Old 12-25-2012, 01:48 PM   #121
kag
Wander Lust
kag's Avatar
Oddometer: 1,719
Originally Posted by stoney4vida View Post
I put barkbusters with end weights on my Uly and it helped quite a bit. I also have a throttle rocker so I can relax my grip a little. What did you fill handlebars with ? I have a few old HD's in the garage myself. I have a 52 flathead, 65 pan and 80 shovel. Love riding the old bikes. They have a soul
Filled the bars with silicone caulk through the hole near each grip. I put tape over the other holes on the bars so it would not leak out. Removed after the silicone cured over night. I used about 3/4 of a tube.
kag is offline   Reply With Quote
Old 12-25-2012, 07:56 PM   #122
stoney4vida
Semper Fidelis
stoney4vida's Avatar
Oddometer: 2,168
Did this make noticeable difference ?
stoney4vida is offline   Reply With Quote
Old 12-30-2012, 02:22 PM   #123
stoney4vida
Semper Fidelis
Oddometer: 2,168
I got my hands on a Spec Ops muffler. Can I run this with stock ECM, or will I need to go to EBR for the race ECM loaded for the Spec Ops muffler ? If it's possible to run with stock ECM are there any negatives to doing it ?
I also run the K&N air filter
Old 12-31-2012, 11:33 AM   #124
frontiercat
all out of charm
frontiercat's Avatar
Oddometer: 1,341
In my opinion, get the ECM from EBR with the correct algorithms in it. You will be much happier.
Yes, the negatives are possible engine (piston) failure due to excessive lean conditions.
frontiercat is offline   Reply With Quote
Old 01-01-2013, 02:27 PM   #125
stoney4vida
Semper Fidelis
Oddometer: 2,168
Thanks for info folks
Old 01-01-2013, 05:27 PM   #126
Bigmuddy
Oddometer: 1
Started on the 01 DRZs for kicks on country roads in 04'. Was hooked and started searching for a street alternative. Bought the 06 XB12X new, without the benefit of a test ride or even seeing one. Had to wait for it to arrive in at the local HD store. Fear of the power and the potential downsides were soon overcome with relative confidence and certainly comfort. Over 40k on the clock now and cannot yet imagine parting with it. Just picked up an 07 F650GS to for more distance on dirt and to take pressure off the Buell.
What started out as a pastime has evolved into an everyday thing. This, that or the next bike and all that goes with them. Even have an 08 CBR1000rr that my son calls his. Fantastic contrast to anything I have ridden. Of all these currently in service the Buell easily covers the broadest range of uses. Have had a lot of peg time on it too. Very manageable. Big, big fun.
Bigmuddy is offline   Reply With Quote
Old 01-02-2013, 12:45 PM   #127
unlucky1
unlucky1's Avatar
Oddometer: 261
Checkin' in - last weekend I got the Uly out on the road for the first time since November. Since then I've bought a "fast" Mustang as my daily driver and have been putting saddle time on my DT175 at the local ORV park... I'd forgotten much thrust the Uly makes right from the bottom and how effortless it is to toss around.
So much fun, but don't try to launch it like a DT :)
This photo is sort of a joke I couldn't resist:
Just shy of 48,000 miles now, but most aren't mine; it came with 37,000mi last February. Fixed the fuel pump wiring before Sturgis last summer and it was pretty easy, looks like fuel filters that fit can be had at Autozone; good to know. I think that's the last factory issue on it, the rest will likely be old bike issues. The Sturgis run toasted the battery pretty well, it hasn't been able to hold as deep a charge since that trip. No surprise with how hot it gets under the seat though.
This winter I'm going to take off the header and have the front pipe bunged for a wideband O2 sensor and fix the fueling on a dyno; a PO disabled closed loop learn and tuned it at sea level so it has about a 7000ft ceiling. I know because I completely bogged out and lost all power, blowing soot, while riding over the top of King's Hill Pass in Montana at about 7300ft and woke back up just below the pass. At least I can be pretty confident it isn't running lean!
I'd buy another one but maybe by then the AX will be a thing :)
2008 XB12X
unlucky1 is offline   Reply With Quote
Old 01-12-2013, 09:33 AM   #128
HooliKen OP
Awesome is a flavor
HooliKen's Avatar
Oddometer: 2,995
Buell Bliss Part Deux
When I picked up my second 06 Uly I basically road out, met dude, rode it home, then headed to VA for 46 days of 14 hour shifts during an outage. After riding it for awhile I got the sense that it was way, way underpowered compared to my first one. My original 06 would power wheelie in 2nd and sometimes in 3rd. Well finally got through the holidays and now have been able to tear into her a little. PO supplied me with a bunch of extra parts and a pretty thorough maintenance history.
