11-29-2012, 10:51 PM
#16 |
Oddometer: 179
full time (differential'd) will be great when you're putting 180+hp to the ground (more if I do get that turbo). One wheel drive in the dirt with that much power will shred tires. But this topic is about a ural with 1 or 2wd and not even half that horsepower so it's more comparable to 2wd vs 4wd truck in the dirt/sand/snow. Hit it a lot of speed in 2wd or chew your ay through in 4wd. Same goes for the bike. Just my thoughts.
-Brock
Side Effects Sidecars and Trikes Builder, designer, fabricator, sales, installer, problem solver, R&D guy http://www.facebook.com/pages/Side-E...44069652295470 www.sidecars.ca |
11-30-2012, 05:25 AM
#17 |
Oddometer: 16
Thanks for all the opinions. I'll probably be looking for one with the 2wd.
11-30-2012, 07:07 AM
#18 | |
UDF Adventurer
Location: an alternate universe, much better than yours
Oddometer: 310
I have a 2006 Ural Gear Up and often take it down unmaintained logging roads/closed township roads. You don't need 2wd until you need it.
And often the deployment of 2wd takes you to a place where a winch or rope puller/and/or monkey have to push to get back out. You don't NEED it, but you may WANT it sometime. Get it if you buy a Ural, you will certainly use it, albeit not often. But you can live without it. Either way, if you plan to drive off of maintained dirt roads, you will get stuck so have a back up plan of mechanical or human help. Heck, I have even managed to stick a Rokon and an Argo in mud and swamp, so even 8 wheel drive won't save your *ss sometimes. But a winch will. Quote:
Honda ST1300, Ural Gear Up, Rokon Ranger and now an Argo, WTF is wrong with me? A Brit named Billy once said something silly; he so wrongly concluded that Ural deluded.
Montague screwed with this post 11-30-2012 at 08:44 AM |
11-30-2012, 08:35 AM
#19 | |
Sidecar Jockey
Claude Founder: Internet Sidecar Owners Klub at SCT http://autos.groups.yahoo.com/group/SCT/ President: C Stanley Motorsports Inc. http://autos.groups.yahoo.com/group/...rsandTrailers/ http://freedomsidecars.com/ |
11-30-2012, 09:33 AM
#20 |
n00balicious
Oddometer: 2,943
Mr. Cob is without a doubt one of the more "extreme" sidecar drivers around, the fact that he only uses it 3% of the time shows how little 2wd is "needed". Being that the OP will be on dirt/gravel roads that are not steep or rocky, I would say that a Ural Tourist would fit his requirements very well.
"I couldn't wait for success, so I went ahead without it." |
11-30-2012, 09:53 AM
#21 | |
Scott Whitney
Oddometer: 2,247
11-30-2012, 10:00 AM
#22 | |
Howling "Mad", Adventurer
Oddometer: 8,801
I think there is a viable market for a two wheel drive system for the GS sires of bikes, the problem as I see it is that anything now on the market puts it will beyond the means of the average GS hack pilot. I have followed the Aussie builds, with the sidecar mounted on the left getting two wheel drive is a MUCH easier and cheaper thing to do then for us who have the sidecar mounted on the right hand side. I really like my hacked GS but every time I have to manually push it backwards or turn around on a road because I don't want to chance getting stuck as it doesn't have two wheel drive, my Ural's are sitting the garage laughing the Russian ass-arses off.
Dave, aka "Mr. Cob" Want a STEEL SKID PLATE for your Ural, contact me for details. My photos, http://mr-cob.smugmug.com/ Help a CHEAP bastard keep his Smugmug, use this coupon ( geyYbNZwLLrl6 ) thank you. |
11-30-2012, 10:40 AM
#23 |
four-stroke earth-saw
Oddometer: 657
As many others have said, its not needed. Until its needed.
