Old 11-27-2012, 06:49 PM   #16
madeouttaglass
The AntiHarley
madeouttaglass's Avatar
Oddometer: 3,616
Thanks guys. Now I have something else on my winter "to do" list. I've had that same winch sitting in a box for two years. I'll make a front receiver because I already have a rear hitch receiver.
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149
Escape from NY- http://advrider.com/forums/showthread.php?t=955520
madeouttaglass is offline   Reply With Quote
Old 11-27-2012, 07:33 PM   #17
karitoki
karitoki's Avatar
Oddometer: 131
Originally Posted by Mr. Cob View Post
In short I can and have done all of these types of recoveries with a $49 dollar hand powered tool that may be slow but you can count on it to work even if your battery is dead or the connections have gone bad. A rope puller doesn't have the starbucks appeal that some folks require but it'll get you home and thats what counts in the real world.
What model rope puller do you use and where do you buy one?
karitoki is offline   Reply With Quote
Old 11-27-2012, 08:17 PM   #18
windmill
windmill's Avatar
Oddometer: 4,084
Maasdam rope puller.
https://www.treestuff.com/store/catalog.asp?item=117
Mclendons hardware carries them, Ace Hardware sometimes has them too.
"Take care, sir," cried Sancho. "Those over there are not giants but windmills".
windmill is offline   Reply With Quote
Old 11-28-2012, 11:42 AM   #19
dholaday
dholaday's Avatar
Oddometer: 342
Question
Mr. Cob:
How long a rope do you usually carry?
Thanks,
Duncan
It is better to have ridden and crashed, than to have never ridden at all.
dholaday is offline   Reply With Quote
Old 11-28-2012, 03:23 PM   #20
Mr. Cob
Howling "Mad", Adventurer
Mr. Cob's Avatar
Oddometer: 9,495
Originally Posted by dholaday View Post
Mr. Cob:
Thanks,
Duncan
Howdy dholaday,
The rope puller came with a 50 foot rope, I bought an extra 20 foot rope so I could tie off to an anchor if needed.
Dave, aka "Mr. Cob"
My photos, http://mr-cob.smugmug.com/ Join Smugmug, use this coupon ( https://secure.smugmug.com/signup?Coupon=geyYbNZwLLrl6 )
Mr. Cob is offline   Reply With Quote
Old 11-29-2012, 03:48 PM   #21
on2wheels52
Oddometer: 2,478
Looks like that rope puller deserves looking into. Thanks Mr. Cob.
Jim
R1200GS Ural Patrol KLR650 DRz400 XL185
Austria '08 http://www.advrider.com/forums/showthread.php?t=352082
Back to the Alps in '11 http://advrider.com/forums/showthread.php?t=744205
on2wheels52 is online now   Reply With Quote
Old 11-29-2012, 04:11 PM   #22
SmellyGoatBoy
SmellyGoatBoy's Avatar
Oddometer: 88
Here's the ride report. Has pictures and video of the ride and recovery.
http://advrider.com/forums/showthrea...ght=snoqualmie
"It is better to live one day as a lion, than a life time as a lamb."
SmellyGoatBoy is offline   Reply With Quote
Old 11-29-2012, 04:15 PM   #23
Mr. Cob
Mr. Cob's Avatar
Oddometer: 9,495
Howdy All,
I do not want to in any way give the impression that an electric winch on a sidecar rig is a bad thing, its just that I have used the rope puller for so long and have used it in situations where I doubt an electric winch would have been able to be of much good use.
That said I have for years thought about installing an electric winch on my rig but didn't take the time or make the effort to do so in a way that I thought would make it a practical, easy to use tool for recovery purposes. I have done a lot of research since the ride where Jay and I worked together to make a quick, safe recovery. I have just ordered a winch that I think I can make work as I would like it to.
My plan is to build a receiver that is welded to the front and rear of the sidecar frame, the winch will be mounted on a plate with a stud that can be inserted and locked into either the front or rear receiver. The setup I have in mind will have permanent quick disconnect water proof electrical hookup's for the winch on both the front and rear receivers. This will allow the quick removal or installment of the winch on either end of the rig by simply pulling or inserting a retaining pin from the receiver, plugging or unplugging the power cord, at which point the winch would be ready to be put into use.
