Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 11-25-2012, 07:15 AM   #1
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,171
Changing the icon for a batch of custom POIs?
Having uploaded a set of custom POIs of moto dealer sof a certain brand to a Montana and a Zumo, I realize that I would like to use a custom icon for those places. Is there an easy way to do this as a batch instead of one at a time?
Old 11-25-2012, 08:18 AM   #2
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,874
Well, the easy way would be to create your Custom Icon and place it in the same folder as your POI file (GPX, CSV). You must name the Custom Icon the same name as your POI file. For example; BMW Dealers.GPX = BMW Dealers.BMP.
When you use the POILoader to create the GPI file and load it to the GPS, POILoader will look for a any BMP files of the same name as the POI data and assign the icon to ALL of the POI's within that file (BMW Dealers.GPX).
Your Custom Icon must meet Garmin's Custom Symbol requirements.
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 11-25-2012, 09:27 AM   #3
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,171
Cheers,
Ah! Thanks!
Old 11-25-2012, 01:16 PM   #4
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,171
In case this helps anyone else, on both the Montana and the Zumo 350LM, the file on the GPS unit holding your custom POIs is called "Custom POI.gpi". If you havve no custom POIs, this file will not be present. It is created when you upload custom POIs.
  • On the 350LM it is in a folder called "POI" under "Internal Storage", so /Internal Storage/POI/.
  • On the Montana, the file is also called "Custom POI.gpi" but it is in a folder called "POI" under a folder called "Garmin", so /Garmin/POI/.
The filename that you need to match in order for your custom POI icon to be displayed on screen is the filename of the file that your custom POIs were uploaded from. For example, I had a file named "BMW Motorrad USA Retailers.csv", so my image file for the icon had to be named "BMW Motorrad USA Retailers.bmp" in order to be recognized as DRTBYK instructed.
Key point: Assuming the use of the Garmin poi uploader tool, set to "express" (not "manual") you must copy your image file into the POI folder before uploading the POIs themselves. The uploading tool will take care of making the image to POI association, but if you upload your POIs before the image file is present in the POI folder, the image file will be ignored. There might be a way around that, but just stick the image file up into the POI folder first, then upload your POIs.
Emoto screwed with this post 11-25-2012 at 01:23 PM
Old 12-05-2012, 10:40 AM   #5
1200gsceej
1200gsceej's Avatar
Oddometer: 1,259
Question icon specs?
{snip}
Cheers,
Do you have a reference link to those specs?
Also, do the comments relating to the Montana and the 350 also apply to the Zumo 660/665?
thanks,
-ceej
My bike: Yellow '05 1200GS - on the Spotwalla ADV location page as CJ3.
My solo trips: 2014 Natl Park triangle, SF-Colorado-SF 2011 and 2013, SF-LA loop, Pinnacles and Carmel Valley loop
With Ol'Badger: http://www.2guysonbikes.com
And remember: Beauty is in the behind of the holder.
1200gsceej is offline   Reply With Quote
Old 12-06-2012, 07:26 AM   #6
DRTBYK
DRTBYK's Avatar
Oddometer: 5,874
thanks,
-ceej
The spec's are simple: 8-bit Windows BMP, 32x32px maximum size. If you want any part of the icon transparent, it must be colored Magenta (r,g,b, = 255, 0, 255).
In general EMOTO's comments are correct and they apply to the zumo 66x brand as well. One addition I'll make is that when using Garmin's POILoader to create your POI files you can name them anything you want as the POILoaders screen below indicates.
Naming your POI files (you can have more than one) is a good thing as the default is POI.GPI. If you only use the default name, each time you update/change your POI file the old one is overwritten. So, give your POI files an appropriate name. For example my Garmin/POI/ folder looks like this:
BMW Dealers.gpi
Road Food.gpi
Camping.gpi
Repair Shops.gpi
US Embassies.gpi
Cheers,
Cheers,
Dan
All Things GPS
Old 12-06-2012, 07:34 AM   #7
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,171
BMW Dealers.gpi
Road Food.gpi
Camping.gpi
Repair Shops.gpi
US Embassies.gpi
Cheers,
That is a really great tip!
Times are GMT -7.   It's 10:20 AM.