First thing that had to go was the factory exhaust. Mrs. Hooliken said it sounds like George Jetsons car................not good.
Still had the factory take off from my first 06 and stumbled across Hawk Performance. Randy did his thing and it is currently at Classic coatings getting cermanic coated.
PO said that the idle adjust cable needed replacement and had a new one. Once I got the airbox base off all I had to do was shot it with some 3-36 lubricant and she turns slick as you please.
Going to reroute a bunch of stuff that he OO did just because my OCD will not be able to leave it like it is.
Finally got around to pulling the plugs and it was not pretty.....
I do believe that these were well past needing to be changed. I noticed the corrosion on the front plug when I got it but did not think it was this bad.
Annnnnd I think she has been running a touch lean wouldn't you say?
Guess once I get the exhaust back it will be time to do some tuning. Still have my old maps from my orgininal 06 and some other race maps that I saved.
And unfortunately the VDSTS cable I have will not function with ECMspy or Tunerpro so went ahead and ordered a new cable from xoptiinside. If anyone with a Buell in my neck of the woods wants to play with some data logging and tuning let me know.
Good Times!
"People in this country sleep peaceably in their beds at night because rough men stand ready to do violence on their behalf." George Orwell
950R Super Enduro - 450EXC - Gas Gas TXT 280 - 2000 Honda XR100R - 1988 Honda Z50R
HooliKen is offline   Reply With Quote
Old 01-13-2013, 07:09 AM   #129
armstrong473
armstrong473's Avatar
Oddometer: 74
PO should have changed those plugs out before dropping off the bike....
*hangs head in shame and slinks out of post*
armstrong473 is online now   Reply With Quote
Old 01-15-2013, 01:50 PM   #130
jonathan.vtec
Oddometer: 53
hello boys anything of u have never try this belt?
http://www.ebay.de/itm/ws/eBayISAPI....:X:RTQ:DE:1123
jonathan.vtec is offline   Reply With Quote
Old 01-16-2013, 06:57 AM   #131
GS750T
GS750T
GS750T's Avatar
Oddometer: 370
37,000 miles and the Uly is still my go to scooter. This is the only bike I have ever owned and not had to upgrade the suspension.
"In God We Trust" If you don't like this quote, go F%$K yourself!
11 FLHPT
06 Ulysses
07 klx 250
GS750T is offline   Reply With Quote
Old 01-17-2013, 10:20 AM   #132
HooliKen OP
Awesome is a flavor
HooliKen's Avatar
Oddometer: 2,995
Notice I was a gentleman and did not name drop....cough, cough!
Old 01-18-2013, 07:20 AM   #133
trapperj
Oddometer: 501
Ulysses..2010..0r earlier ?
Ok so I have been on the hunt for a '08 up ulysses. Found a few and let a couple get away. May have stumbled upon a couple of 2010s..that a dealer has new on their floor. While they were being discounted pretty good for awhile a year or two ago...now it seems they want a premium price.
So...would I be foolish to pay for a new 2010..I really want a Ulysses. Wouldn't mind a '08 or '09 and it sure seems they trade for a lot less coin. Other question I have is warranty..or lack there of...on a 2010 Buell. I'll have to travel a few hours away to this dealer...I wouldn't think just any HD dealer would want to work on the Buell. I wouldn't want them to either unless I had a major problem.
Thoughts?? I have wanted a Buell for awhile. If I wait much longer it may be too late. I understand you always loose some $...more even when you buy new. Being so few available they can stick to their price. I hate throwing money away.
trapperj is offline   Reply With Quote
Old 01-18-2013, 07:39 AM   #134
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,135
And their price is....
Old 01-18-2013, 07:53 AM   #135
trapperj
Oddometer: 501
Uly
I haven't got that far yet...I am sorta afraid to ask..lol I would think it's near ratail. I found a 2010 used with 4700 miles at another dealer and Thay want $9295 and didn't seem to want to budge at all. if I go to the dealer I reckon I'd end up bringing one home. I just don't want to make a huge $$ mistake. Although I'll likely keep her awhile and get a lot of enjoyment from her....so maybe I should just bite the bullet and bring one home..
Anyway...you asked about the price...I really don't know...but I am going to find out and report back?
Times are GMT -7.   It's 11:20 AM.