I can handle all the fabrication of the receivers and winch mount, I'll have to enlist the help of my buddy Chris when it comes to wiring this set up as I have NEVER been able to keep the scared smoke within the wires it always escapes. Parts are en route as this is written, fabrication will start when I have something to work with. My plan is to do a build report with photos that shows how and why I will do this as I do it.
Part of the build will be the installation and use of a larger battery, my years of experience with an electric winch have convinced me that you can't have enough battery if your in a tough situation and the winch is being worked hard. One real advantage of the Ural is the alternator on these things really puts out some juice that will go a long ways toward making the electric winch truly useful.
Oh, and don't think for a minute that this will replace the rope puller, I'll still pack the rope puller for those times when and if the electric winch isn't up to the task or needs some help getting it done.
Dave, aka "Mr. Cob"
Old 11-29-2012, 04:18 PM   #24
SmellyGoatBoy
Oddometer: 88
Can't seem to upload video from tapatalk via iPhone
SmellyGoatBoy screwed with this post 11-29-2012 at 05:47 PM
Old 11-30-2012, 02:05 AM   #25
pops
Oddometer: 1,592
Hi NorthwestRider .
We have fitted a winch to our sidecar as well .It is a 12V 4000lbs Electric Winch Wireless with Synthetic Wire. From ebay .We have only had to use it a few times in the bush .It sure is better than trying to push or dig the sidecar out when we get stuck.
I like the idea of being able to use the winch to pull the sidecar from the front or rear.
I will have to look at doing that to ours later .
The wife just said that it is also easy to get the sidecar up on the trailer when she has to come and pick me up when MY BMW needs a lift home .
Cheers Ian
pops is offline   Reply With Quote
Old 11-30-2012, 07:39 AM   #26
tony the tiger
yeah - what he said...
tony the tiger's Avatar
Oddometer: 10,545
Cool2
...I keep one o'them in the trunk when out and about too. Never seem to need it though... guess I'm a sedate pussycat.
Tony
Your signature contains too many lines and must be shortened. You may only have up to 5 line(s). Long text may have been implicitly wrapped, causing it to be counted as multiple lines.
tony the tiger is offline   Reply With Quote
Old 11-30-2012, 07:53 AM   #27
NortwestRider OP
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 4,073
I use to own a 4x4 shop and ran a 9,000lb winch front and rear ( yes 2 winches ) on my Tracker.The reason I ran 2 was that when I ran just 1 with a Warn receiver mount,there were times that I didn't have room to get around the back and slide the winch in.Also owning the shop I got "special" pricing on winches.on my sidecar rig I will probably never need ( I don't plan any real offroad just dirt and gravel roads) it so just a mount on front should work.I also can run the cable under the rig and pull from behind.I already have a receiver in the back and thought about doing that but I would have needed to beef it up for side pulls.Mr Cob,Warn makes a quick disconnect electrical cable for receiver mount winches which is water proof !!.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is offline   Reply With Quote
Old 11-30-2012, 08:18 AM   #28
nieppi
Oddometer: 114
Where you can go without a winch
www.nieppi.com
nieppi is offline   Reply With Quote
Old 11-30-2012, 09:50 AM   #29
Mr. Cob
Mr. Cob's Avatar
Oddometer: 9,495
Howdy NortwestRider,
I have ordered a water proof cable setup that will work with the winch, I should have all the different components within a couple of weeks, then I can start to figure how I am going to build the receiver mounts. My plan it to have the winch mounted on the rear receiver unless I need to use it to pull from the front. The reason I'll be carrying in the rear receiver is to keep weigh off the front of the rig and to help protect it from crashes or being drug through water, snow and mud. Like I said I have been thinking about this for years just now got around to seriously putting all the pieces together.
Dave, aka "Mr. Cob"
Old 11-30-2012, 04:39 PM   #30
3legs
Real men ride sidecars
3legs's Avatar
Oddometer: 1,157
Hi Dave
A word of warning about placing the winch on the rear. I have mine on the front because when I placed it on the rear I kept hitting my shins against the bloody thing Ouch!!!
3legs
3legs is offline   Reply With Quote
Times are GMT -7.   It's 05:46 AM.
