Old 08-09-2013, 08:40 AM   #931
Roadscum
Oddometer: 2,396
Originally Posted by live2offroad View Post
My bike lost a bunch of unnecessary weight yesterday..
You can read about why it's ok here
http://r1150r.org/board/viewtopic.php?f=2&t=15335
And..... Ya probably lost a handful of low end torque.
Regards, Paul
"One of the things that make motorcycling so great is because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Roadscum is offline   Reply With Quote
Old 08-09-2013, 08:52 AM   #932
cug
Oddometer: 4,880
Does anybody know how complex it is to swap the shocks (front and rear) on a Camhead R? 2013 model.
cug is offline   Reply With Quote
Old 08-09-2013, 09:06 AM   #933
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,480
...not complicated at all. If your at all mechanically inclined and a few wrenches, it's a 1 hour job.
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 08-09-2013, 09:08 AM   #934
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,480
Talking
Less weight, then that be a race bike, eh?
Old 08-09-2013, 09:09 AM   #935
cug
Oddometer: 4,880
Do you know the necessary work is? Do I have to take parts off? Or can most things stay in place (like fork, wheels, ...)?
Old 08-09-2013, 09:17 AM   #936
bxrdon
bxrdon's Avatar
Oddometer: 6
I've done the job, most of it was easy. I don't remember all of the steps, but what I do remember is about the rear lower shock bolt. It's heavily coated with loctite. I had to heat the swingarm with a torch to get it out, and had to replace the bolt with a new one afterwards because the head was damaged. So make sure to have a torch handy before you start.
bxrdon is offline   Reply With Quote
Old 08-09-2013, 09:29 AM   #937
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,480
Best to have some sort of lift like Harbor Freight or Sears sells that will jack the bike up from the center, both or one wheel at a time suspended off the ground or close to the ground.
Do one end at a time.
Lift the rear so that both bolts don't have any stress on them and remove.
In other words, the tire can be on the ground but you'll adjust the lift to relieve tension on the bolts.
Same for the front.
Old 08-09-2013, 09:33 AM   #938
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,233
I'm pretty sure it should be the same procedure as on my 07' 12R, in that case you'll need to at the very least slide the tank back (couple of bolts), easy to remove it to give you more space too. It also depends on if you still have the charcoal canister on, a mod you could do while in there, or just remove it and then put it back on. You'll need to support the front of the bike to remove the shock with a jack or by lifting it with a ratchet strap. Remove the top nut first then break loose the lower bolt, then support the bike.
BMW calls for replacing both upper and lower bolts on the rear and the lower from the front when removing the shock since they come micro-incapsulated with locktite from the factory.
Wheels can stay on as far as I remember. Let me know if you need any other help, I probably have more photos. But yes, like mentioned it's a pretty straightforward job to DIY. Probably could find you the torque specs too if you don't have a service manual, assuming they are the same for the different model years, which I would think they would be but can't confirm.
How I support the front:
Photography for me is not about recreating what I saw through
the viewfinder but to show people the way I want to see the world.
LostRider.com
Lost Rider screwed with this post 08-09-2013 at 09:45 AM
Lost Rider is offline   Reply With Quote
Old 08-09-2013, 09:39 AM   #939
Mens Rea
Mens Rea's Avatar
Oddometer: 301
live2offroad, what parts did you use and where did you get them? I want to run a full-size left case and found this thread:
http://www.advrider.com/forums/showthread.php?t=905818
And MIXR, BobbySands, and Mr. Canoehead mentioning running a turn-down. I think I need a 1.75" clamp-on style but haven't found one, even on Amazon. I was thinking of getting a weld-on type and just cutting a slot in it to clamp it. I don't want to make the change permanent so no weld-ons. What did you use?
-- Scott
Mens Rea is online now   Reply With Quote
Old 08-09-2013, 09:41 AM   #940
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,233
I had one of those, it didn't seem to be able to lift the bike evenly since the motor isn't wide enough and oddly shaped, was very wobbly, at least the one I had, maybe yours is different. Using a standard jack and center stand is pretty solid.
LostRider.com
Old 08-09-2013, 09:46 AM   #941
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,480
Yes, forgot about the center stand...mater o fact I think I used it myself.
Old 08-09-2013, 10:10 AM   #942
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,233
Speaking of center stands, I have a brand new center stand for a 12R in my garage if anyone needs one for a great price, PM me.
LostRider.com
Old 08-09-2013, 11:39 AM   #943
live2offroad
live2offroad's Avatar
Oddometer: 337
Regards, Paul
None. All the needed back pressure comes from the Catalytic converter.. The mixture sensor is also well before the "can".. Read the info..
live2offroad is offline   Reply With Quote
Old 08-09-2013, 04:58 PM   #944
live2offroad
Oddometer: 337
-- Scott
That is a cheap chrome temp tip from Walmart while the 8in pipe comes in to the shop I ordered it from..
The Tip is aesthetic, you can just pull the can and let it run.. I like the 8in tip because it ports the hot gas past both rider and passenger foot rest.
-Peter
Old 08-09-2013, 05:17 PM   #945
Ricky Chuck
Red Green Rulz!
Ricky Chuck's Avatar
Oddometer: 460
Regards, Paul
Road S, is that pipe emptying into the front of any suitcase you'd put on there? Any worry about hurting the suitcase?
2005 BMW R1150RT
Ricky Chuck is offline   Reply With Quote
Times are GMT -7.   It's 10:24 PM.
