12-02-2012, 06:25 AM
#1 |
honestly
Oddometer: 2,257
Harley guys - Xied
anyone running these?
Sounds like a decent alternative to tuner and remap. I've got a 2012 FLD. Looking to add a slipon first, and a AC in the future. Not sure if the Xieds will suffice, or I should pick up the variable Vieds
the carrot seed - honest country. Bulletproof VS. Bloodweiser - yamaha world super GP TT 5000 BW - 455 : BP - 100 |
12-02-2012, 06:52 AM
#2 |
Scofflaw
Oddometer: 152
I plugged in a FL-Xied-10 set the first day on my 2012 FLHR, ran them without trouble or complaint the first 1000 miles on my completely stock bike. Removed them when I purchased a Dynojet Power Vision and a couple other up-grades. If I hadn't made changes at 1000 miles, I would still run the FL-Xied-10.
12-02-2012, 09:50 AM
#3 |
Oddometer: 17,983
Get a screaming Eagle race tuner and have the values in your ECU adjusted (remapped) Then put the race tuner back in the box and save it for next time you make a change.
This way there is nothing on the bike that wasn't there before... Nothing spliced in to trick the system that might be susceptible to heat/vibration. If you don't have a good tunrer in your area you can purchase a map from Mike Stegmann at Team Latus. Google him up.
"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." — Dr. Seuss “Watch out for everything bigger than you, they have the "right of weight" Bib |
12-02-2012, 10:18 AM
#4 |
Scofflaw
Oddometer: 152
Dynojet Power Vision isn't spliced on. You can flash the ecm with new program and remove the tuner. Original factory map is stored in tuner, you can restore stock map at anytime, doesn't leave a footprint. (ECM appears stock after restoring original map.)
Power Vision has self/auto tune capabilities that require connection to ecm until auto tune is completed. Power Vision can be mounted to bike and connected if you want to monitor the engine, but isn't necessary for simply flashing the ecm. Power Vision reads and clears fault codes. Fuel Moto provides custom PV maps as well as the Power Vision tuner. |
12-02-2012, 11:12 AM
#5 |
Oddometer: 17,983
12-02-2012, 11:28 AM
#6 |
Oddometer: 566
Nothing beats a real tuner and proper tune.
I've forgot more than you kids ever knew! Retired and living off the interest on the money I owe. |
12-02-2012, 12:15 PM
#7 |
Iron Collector
Oddometer: 229
How very true! But you can rack up a substantial bill with the needed dyno time. If your just doing the basics (pipe/air filter) and want to adjust EFI mixtures and not looking for the last few hp/tq then this is the best bang for the buck IMO: http://www.patriotpipes.com/controller.html
Life is short, don't waste it....now get out there! |
12-02-2012, 02:21 PM
#8 |
honestly
Oddometer: 2,257
Jeezaloo tho, that powervision is $469
SERT is $250 Xied $100 Whats the benefit of the PV? I'm not looking for top performance numbers, well I mean I'd like them but can't afford it. I want to switch out my pipe, (because seriously have you heard a stock switchback?) and would like to eliminate the stock lean conditions too. Going to get rid of that AC at some point, but that's mostly a cosmetic call and may be pushed to the wayside for a bit. I'm crazy new to this crap. I'm a carb guy for sure. Any help appreciated.
12-02-2012, 06:47 PM
#9 | |
Iron Collector
Oddometer: 229
These things are pretty much idiot proof.
Life is short, don't waste it....now get out there! MitchG screwed with this post 12-02-2012 at 06:52 PM |
12-02-2012, 07:10 PM
#10 |
Oddometer: 418
Xieds eliminated 90 percent or more of the nagging ping associated with the stock set-up on my 2012 Ultra. A tuner and a good map could do more, I know.
My $ .02 |
12-03-2012, 03:33 AM
#11 |
Oddometer: 294
I put them on my stock 07 Sportster 883 and they work very well. Prior to the XiED 14s the bike really didn't like running below about 60kmh in 3rd, 80 in 4th and 100 in top and vibrated badly over 110kmh when the throttle was opened up. With the XiEDs it immediately ran a lot smoother, 4th was useable around town and top was smooth over about 85kmh. I then put on a set of SE2 exhausts that I had made some new (slightly more restrictive) baffles for and did the air filter conversion. It is now very smooth, top is OK from about 70kmh, no lugging or shaking etc, it is smooth at 120 and runs to about 140kmh before the vibes start kicking in again. Plug colour is fine, fuel mileage is slightly better as it is now happier in higher gears at lower speeds and it has made the bike a lot nicer to ride. I have a tacho on mine and it is smooth in 4th and top from 2000rpm up, and will accelerate from those revs without any lugging. They only affect the closed loop fuelling, but that's where the engine spends a lot of time. Worth a try for $100 and you can always sell them on if you don't like them.