I only use it sparingly, usually to get me out of situations. Mud. Snow. Sand. When it IS needed, it works very well. I suppose its a lot of extra cost and complexity for those every-now-and-then situations. However, I prefer to dictate where I'm going to ride, rather than let me rig decide that for me. I don't turn around often. ![]() I should mention that it does put some added stress on the final drive, having the driveshaft moving about. If you plan on riding 60-65mph everywhere on pavement and only doing a few miles on gravel roads, I'd get a single wheel drive model. I don't go much above 55mph on pavement, and wherever possible, stick to fire roads.
Buy it, use it, break it, fix it. |
11-30-2012, 11:20 AM
#24 |
Oddometer: 8,801
Howdy All,
Barry and I were in one wheel drive up to this point. This was where Barry stopped and I put my rig into two wheel drive. Easy riding up to this point good solid snow to get a grip on, the snow was much softer where it got deeper in front of where we stopped. Because of the break in the tree cover more snow hit the ground ahead making it deeper, it was a fairly nice day so more sunlight had hit the snow making it softer in the drifted area ahead of us. ![]() As they say a picture is worth 10,000 words. In this photo you can see Barry's ( windmill ) rig is about a 100 or so feet behind mine. I decided to see if I could blast through the snow drift to get to the less deep snow on the other side of this area. Shift into two wheel drive, winder up, drop the clutch, dig through the snow down to the gravel and GO. Well go until the snow I was pushing lifted the front of the rig up to where it was skiing on the skid plate and packed up under the sidecar which eventually resulted in no forward movement. However, stuck as the rig was, I put the rig into reverse and backed it up under its own power with NO human being pushing involved. ![]() Look how the snow is packed up between the bike and the sidecar, and still the rig powered itself backwards out of this situation. ![]() As you can in this photo there is a DEEP ditch on the left side of the logging road, and a very steep LONG drop on the right side of the road. I wouldn't even consider taking a one wheel drive rig with out reverse into such conditions. ![]() Barry and I have a habit of riding in this type of environment, during this ride we probably used two wheel drive for a mile out of the 50 or so we spent on the logging roads, sometimes only for a distance of 20 feet but without it we would not have been able to continue to the point where we were forced to turn around. So the whole one verses two wheel drive AND reverse thing really boils down to how far do you want to go and how much physical labor do you want to expend doing it.
11-30-2012, 01:54 PM
#25 |
Mad Scientist
Oddometer: 3,005
I have about 250k miles on sidecars and probably 30K of that is off road. There are times I wish I had 2WD for the those adventurous spots on the trail.
BOXER Metal BMW Biker Scum BMW Mad Scientist! VBMWMO #7770, BMW MOA #48694 & Airhead BMW Club #600 |
11-30-2012, 08:15 PM
#26 | |
Sidecar Jockey
The 1200GS bikes would be an easier conversion for 2WD than the earlier GS models for right mount sidecars. Those of us who have actually been in the push it back/ dig it out/ turn it around / find the shovel/ jack it up/ wonder how far it is to walk outa here/ it is getting dark soon/ I am a fool/ wish I would have listened to that little voice in my head/ should I laugh or cry situations can relate to the good points of 2WD and / or reverse. It is still amazing what even a one wheel drive outfit can do off road but knowing that one can engage another wheel would be a good feeling. My worst experiences with one wheel drive have been on steep uphills where you cannot maintain a decent speed. Shift weigth to get steering back / lose traction/ shift weight back yadda yadda. Then lets roll back and do a turn around keeping the sidecar on the downhill side if possible. LOL...Are we having fun yet?
12-01-2012, 07:34 AM
#27 |
Location: Climax NC or Fancy Gap VA (milemarker 199 BRP)
Oddometer: 305
I've been taking a Ural swd on some logging roads recently, hate to think how my stupidity would be rewarded with 2wd.
12-01-2012, 07:48 AM
#28 | |
Oddometer: 378
'09 R1200RT '07 Ural '65 MV750 |
12-01-2012, 03:17 PM
#30 |
The AntiHarley
Location: Bristol Hills in the Fingerlakes region of NY
Oddometer: 2,267
He needs five wheel drive.
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149 |
