Awkward
Jeff B's Avatar
Oddometer: 5,655
Thank you for your response.
My intention was for this to be my cold weather suit. I figured that a 1pc would be easier to get in and out of, but I don't wear jeans underneath, only fleece or polyprop underware. So going into restaurants and such I thought the 2pc would be more convenient, cause I'd just leave the pants on.
When stopped at a destination I know I can fit the top in one pannier, the bottoms in the other. I don't think a 1pc w/ the big pads would fit in one of my Givis'.
Yes, I've have both jackets and pants on when trying to zip them together. I'm sure my belly does not help matters either.
Old 11-21-2012, 07:44 AM   #4
V-Tom
Oddometer: 778
I use a two piece and am very happy with it.
IIRC there are a couple of "belts" that secure with velcro on the sides of the jacket or pants to tighten it up. I suspect these are snugged up right now and that may be why the zippers appear to be different lengths.
As far as putting it in cases: my two piece can fit inside of a GIVI E41 sidecase when it has all thev normal pads and that back pad. You don't need to take it apart, just make sure the elbo and knee pads are spooned together when folding.
I alway wear something under my Roadcrafter. It goes off in seconds so this is very convenient. If you are going to keep the pants on when stopped you should probably look at getting the suspenders.
..Toim
2006 DL650 V-Strom * 202,000 km 125,500 miles 2012 DL650 115,000+ km, 72,000+ miles
If you really give a damn about safety read the following links:
Why Cars don't see bikes (SMIDSY)
SMIDSY detailed report
V-Tom is offline   Reply With Quote
Old 11-21-2012, 07:45 AM   #5
cluster148
Oddometer: 61
2Piece Aero
3,possibly 400,000 miles on 2 piece Aerostitches.Never zip them together.Always had the zip on "suspender" option.Works great for me.
Allows to take off coat without taking off pants.But you get lots of questions when you go into restaurants" How's the fishing?"
Clark
cluster148 is offline   Reply With Quote
Old 11-21-2012, 08:37 AM   #6
xrcris
Oddometer: 222
Pissed
This topic must be fate - my balls are soaked (again) after my commute to work and I was thinking of starting my own thread just to vent....
I don't have a full two piece, just the pants w/ bib - honestly for the $$ they suck. The zippers leak like a fucking sieve and the velcro sucks. The zipper pull actually fell off both leg zippers too. They are around 4 years old.
I reallllly want to like Aerostich (since they're an American co.), but the Joe Rocket pants I had before were better. For comparison, I've got a Teknic jacket that I've been wearing every day for the past six years that has held up better.
I don't ride, I commute.....
'94 XR-L
'99 VFR
'03 V-Strom
xrcris is offline   Reply With Quote
Old 11-21-2012, 08:46 AM   #7
ph0rk
Doesn't Care
ph0rk's Avatar
Oddometer: 2,059
Are you the first owner of the pants? Most of the "two piece leaks less" stories are referencing the whole two-piece, so if you have a different jacket that lets water hit at a different place on the pants... well there you are.
FWIW, I have a one-piece with the RiRi zips and I haven't had a leak other than at the pit vents (which were wide open in a downpour, duh).
I've also never had a leak with my AD1 pants, either.
Frankly I'd like to swap my 1pc for a 2pc, but thats more about vanity than anything else (yes yes, vanity and aerostich don't mix, but oh well).
--Semantics are everything.
ph0rk is offline   Reply With Quote
Old 11-21-2012, 09:13 AM   #8
xrcris
Oddometer: 222
First owner - "if you have a different jacket that lets water hit at a different place on the pants... well there you are." is just fucking bullshit. The zippers suck. They broke and they leak. If you never ride in the rain, the pants are great, but when I'm ready to replace these, which will be sooner rather than later based on what's falling apart, it will be with something other than Aerostich.
'94 XR-L
'99 VFR
'03 V-Strom
Old 11-21-2012, 09:26 AM   #9
V-Tom
Oddometer: 778
It's odd how many people have very different experiences.
My Two Piece is three years old and has about 110,000 miles on. I commute in almost every possible weather condition including heavy rain plus do road trips and the zippers have never leaked. (did about 40,000 miels last year.) If water gets in it generally is at the neck if I haven't snugged things in.
I have had a couple of pulls break but a split ring in them took care of it until I could get new zipper pulls.
On the other hand my Joe Rocket pants barely lasted the first season (two zippers broke.) My Tecnik Jacket is okay but showed heavy wear after the first year and generaly was never as comfy in warm weather as my Roadcrafter.
