11-29-2012, 12:58 PM
#1 |
Oddometer: 119
iPad 2 on my bike
I'm considering mounting my iPad on my 83 V65. I'll probably use a RAM mount. I would like to hear comments from any one that has actually done this, my searches didn't show much. Is the screen readable? My Garmin fades out in bright sun but if I change the viewing angle it helps. Also, if you have tried the RAM iPad holder is it secure enough?
I have one of their cheap holders on order. I can play with this an my RAM mount for the Garmin to see if there is room without hitting the tank of covering the gauges.
bob "Live while you're alive" 1983 V65 Magna 1984 700cc Magna 1982 V45 Sabre (Project) |
11-29-2012, 01:14 PM
#2 |
Oddometer: 21,548
Check out the Bags Connection tankbags, there is a waterproof iPad case that works with them. The total cost will be kind of high - you've got to buy the tank ring, the bag and the case, but it *is* waterproof, and that is a very nice feature.
11-29-2012, 03:06 PM
#3 |
Oddometer: 235
Any word on how they handle the heat while wrapped in a waterproof bag? My iPhone overheats if I use GPS while it's in a waterproof bag. Curious if the ipad dissipates better.
I buy all my stuff at motorcyclegear.com, formerly newenough. |
11-29-2012, 03:28 PM
#4 |
(Super-Genius)
Oddometer: 4,637
I would think it would be nearly impossible to read in the daytime.
11-29-2012, 03:37 PM
#5 |
Oddometer: 21,548
Heat is a good point. My iPad shuts down when its used indoors in direct sunlight, add a sealed environment and you've got a perfect environment for overheating the device.
I get wanting to use a large screen navigation system, I do not, OTOH, think an iPad is the best option out there. |
11-29-2012, 04:10 PM
#6 |
Bearded Hooligan
Oddometer: 490
Check out Seal Shield, at www.sealshield.com, will make your iPad completely water/dust proof. Only about $25 too. The issue that you are going to run into is overheating when hot out and in direct sunlight. I would also look into rokform cases, at www.rokform.com. They make a mount to a bicycle dont see why it wouldnt work on a motorcycle. iPad mini might be a better solution, but not much aftermarket support yet.
2004 BMW R1150GS Adventure ![]() Get a discount at Smugmug ![]() Use Code- iFRLhicsrl4no |
11-29-2012, 09:58 PM
#7 |
What could go wrong?
Oddometer: 4,960
I have no advice but can't help but to wonder why you want to mount it?
Kawasaki H1 build thread 71- 450 Honda CL re & re Just another pathetic sheep following the herd |
11-30-2012, 06:21 AM
#8 | |
Oddometer: 119
I'm liking the mapping apps that are available for the iPad and iPhone. I don't have an iPhone yet (cell service in VT is thin and zero at my house) and using it for GPS may give me enough reason to get one. So, I'm experimenting -- at least it will keep me off the streets for a while.
12-05-2012, 07:45 AM
#9 |
Oddometer: 4
iPad Woks Just Fine as a GPS
The iPad works fine with the Ram Mounts. I also installed a power source from 3BRPOWERSPORTcom. Just make sure you get the 2.1amp unit as the iPad won´t charge with the lower amp version. On its battery alone it´d last about ~5hours, so it´s good for short day rides. Needless to say you need the 3G version which comes with GPS. I use the SYGIC software available at apple store.
My experience has been good, albeit the screen is a bit too big blocking other instruments, and the unit (ipad 1) is heavy, but the RAM mounts holds it well. I ride a 1200GS. It terms of "waterproofing" I just use a ZIPLOCK bag and it works. The buffeting behind the screen creates a downward draft that keeps the bag in place. Also, I never had a problem with overheating, I live in Atlanta, and the brightness is set at maximum. I´d used for a year. Never had a problem. As a side note with the 3BR power source, It tends to discharge the battery when not in use as it has a transformer to turn 12v into 5.1v for the USB power source. It is normal, but be aware, that the battery may be low after 2 weeks without use. It does have a fuse that you can remove if the discharge bothers you. As and intermediate step, I use a lot my iPod touch with the Bad Elf GPS chip. I like it better than the ipad simply because it was easier to carry it around. Now the issue I had with this set up was that the extra chip was not designed to withstand the vibration of our horses, so it ended up in the trash can after the innards vibrate out of the plastic case and die. Plus, the chip dislodge constantly from the iPod. It even comes with a lanyard... So, I go next to my "final solution". I believe the perfect balance is available with the new mini ipad. Its size is just perfect for me, it doubles as a personal computer to take care of things while on a long trip and it weights less than half of the ipad. Ram mounts is coming with a dedicated cradle for it. So it is all good. We´d see how it goes. Hope this helps. |
12-05-2012, 08:01 AM
#10 |
Oddometer: 119
Thanks PhaedruZ. I agree that the iPad mini would be really good, now if I could only get my bank statement to agree.
What app are you using? Any thoughts on setting up routs ahead of time?? Letting the program pick the route is Ok unless there are particular roads you want to cover.
12-05-2012, 03:14 PM
#11 | |
Oddometer: 4
By the way, a cheaper option is the Nexus 7 tablet, starting at 200$ and I believe even the wi-fi only version has GPS. I decided to go the ipad route because my other computers are Apple and I did not want the hassle of learning yet another system. |
12-06-2012, 08:09 AM
#12 |
Oddometer: 119
Thanks for the input. SYGIC is clearly a contender. I'm looking a anything I can find to see if any will import gpx files.
For now I am "stuck" with my iPad2. I'll use that as a test bed and then see if I can come up with something smaller by riding season.
