Old 12-01-2012, 12:08 PM   #1
mtiberio OP
mtiberio's Avatar
Oddometer: 86
Lester Mags, making them tubeless
I just picked up a Guzzi G-5 (949cc, 5 speed) that is fitted with Lester Mags. I can't see paying the weight penalty of mags, and not having them set up for tubeless.
Has anyone ever set up a late 70's early 80's set of Lester Mags for tubeless operation?
I have converted many a set of the standard Guzzi cranked spoke mags of that same era. Since the inside had no flat machined around the stem hole, I always simply tapped the hole for a 1/8 pipe thread, and fit a tank valve. Works amazingly well. I'd prefer to not tap the Lesters,
Does anyone know of a tubeless valve stem that works in the Lester Mags?
Thanks,
Mike
mtiberio is offline   Reply With Quote
Old 12-01-2012, 02:10 PM   #2
shaner1100gs
Oddometer: 72
Thanks,
Mike
Here you go. https://www.denniskirk.com/parts-unl....prd/54155.sku
I think I used these on my Lesters on my 77 R100S.
Shane
shaner1100gs is offline   Reply With Quote
Old 12-01-2012, 04:53 PM   #3
mtiberio OP
mtiberio's Avatar
Oddometer: 86
Thanks... I assumed the inner surface of the rim was curved, and that normal flat rubber washers on these type of stems wouldn't seal. But there it is in the description... fits lester... thanks again
Times are GMT -7.   It's 11:11 PM.