..Tom
Old 11-21-2012, 09:45 AM   #10
xrcris
Oddometer: 222
..Tom
yeah, I wonder how much it depends on what you're riding? IE some bikes have better/different weather protection? The reason I bought the Roadcrafter pants was because the stiching holding the zipper to the Joe Rocket pants split after two years of use - obviously not a stunning endorsement of their quality, but they never leaked and for a $100, I'm not complaining. But the JR pants had the zipper on the outside of each leg so whatever waterproofing material was used, was unbroken through the crotch. This is vs. the zipper that starts in the crotch on the RC - on my VFR the water hits my jacket then runs down and leaks in the crotch. FWIW, my Teknic jacket has never ever leaked a drop, it is entirely waterproof, there is a flap secured with velcro that totally covers the front zipper. It's on it's last legs, general wear on the inside liner, the adjusting straps tore, and the some of the stiching on the velcro is gone, but no one part failed to the point where it had to be replaced. I'm pretty happy with the time & performance I've gotten out of it.
'94 XR-L
'99 VFR
'03 V-Strom
Old 11-21-2012, 09:50 AM   #11
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 11,469
my two piece stich is still going strong after 15 years . . . . . the zipper between the jacket and pants was a lil tough to begin with, but eased with use . . . . the fact that the pants and jacket are the same size might have something to do with that.
if the zippers are trashed on your pants, get em fixed, would be miy advice. then, try and figure out why they failed in the first place . . .every company makes errors, but it's how they stand up after that separates the good from the rest.
Full disclosure, after sealing the seams and zipeprs per Aero's instructions, I can ride through 6 hour frog stranglers dry . . . .
YMMV, of course.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 11-21-2012, 10:03 AM   #12
sportbiker929
sportbiker929's Avatar
Oddometer: 166
spraying silicone on the zippers helps immensely!
96 R1100GS, Ohlins shocks, V-Stream STD, Pro Tapers (Pastrana F/S bend), Trackside Grip Heaters, Cycra Pro bends, Pivot Pegs, Leo Vince, Michelin Road 3 trails.
95 XR650L, Mikuni Pumper, Yosh, Baja Designs race Light, Pro tapers, Cycra Pro Bends, Magura 1/4 turn, Pirelli MT90s.
sportbiker929 is offline   Reply With Quote
Old 11-21-2012, 12:50 PM   #13
ph0rk
Doesn't Care
ph0rk's Avatar
Oddometer: 2,059
If you bought roadcrafter pants to wear as standalone riding pants on purpose, you made a mistake - the AD1s and Darien pants would have been better. The whole point of the RC (1 or 2pc) is fast in/out, hence the inner-thigh zip. That said, my 1pc hasn't ever leaked in the southern frog-stranglers we get down here, either on a bike with good wind protection or on a naked bike (other than when I have left the pit zips open). It does have the new zips, however.
I've had a number of their products in my hands, and they don't seem to be in the habit of shipping crappy products. I wish I could say the same about other manufacturers. Compared to the zippers on olympia or rev'it gear, the stuff on my RC is very robust. So far, my RC is the only piece of gear that hasn't had a "WP" zipper leak - that isn't to say one won't leak eventually, but if you absolutely must have waterproof, a zipper is a pretty stupid thing to have. With enough water and pressure, a zipper will leak. Zippers are convenient, though, so it is an acceptable risk.
Aerostich does repair zippers. If you can convince them they failed because of a defect I'm sure they'd take care of you. You can even send them pictures before shipping the pants themselves.
Old 11-21-2012, 01:09 PM   #14
xrcris
Oddometer: 222
Not according to Aerostich:
"either part can be worn separately." http://www.aerostich.com/jackets-pan...ter-pants.html
The zippers haven't "failed", they just leak - they've always leaked. There's nothing to fix except the design. The pulls broke off both legs within two years, (the zipper on my Teknic jacket is still intact after even longer use) but they still "zip".
The OP asked how they work, glad you like yours and I'm not into a pissing match about whether they are good or not - but for me and my money they suck.
'94 XR-L
'99 VFR
'03 V-Strom
Old 11-21-2012, 01:17 PM   #15
squish
Out of the office.
Oddometer: 6,161
It sounds like xrchris feels like the roadcrafter should be waterproof something Aerostitch has never clamied it was.
Bummer he has had such a bad experience with it.
Following aerostichs advice in maintaining the suit helps a lot.
On vacation for a spell
squish is offline   Reply With Quote
Times are GMT -7.   It's 06:54 AM.
