Old 12-02-2012, 09:11 PM   #61
Seventy One
Seventy One's Avatar
Oddometer: 498
Well, I rode it, and I like it...a LOT!
Too bad the dealer is such a jerk...I introduced myself as the person who called about the Uly. I think he mumbled "hi". That was it. He never even got up from his desk.
Anyway, I love the motor! It pulls like a freight train and kind of sounds like one too. The seat height is great (I'm 5'11" with 32" inseam). The controls are identical to the DR650 (as is the brake dive) so I felt right at home.
I found the steering to be a tad heavy though. Not what I would have expected out of a rig with a 17" front wheel. Not an issue though.
The shifter was the real problem though. For whatever reason it seems like it was at least an inch too high. My foot was forced upward at a tight angle throughout the ride. It was actually sore after a few blocks. It's about like trying to drive a car with the seat shoved all the way forward. I kept trying to slide back in the seat to avoid this but couldn't due to stepped seat. There does seem to be some adjustment on the shift linkage though. Is this a common complaint? Oddly, the rear brake pedal never bothered me....either that or I rode the brake the whole time.
I wasn't able to purchase it due to a "software issue" connecting to the banks.
Fun, fun bike though! The sound of the fan was cool too!
One last question. How on earth do you guys lift these up for service? The under frame muffler/exhaust would interfere with my current jack.
"You are what you hate".~ Anonymous.
Seventy One is offline   Reply With Quote
Old 12-02-2012, 09:32 PM   #62
dave186
Oddometer: 185
You can adjust the shifter just loosen the jam nuts and twist the linkage. I have mine up quite a bit to fit my big foot under it, would like a shorter one. Lift the bike by the muffler, its made for it.
dave186 is online now   Reply With Quote
Old 12-02-2012, 09:47 PM   #63
yokesman
Oddometer: 514
i have a tuber but this works for any bike, while on the side stand place a jack stand under the opposite side foot peg boss slightly lifting the rear tire ,then at the stand side either place a jack under the peg boss or lift it again and slide another jack stand under it.sometimes the jack is neccessary as the service requires work directly at the rear and the jack can be moved somewhat to allow access. the muff it ok with it but I like to drop mine done a bit for better access to the trans plug.
yokesman is offline   Reply With Quote
Old 12-03-2012, 03:12 AM   #64
Hughlysses
Hughlysses's Avatar
Oddometer: 3,373
The Buell XB's are very sensitive to suspension setup; if it wasn't set up properly that might explain the heavy feeling steering. Just go by the recommended settings in the owner's manual and adjust for your weight. 99% of the time, that'll be spot-on, but you can fine-tune from there if necessary. And of course you never know if a dealer like that bothered to check the tire pressure so it could be something as simple as that.
+1 on the shifter adjustment. It shouldn't feel like that and it's easy to adjust.
As far as jacking up the bike, the stock muffler (or a modified one like a Drummer) will support the weight of the bike. If you look carefully, two jacking points are indicated. You can build a cradle out of 2x4's that'll allow you to support it with a standard motorcycle jack. Here's a template:
http://www.badweatherbikers.com/buel...adle-92346.pdf
Here's one version under an XB:
You can use 2x4's for the sides, all-thread like this guy did, or some people don't even bother with sides.
2007 Buell XB12X Ulysses
1983 Honda VT500FT Ascot
Hughlysses is offline   Reply With Quote
Old 12-03-2012, 03:12 AM   #65
Hog Rider
The Professor
Hog Rider's Avatar
Oddometer: 1,448
Jacking the Buell
Just move the center of gravity for working on the front wheel. I have a pit stand for my bike, But I use a jack most of the time for quick service work.
