Old 11-28-2012, 08:33 AM   #16
Navin
Navin's Avatar
Oddometer: 8,082
[QUOTE=81cr450;20131489A cheap more modern suspension bike is why I'm not looking at the buy & ride type. I have a real hard time just riding "stock" machines, tinkeritis bad, Thats half the fun putting it together & making it work.
QUOTE]
The Ninja 250 is cheap but I wouldn't call anything else about it modern. It is a 1980s bike in later style clothing. Even the 2013 300 isn't different enough to make it modern as far as the chassie is concerned.
Navin is offline   Reply With Quote
Old 11-29-2012, 11:16 AM   #17
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 9,068
Originally Posted by 81cr450 View Post
The offset sprocket does work you just need an additional bearing set up to the outside. Definitley more fab work though.
That would be pretty easy to do on the kick starter shaft. All you would need is an extension with female and male splined ends, and a couple bearings to keep it all aligned. There isn't nearly as much stress on the kicker, so the bearings wouldn't need to be oiled or anything. 2 skateboard wheel bearings would do the trick.
High Country Herb is offline   Reply With Quote
Old 11-29-2012, 07:31 PM   #18
81cr450 OP
Oddometer: 96
I like that idea, much better than bending a kicker.
Probably right as far as it not really being more modern , the 08+ up just have the more common tire sizes than the older 250 ninja bikes
81cr450 is offline   Reply With Quote
Old 12-01-2012, 07:14 AM   #19
Sh0nky
Oddometer: 5
Here is a decent thread with an RD engine in one:
http://www.2strokeworld.com/forum/in...p?topic=7376.0
Personally I would find an old KX250 or something and put that in there. Keep it really really light.
Sh0nky is offline   Reply With Quote
Old 12-02-2012, 07:40 PM   #20
81cr450 OP
Oddometer: 96
Thanks Sh0nky that is exactly the kind of thing I was looking for. I googlieyed searched for like a half a day but most everthing I ran across was just "oh yeah that'd be cool" & the starters that dont finish. It was great that they listed a weight there too, I'd assumed it'd be a bit lighter for sure
Times are GMT -7.   It's 03:51 AM.
