12-18-2012, 07:05 PM
#16 |
Trustin' my cape...
Oddometer: 512
A quick update. This little unit list on Bike Bandit for a not-so-thrifty $41. I ordered one today from the local bike shop and was told thanks to Saint Nick's trip through town, it won't be in until the week of 1/8/13... at least I can get it... why didn't I just cut the petrified fuel line?
Pulled the carbs out of the PS and SafeTKleen last night and reassembled one of the carbs. Everything looks good, hope to post some pictures in the coming days... |
12-18-2012, 08:14 PM
#17 |
Oddometer: 166
What I learned was that the careful use of an electric heat gun helps loosen stuck nuts, screws, and especially soft things like fuel lines and gaskets. You don't have to cook them, just get them good and warm and old brittle fuel lines come off much easier. I put penetrating oil on stuck fasteners and then heat them until the oil evaporates, then let it cool and do it again, a couple of times, and things do unscrew. If you buy new old rubber bits a little heat makes them soft enough to flatten out wrinkles and get them to sit flat.
Enjoy! |
12-18-2012, 08:30 PM
#18 |
Trustin' my cape...
Oddometer: 512
Excellent, thanks! My mindset is still with modern, worked-on-a-lot dirtbikes. I'll be way more careful in the future but I seriously had no doubt it'd be that brittle.
I read somewhere that boiling (?) rubber boots in wintergreen will restore a little rubberocity to old stiff rubber. Anyone have any advice pro or con? |
12-19-2012, 11:55 AM
#19 |
Oddometer: 25
I am parting one of these bikes out, so if you need any parts, let me know!
2000 Suzuki SV650N, 1991 Yamaha TW200, 1993 Honda CR250, 2004 Honda Crf-50, 1986 Yamaha Bw80 (x2), 1999 Yamaha BWS-50 Zuma |
12-22-2012, 04:04 PM
#20 |
Trustin' my cape...
Oddometer: 512
12-23-2012, 04:24 PM
#21 |
AKA Walter Mitty
Oddometer: 1,311
I like this thread. My bike is an 85 750s, the Canadian version of this bike in red and black. I wanted the black and blue, but beggars can't be choosers.
Purple Monkey Dishwasher |
12-24-2012, 09:25 PM
#22 |
Trustin' my cape...
Oddometer: 512
Got a working neutral/shift switch? Mine appears non-funct. I need to pull it and see if there's any rebuild potential but a cursory ohmmeter exam today indicated it was open. Could just need cleaning but I thought I'd touch base and see if you have one just in case...
12-31-2012, 08:52 PM
#23 |
Trustin' my cape...
Oddometer: 512
Today - that pesky gear switch selector! Previously I'd checked the switch for continuity and discovered all contacts were open and indicated a required removal for inspection. In true Murphy's law fashion, the bottom left mounting screw didn't just pop out. The kickstand and shifter needed to be removed so I could get an impact driver on the stubborn screw. Of course, removal of the sidestand and shifter did nothing to ease access to the buggered screw. The spring mounting post is the problem and it's welded to the frame. Oh well, looks like it needed cleaning anyway...
![]() After a couple of false starts, I was able to get the screw out and the switch removed. When I pulled the pickup out of the cavity, the problem was pretty evident. Looks like I got one too many pieces: ![]() Not only was the post broken, but the wiring inside was buggered as well. Looks like it's been broken for while... ![]() So, I've got the carbs out and awaiting a replacement for the clay gas tee and now I need to order a replacement gear indicator switch... remembered the side stand looked like it needed cleaning. Scrubbed it up in the parts washer, and immediately feel like I've accomplished something! I can't fix anything to so crank up the tunes and find some rags! Time to clean! Something about working on a dirty bike kinda kills the mood. A good cleaning will really tell me what I've got...and. . I was stoked by what I found, the bike has excellent bones. Patinaed bones, but excellent bones nonetheless. A few teasers: Before: ![]() Afters: ![]() ![]() ![]() Lastly, as the day grew to a close and I had a couple beers.. ![]() There are 576 1984 Nighthawk CB700SC items for sale on FleaBay today. Not a single one was a gear selector switch or a replacement fuel line T. This indicates a surplus of gorilla 700SC mechanics and perhaps a faulty design. Lastly, a first. SILTHW count today = 0 Happy New Year YFF's! |
12-31-2012, 08:58 PM
#24 |
Nanu-Nanu Adventurer
Oddometer: 7,019
I have no idea if yo will run into this or not, but I will share my grief. My 84 ran fantastic over about 3000 RPM but misfired badly below that. After months of doing this and that I found one of the coils to be bad. Just a heads up. GOOD for you bringing it back to life.
![]() Marc
04 R1150RT,06 KTM 450EXC, 84 R100RS LE, 89 XL600V, 2012 Stelvio, 72 Guzzi Eldorado http://s22.photobucket.com/albums/b327/lomaxcm/?sc=3 |
12-31-2012, 09:10 PM
#25 | |
Trustin' my cape...
Oddometer: 512
In any case, thanks for the heads-up! We should have a beer when I get the 'Hawk roadworthy. Merfman screwed with this post 12-31-2012 at 10:03 PM |
01-02-2013, 02:49 PM
#26 |
Oddometer: 2,001
Where are you guys getting parts. Does Honda stock any oem parts like the complete sticker sets? I picked up an 85 700SC yesterday!
with his videos I've been able to crash into trees even faster than before. ( Darius re Shane Watts) |
01-02-2013, 03:17 PM
#27 | |
Oddometer: 334
http://www.cbdecals.afegraphics.com/...ing=&cat_id=23
07 Bandit 1250 00 ZR7 97 DR350 93 DR350 86 Nighthawk 700s (Red, White,Blue) |
01-02-2013, 05:49 PM
#28 | |
Trustin' my cape...
Oddometer: 512
For parts, I've been getting everything I needed from the local bike shop. Been lucky so far. Some things aren't available. Bike Bandit and eBay are resources as well... Also, for full immersion in all things Nighthawk, head over to www.nighthawk-forums.com, great resource and good guys. Some very nice builds too! Merfman screwed with this post 01-02-2013 at 08:49 PM |
01-02-2013, 06:14 PM
#29 |
full-time fool
Oddometer: 42
FYI on the gear switch, I got lucky finding one for my Yamaha by taking the old one to a friendly, old-skool, 4 wheeler shop and comparing them. Found one in their old stock that fit my bike from off a similar vintage four-wheeler. Oftentimes the manufacturer would just order a huge batch of them and use them for everything but slap different part numbers on them for 2 wheels or 4 wheels, but same bit of metal. I know Honda used similar seals between marine and terrestrial motors... Dunno if this helps you, but one more avenue to check.
In less than optimal circumstances, creativity becomes all the more important. |
01-03-2013, 06:34 AM
#30 | |
Trustin' my cape...
Oddometer: 512
