Old 11-25-2012, 09:19 PM   #1
81cr450 OP
Oddometer: 96
2-stroke powered ninja 250r?
I'm sure I'm not the only one on here who's had the thought of a 2-stroke powered ninja 250r.
What I'm wondering is anybody "seen" any links anywhere of completed build's. Fabbing a whole bike would be beyond me, but a conversion I could manage.
I'm thinking it couldnt be much different than building an AF bike. Ideally I like the new CBR 250 r honda with a kx500 motor in it, cause the steel frame would be easier to work with & it's gotta be slimmer with a single cylinder motor which would make everything line up better kicker & sprocket wise.
If I was to use the 2008+ ninja250 I think the banshee motor would be a better pick to fit the twin cylinder frame. I've seen one of the 1st gen 250 ninja's done on youtube but it wasnt very informative & was only a buzz up & down the street
cr500 builds would even interest me , just trying find more info period.
As far as a single cylinder & vibes , it really wouldnt be any worse than in a dirtbike would it?
Thanks for any input
81cr450 is offline   Reply With Quote
Old 11-25-2012, 10:45 PM   #2
Tosh Togo
Oddometer: 1,594
An RZ350 engine would be worth a look. It's about the same size as your EX250 engine is, but makes more power and weighs less. A Banshee engine would work just as well... you'll be making custom pipes anyway.
Tosh Togo screwed with this post 11-25-2012 at 10:53 PM
Tosh Togo is offline   Reply With Quote
Old 11-26-2012, 06:05 AM   #3
jar944
jar944's Avatar
Oddometer: 695
The 500cc 2t singles vibrate.. a lot. The counter shaft dictates engine placement and dirt bikes are considerably narrower then most street bikes. because of that Getting a functioning kick start seems almost impossible due to the frame width.
I've thought about a banshee/RZ powered 250 ninja, I even have a banshee motor sitting in my garage waiting to be swapped into something.
Pipe fitment on the twin is the issue. keeping it inside the faring would require some effort.
jar944 is online now   Reply With Quote
Old 11-26-2012, 04:43 PM   #4
81cr450 OP
Oddometer: 96
Photobucket
Photobucket
Looks like a bit of room for "a" pipe, might could make room for 2 if you put cutouts in fairing kinda like they do to car hoods when a turbo is peeking through.
My question about a big single could have been better phrased maybe. I've been riding 2t 500's for the last 10+ years the vibes dont bother me , would it be worse or amplified in a street bike. I realize you'd need to gear it so it would be in the smooth spots at cruise RPM but...
An RZ350 motor would be good but I think you could get a better powervalve set up with something like the T-rex jugs as well as go bigger. No doubt a twin would be the smoothest, the banshee motors where barely bolted into the frame compared to a dirtbike single
Offset sprockets arent a big deal to shift the motor over to help with a kicker throwing the weight off center much would be a big negative though
81cr450 screwed with this post 11-26-2012 at 05:23 PM
Old 11-26-2012, 08:11 PM   #5
Motorrad
Motorrad's Avatar
Oddometer: 226
Kawasaki sucks... why would you want one of those.... get a honda...
haha..
Okay..
I always thought one of those with a HOT HOT built 250R atc motor would be fun..
Motorrad screwed with this post 11-26-2012 at 08:21 PM
Motorrad is offline   Reply With Quote
Old 11-26-2012, 09:38 PM   #6
81cr450 OP
Oddometer: 96
The reverse kick would actually work quite well & its counter balanced , 6 speed , 90 hp with a Liger jug
Old 11-26-2012, 09:54 PM   #7
Motorrad
Motorrad's Avatar
Oddometer: 226
exactly what I was thinking....
Old 11-27-2012, 04:58 AM   #8
jar944
jar944's Avatar
Oddometer: 695
The vibrations may or may not be more, it would depend on the mounting and frame rigidity. I wouldn't think it would be much of a change either way. It's the constant speed vibration that would get annoying.
For the banshee, a serval / or cheetah powervalve setup (420 to 485cc) would be plenty of motor. Then swap in a RZ transmission and you have enough gearing for the highway.
Offset sprockets put more load into the counter shaft bearings, I would avoid them.
Old 11-27-2012, 09:19 AM   #9
Navin
Navin's Avatar
Oddometer: 7,992
I'm trying to build a decent bike out of a 2013 Ninja 300. The engine is the best part of the bike. There are better chassies to swap a 2t into. Search CL for parted out GSXRs. A roller from any 600 SS would be a far better base to start with.
Navin is offline   Reply With Quote
Old 11-27-2012, 09:59 AM   #10
2trally
User Awaiting Email Confirmation
Oddometer: 62
Have you seen the 450 mono gp bikes? I think it would be easier to start with something like a kx500, change the suspension, gearing, subframe and wheels. Then fabricate some fiberglass bodywork for it. You would end up with a lot lighter bike and there wouldn't be as much custom fabrication.
Okay, maybe there would be more custom fabrication, but I think your less likely to run into a problem that will stop the project cold by changing the suspension and subframe than by changing the engine.
2trally screwed with this post 11-27-2012 at 10:17 AM
2trally is offline   Reply With Quote
Old 11-27-2012, 11:58 AM   #11
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,690
You might try to find one of these :
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper
Andyinhilo is offline   Reply With Quote
Old 11-27-2012, 12:01 PM   #12
Motorrad
Motorrad's Avatar
Oddometer: 226
just go find a RD500 and get it over with.. spend money... and ride..
Old 11-27-2012, 12:38 PM   #13
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 8,980
Is alignment that big of a deal? I would mount the motor with the sprocket lined up, then make a custom kick starter to fit the area. A simple dog leg bent into a stock kicker should do the trick, right?
They used to have some cool 125 and 250 2-strokes at Laguna Seca during the MotoGP races.
High Country Herb is offline   Reply With Quote
Old 11-27-2012, 01:16 PM   #14
jar944
jar944's Avatar
Oddometer: 695
On a 125/250 yes, that will work. On a 500 the extra outboard leverage WILL break the case.
Old 11-27-2012, 07:50 PM   #15
81cr450 OP
Oddometer: 96
Gixxer weight is the hangup 424 lbs w/fuel . compared to near a 100 lbs less with the 250 size bikes
The offset sprocket does work you just need an additional bearing set up to the outside. Definitley more fab work though. & I have thought that you could poly mount in a cage with no movement available so it just dampens the vibes
A cheap more modern suspension bike is why I'm not looking at the buy & ride type. I have a real hard time just riding "stock" machines, tinkeritis bad, Thats half the fun putting it together & making it work.
I do have the KX550, SUMO really would be the easiest & probably the lightest.
The 250r motor shifted to the sproket side all the way would leave you more room for a pipe on the other side & you could bend the kicker on it as long as you had a decompressor in the head.
Thanks for the idea's & the cool pics of the sweet old iron Guy's
. I admit it's a bit of a PIPE dream at the moment, but thinking it through has really brought in some great ideas. More input definitley welcome.
Horse power wouldnt be as big of structural detriment as weight, I've read on some other forums that it would just trash a bike doubling the horsepower that the factory intended, but you see guys do that & more on Banshee's & other machines with no ill effect & considering you'd be losing weight with a lighter motor wouldnt that be a big positive structurally?
Times are GMT -7.   It's 05:27 AM.
