Old 04-27-2014, 08:12 PM   #1741
Dieselpwr
Dieselpwr's Avatar
Oddometer: 440
Take a look at your oil cooler. mine has a small leak. Luckily it's still under warranty.
2011 BMW R1200R Classic
Dieselpwr is offline   Reply With Quote
Old 04-28-2014, 07:15 AM   #1742
Hoop71
Hoop71's Avatar
Oddometer: 123
Leo Vince Exhaust
Just a heads up for anyone looking for an exhaust for their bike.
http://www.revzilla.com/motorcycle/l...m_medium=email
Hoop71 is offline   Reply With Quote
Old 04-28-2014, 07:27 AM   #1743
Patch
Patch's Avatar
Oddometer: 739
Wonder how it sounds ... Can't you-tube at work.
Price might make me rethink getting that fat stocker off my bike.
Thanks Hoop
Patch is offline   Reply With Quote
Old 04-28-2014, 07:28 AM   #1744
objectuser
objectuser's Avatar
Oddometer: 242
Originally Posted by GreyThumper View Post
Better consider what you're likely to put in the top box, since the Givi rack has a weight limit (10 kilos, IIRC), so it might be a waste of money to spend on a bigger top box anyway.
I have the E193 on mine. I use the E52 Givi case on it and have not had problems, but I've not taken it cross country either. I throw my backpack in there, which contains my laptop.
I did use blue loctite on the bolts under the E193 because they came loose once.
2009 R1200R - Sold
2009 R1200GS
1968 Norton P11A
objectuser is offline   Reply With Quote
Old 04-28-2014, 09:46 AM   #1745
ph0rk
Doesn't Care
ph0rk's Avatar
Oddometer: 2,057
That does look like an awful good deal. How many years does one of those things last? They (LeoVince) has several other products at different price points, and most other silencers for the R1200R are in the $700-800 range. I wonder where this one skimped?
--Semantics are everything.
ph0rk is offline   Reply With Quote
Old 04-28-2014, 11:09 AM   #1746
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,365
I've had LV pipes on a few bikes, they're always best bang for the buck.
Every bit as good as most manufacturers out there.
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is online now   Reply With Quote
Old 04-28-2014, 02:15 PM   #1747
janson-swg
Oddometer: 3
I just finished making some changes on my R1100R...hope you like it.
janson-swg is offline   Reply With Quote
Old 04-28-2014, 05:14 PM   #1748
rous44
rous44's Avatar
Oddometer: 1,296
Looks like a great deal. Will it fit a 2013?
Registered offender
"picking up hookers, instead of a pen, the words of my youth slipped away" Waylon Jennings
MX '06 http://www.advrider.com/forums/showthread.php?t=176637
MX '07
http://www.advrider.com/forums/showthread.php?t=278826
rous44 is offline   Reply With Quote
Old 04-28-2014, 07:23 PM   #1749
Rick G
Ranger Rick
Rick G's Avatar
Oddometer: 2,006
Anyone know if a new computer tune is needed with one of these and is it available from BMW ala Triumph?
Rick G
Any Road Any Time!
2011 BMW R1200R - The Redhead with Big Jugs I have always wanted!
2009 Vespa GTS Super 250ie - Just for Kicks & Giggles
Rick G is offline   Reply With Quote
Old 04-28-2014, 11:53 PM   #1750
Hoop71
Hoop71's Avatar
Oddometer: 123
Rick G
I put a Remus slip on on my 2011 and no tuning needed. Ran like a top!
Old 04-29-2014, 08:18 AM   #1751
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,552
Rick G
Typically the exhaust change does not move the operating parameters out of the normal range. This is why there is no significant improvement in performance with the change of exhaust on the R-series.
JimVonBaden is online now   Reply With Quote
Old 04-29-2014, 11:44 AM   #1752
clevishook
stevedore
clevishook's Avatar
Oddometer: 1,596
I put a luftmeister pipe on my old R1150rs and rode it around the hood. No performance difference but it was loud. Took it right back off and reinstalled the stock pipe. That noise gives me a headache after just a few miles.
clevishook is offline   Reply With Quote
Old 04-29-2014, 01:39 PM   #1753
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,365
True dat, but with a caveat.
Changing the muffler only does next to nil. Changing the headers to eleiminate the cat converter opens the system up to help it 'breath', causing less back pressure, and in turn, allowing the boxer motor to rev and de-rev easier.
The result is less restriction and a smoother running motorall around.
Money better spent on a set of headers than a slip-on can.
Old 04-29-2014, 02:19 PM   #1754
ph0rk
Doesn't Care
ph0rk's Avatar
Oddometer: 2,057
A smoother running motor that might be less good around town, where the low end torque is rather useful. Pretty damn handy jockeying for position on the interstate around rush hour, too - I can squirt ahead of traffic about to do something stupid with only right wrist input, regardless of where I am in the RPM range (even in 6th).
Others disagree, of course.
Old 04-29-2014, 02:32 PM   #1755
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,365
contrare'
Just the opposite, smoother running meaning less jerkiness and more refined/controlled operation with both the throttle and the gearbox/clutch.
This doesn't mean a loss of torque.
2 of the best mods for a modern boxer are the cat removal and a fuel nanny or Accelerator (booster plug) module.
Times are GMT -7.   It's 03:54 PM.