12-03-2012, 04:49 AM
#12 |
Oddometer: 4,314
SERT,TTS or Thundermax and a proper dyno tune by a reputable tech. None of them cheap but neither was the bike. All the others are simply piggybacks that eventually cause problems or fail altogether. If you have to save and put off the pipes do it. The reward is worth the wait.
The paradigm of "why do it right when I can do it cheap" is a false economy. They run so much better with the O2 sensors and a proper tune. Performance is far more than a big peak HP number on a chart. Why buy a top shelf bike and cheap it out? I'll never understand that.
When injustice becomes law,resistance becomes duty. Thomas Jefferson |
12-03-2012, 07:36 AM
#13 | |
Oddometer: 266
They are hard to beat for the price. They do work, and improve roll on throttle & drive ability. Plug color is better. I never noticed any change in gas mileage with the XIED's installed. I noticed the biggest difference when I put in NGK Iridium plugs along with the XIED. It made the bike come alive and really gives it some jump. Search out Iridium and Harley on the web and there is some info on running these plugs. They ( Iridium plugs ) do affect how the Delphi ignition system works, its basically the same as installing Harley's Screaming Eagle plugs. What's happening is the Delphi ignition system is designed to run with the stock Harley plug and nothing else, so it expects to find a certain reading from the plug when an engine knock ( pre-ignition ) is happening and it will retard the timing. With the Iridium or any other plug they operate at a fixed 5K ohm resistance and that will affect how the ignition system works. I think the XIED's for the price and ease of installation etc are really the way to go. I would even try them and the Iridium plugs together before you did anything else. I think you'd be pleasantly surprised. Bang for the buck is high for this set up. If you haven't been to the XIED site yet they do have some good info. Lots of choices out there when you are looking a fuel management systems and good luck in your quest.
1971 R50/5 Cafe Project 2008 Heritage Softail |
12-03-2012, 08:48 AM
#14 | |
bam-a-lam
Oddometer: 1,839
I used the SEPST...newest version of the Screamin Eagle Pro (race version) Super Tuner on '12 Road Glide after swapping the OEM header with catalytic converter to a Fuel Moto 2-1-2 non-cat header with Supertrapp slipons and AE Air Filter kit. The newer version has a SmartTune feature that allows the owner/rider to semi fine-tune after downloading a pre-programmed map based on modifications. The SmartTune allows one to get a better tune than the downloaded map without the cost of a dyno tune and you do as many SmartTune runs as you want. It certainly won't get the same result as a dyno tune but should be much closer to ideal than the pre-programmed download map. I picked up an '09 XR1200 two months ago and went the less expensive route with the Patriot Top Fueler and while it seems to work well I am having low rpm stall issues. I didn't want to spend too much on this bike but bite the bullet and ordered another SEPST. I really don't like the idea of a piggy back system and figure I can more accurately tune the XR using the SmartTune function....and the beauty is with either bike if I make more radical changes I can re-tune at any time or just take the bike in for a real dyno tune as long as the dyno operator is familiar with the SEPST. Hopefully I can re-sell the PTF and recover some of my expenses....but like everything else, if you spend the extra money up front and do it right the first time you usually come out ahead.
'12 H-D Road Glide Custom '09 Suzuki DR650 '09 H-D XR1200 |
12-03-2012, 09:02 AM
#15 | |
Oddometer: 510
Thanks for the info. What are the real-world riding changes with the SEPST in? In most of the harley forums, guys post their dyno sheets...and nothing else. I don't ride a dyno. Is mpg much different? Pinging? Noticible power? Throttle response. In my stock 103 2011 the only thing that bugs me is high altitude pinging under moderate throttle...esp. with low grade gas. Going up mountain passes I make sure I use 93 octane. Seems to help. Cakeeater |
