12-03-2012, 03:01 PM
#16 |
GPoET&P
Oddometer: 3,749
12-07-2012, 02:17 PM
#17 |
Sleep, Wrench, Ride
Oddometer: 4,445
At some point in the bike's history a bolt rubbed on the rear drum cover and put a giant gouge in it. I thought I should go ahead and take care of this.
![]() Cleaned and welded: ![]() And sanded back down (not perfect, but this bike's not going to be perfect)
Bikes: DR350 | GR650 Street Tracker | NX650 Turbo | Catamount Cycles Events: 2013 Monkey-Butt 500 | BreckTrek 2013 |
12-07-2012, 02:27 PM
#18 |
Sleep, Wrench, Ride
Oddometer: 4,445
I've also started to tear into the primary to try and stop an oil leak (pointless endeavor on an old Harley, I know) and see if anything else needs to be fixed.
![]() I called the dealership to get new clutch seals. The guy took about 20 minutes to tell me most of the seals for this bike are discontinued. He can get one of them, but he would have to charge me for 10 of them because that's the minimum quantity he can order them in and he won't be able to sell the rest. I'm guessing I won't be relying on the dealership much for this project.
12-07-2012, 02:56 PM
#19 |
Squiddly slow
Oddometer: 878
XR750 replica?
12-11-2012, 10:55 AM
#20 |
Sleep, Wrench, Ride
Oddometer: 4,445
The bike's been starting well, but I haven't been taking it out on long rides, so I thought I wouldn't hurt to put it on a trickle charger. After two days the battery still wasn't at full charge and it sounded like the acid in the battery was boiling so I took the charger off. It was just a little battery tender like this:
![]() Can anyone tell me what's going on with my battery?
12-12-2012, 04:56 PM
#21 |
Oddometer: 335
I ride a bullet. A 2 wheeled, multiple-explosion powered machine with enough moving parts to remove entire fingers. Surfaces hot enough to cook flesh. It propels me at neck-breaking, bone-snapping flesh-tearing speeds, over and trough obstacle's I can only see as blurs. Its a sport that kills the careless, maims the best, and spits at the concept of mercy. |
12-14-2012, 02:43 PM
#22 |
Riding Nomad™
Oddometer: 12,722
-- i cant wait to see what this will turn into!
Learn to ride. Ride to learn. FS: 1993 Suzuki DR350S (wide ratio 6 speed - street legal kickstart) |
12-15-2012, 12:10 PM
#23 |
motorcycle addict
Oddometer: 890
In current form...
![]() ![]() Can't wait to see where it goes without that paint and springer nonesense.
it is easier to ask for forgiveness than permission |
12-24-2012, 02:08 PM
#24 |
Sleep, Wrench, Ride
Oddometer: 4,445
Sort of.
Yes And yes. I guess I made that one too easy. The pre-75 Sportsters had a right side shifter which is perfect for flat track. I've already got conventional forks and a 19" front rim on the way.
12-25-2012, 12:22 PM
#25 |
GPoET&P
Oddometer: 3,749
Ohhhhh yeaaaah!!!!
02-22-2013, 09:07 PM
#26 |
Oddometer: 737
For parts, check out sporty parts in Fullerton California. All they do is sportster parts. From all eras.
02-22-2013, 09:19 PM
#27 |
Nanu-Nanu Adventurer
Oddometer: 7,012
Back in the good old days, on Brit bikes, we would use silk thread on the primary with no gasket. I would stop the most stubborn oil leaks.
![]() Marc
04 R1150RT,06 KTM 450EXC, 84 R100RS LE, 89 XL600V, 2012 Stelvio, 72 Guzzi Eldorado http://s22.photobucket.com/albums/b327/lomaxcm/?sc=3 |
