Old 12-02-2012, 01:55 PM   #16
Gordo83
Oddometer: 144
Not to change the subject, but what is the white jug with the black pipe going to ? doing there. I've had an 85 TY350 for several years and haven't seen this add-on. This is in regards to the craigslist TY350
in Kansas City.
Gordo83 is offline   Reply With Quote
Old 12-03-2012, 06:37 AM   #17
Sting32
Trials Evangelist
Oddometer: 1,438
in Kansas City.
I've seen the mod, on several of these old Yamaha bikes in Wichita area, back in the days. I ended up with a 350 not long ago that had this, but I dont really know what it does... Because, I only rode Bultaco's back in those day, so cant tell you exactly, but I think it was Some theory about response time on throttle using this "can" which I believe stores up "vacuum" so that when you crack the throttle it acted differently. I could be wrong...
Sting32 is offline   Reply With Quote
Old 12-03-2012, 08:30 AM   #18
Brewtus
Buffoonery, Inc.
Brewtus's Avatar
Oddometer: 3,131
Originally Posted by 2whlrcr View Post
That's a big plus, because half of the people in the US can't. And I'm including the ones that were born here too.
Tell me about it.
Work hard. Play hard.
Team Dead End. The drinking team with a Trials problem.
2-Time winner of the coveted "Best Shenanigans" award at Capt. Rick's annual BBQ.
Brewtus is offline   Reply With Quote
Old 12-03-2012, 09:26 AM   #19
PSchrauber
PSchrauber's Avatar
Location: Summer: Kemiö, Finland; Winter: North Germany
Oddometer: 867
in Kansas City.
That is a hand made Yamaha YEIS System, that they had back then.
YEIS stands for: Yamaha Energy Induction System
The YEIS consits of a plastic container, which is connected with a rubber hose to the inlet of the engine.
This creates a kind of reservoir between the carburetor and cylinder, in which the two-stroke mixture will retained when the slide (little or no gas) or the gates/reeds of the cylinder are closed until the slide or gates/reeds by the piston are opened again.
The system also works as a vibration damper in terms of sound (Greetings to Hemholz) at certain speeds between the combustion chamber and carburetor as the gases oscillating back and forth.
The YEIS causes a better engine response, more torque at low and medium revs and a lower consumption by up to 10%.
PSchrauber is offline   Reply With Quote
Old 12-30-2012, 06:54 PM   #20
xtnomad
xtnomad's Avatar
Oddometer: 96
If you are still looking, I boxed away quite a few parts years ago, Rings,Pistons Gaskets Reeds ect. I have a stock cylinder and head still on the shelf. PM me.
xtnomad is offline   Reply With Quote
Old 01-05-2013, 09:48 AM   #21
RobbieO
Muskokatard
RobbieO's Avatar
Oddometer: 8,942
We used to call that thing a "boost bottle". I had one on my Italjet and the improvement of low end response was noticable!!!
Only a biker knows why a dog sticks his head out of a car window.
RobbieO is offline   Reply With Quote
Times are GMT -7.   It's 04:13 PM.