Hog Rider
IBA # 31325
AMA# 739943
Cobb
Etc..
http://carlstwowheeledadventures.blogspot.com
2006 Buell Ulysses, Current Rally Mount
1984 HD Electra Glide Classic
1977 BMW R 100/7 Cafe'
1982 Honda CBX Super Sport, Work in progress
Hog Rider is offline   Reply With Quote
Old 12-03-2012, 04:33 AM   #66
Murf2
Oddometer: 832
I'm betting on suspension adjustment & tire pressure for the heavy steering. When I first rode mine, it turned like a pig. Aired up the tires & what a difference!
Murf
Murf2 is offline   Reply With Quote
Old 12-03-2012, 05:06 PM   #67
dave186
Oddometer: 185
On the 06 models it helps a lot to change to the 07 fork springs. triple rate versus the single rates they came with. I just put them in mine, surprisingly cheap only $27 each at my local dealer. Really help with the brake dive. Once I got everything dialed in how I like it, I make on the fly adjustments with the rear preload adjuster, rear ride height really seems to affect the handling. I drop the rear a bit if im going to be on a loose gravel road for a while, makes it less squirrely. I think related to the steep fork angle?
Old 12-03-2012, 06:25 PM   #68
Seventy One
Oddometer: 498
Thanks to everyone for the great info!
Think I'm going on over to badweatherriders and do some more reading. If these machines are half as much fun to wrench on as my DR650, I think I'm gonna love the Uly. I have just as much tearing the DR apart as I do riding it.
The only other concern I have is whether or not I can handle buying a bike during the first week of December. I bought a mountain bike years ago (during November IIRC) and it sat there in my apartment, staring at me all winter. Nearlly drove me insane.
Old 12-03-2012, 07:39 PM   #69
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,491
71, you don't have to get too fancy jacking up the bike. I don't even own a motorcycle jack.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 12-06-2012, 04:48 AM   #70
joeschaar
Oddometer: 1
springs for nose dive
Dave, Do you happen to know the part number of the '07 fork springs you ordered. I'm a new Uly owner and so far the seat height and the nose dive are the only issues I have. I have the seat hieght under control and now I'm trying to get the nose dive under control.
Cheers,
Joe Schaar
joeschaar is offline   Reply With Quote
Old 12-06-2012, 06:46 AM   #71
dave186
Oddometer: 185
I will have to try and find the invoice. I just asked for fork springs for an 07, the part number is only different by one letter from the 06 I do remember that.
Old 12-06-2012, 07:01 AM   #72
Vertical C
Vertical C's Avatar
Oddometer: 2,798
I hate these threads.
Mine fell apart.....and I still miss it and want another,
Vertical C is online now   Reply With Quote
Old 12-06-2012, 07:03 AM   #73
red450
WEE-A-BOO
red450's Avatar
Oddometer: 312
Do any of you know if an ECM from an 2007 XB12R will work in my 2006 Ulysses?
Mine is shot and I need to replace it but I don't have the cash for an EBR plus, I've heard mixed reviews on them w/06 bikes.
red450 is offline   Reply With Quote
Old 12-06-2012, 07:18 AM   #74
RealOldDualSportGuy
RealOldDualSportGuy's Avatar
Oddometer: 485
Verticle C
Gday Mate
We have just the ride for you.
Unfortunately it is in the US.
Regards
Be safe
I wont be wronged, I wont be insulted, and I wont be laid a hand on. I dont do these things to other people, and I require the same from them. John Wayne -- The Shootist (1976)
RealOldDualSportGuy is offline   Reply With Quote
Old 12-12-2012, 01:36 PM   #75
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,321
Anyone care to compare an '06 XB12ss with the Uly? Leaving out the obvious lack of luggage, I'm interested in the street ride position and handling.
I've recently become enamored with the Uly, but during research I've noticed more problems with the earlier "06 models.
My question is, do the other Buell models, specifically an XB12SS, of the same vintage suffer similar problems? A low mileage one is available locally, but will I be looking at ECM upgrades, bearing problems, fan failure etc? I realize this is not setup as a tourer, but it will be more of a local rider, with some runs to the GA mountains for fun.
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Times are GMT -7.   It's 06:41 AM.
