Old 06-21-2005, 12:25 AM   #1
scottw OP
Steppe Rider
scottw's Avatar
Oddometer: 291
Bluhduh Broke my R100 GS subframe. Again.
Ok, second time in two years for my R100 GS ('89). This happened last year and I had it welded back together. Anyone know of any sources for a reinforced subframe? I'll have this one welded again here, hopefully with some bracing, but I'd like to just get one made by someone who knows what they're doing.
And don't point me to HPN, I don't have that kind of $$.
All other ideas appreciated.
Here's the left side:
And here's the right:
scottw is offline   Reply With Quote
Old 06-21-2005, 12:58 AM   #2
Gusgus
Gusgus's Avatar
Oddometer: 5,308
Well I can see one trouble with your repair.
I am an aircraft mechanic and have been welding frames for aircraft (supercubs) for years.
The weld or repair actually caused it to break.
Here is why.
In a crack across the tube (like your tube) the repair isn't going to be as strong as the old tube without additional metal added and in a far different place than the crack. In other words there should have been triangle plates added after the tube was welded. Added over the weld. Then made sure they fit well and welded also.
If done as shown here .....
http://www.airweb.faa.gov/Regulatory...apter%2004.pdf
Page 4-67
It will not crack ever,,,, again.
The trick is a great fit prior to welding. Then a great weld is also essential.
The weld done on the first break could never have lasted. It actually creates another break just from the stresses at the repair.
Good luck.
Gusgus is offline   Reply With Quote
Old 06-21-2005, 05:28 AM   #3
BWalker
BWalker's Avatar
Oddometer: 176
Would it also work if you put a solid steel rod inside the frame before welding?
Bob
'13 Super Tenere
'00 BMW K1200LT Trike
Pittsburg,Tx
BWalker is offline   Reply With Quote
Old 06-21-2005, 08:25 AM   #4
moosehead
moosehead's Avatar
Location: south of the checkerboard....Bruce Penninsula
Oddometer: 276
These guys make some heavy duty subframes for the R100GS.
www.overland-solutions.com
From the UK but from the pix you get an idea of what they're doing.
moosehead is offline   Reply With Quote
Old 06-21-2005, 10:05 AM   #5
Gusgus
Gusgus's Avatar
Oddometer: 5,308
Yes it would work if a solid rod was inserted. But first a few holes would need to be drilled in the existing tubes for an external attachment of the internal rod to the exterior tube.
The welds then are called "rosette" welds The holes are filled with welding material.
This method is good if a rod can pass through enough of the existing tube. It is strongest if it can travel a minimum of 3 times the tube diameter into each end for strength.
Old 06-21-2005, 10:22 AM   #6
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,963
extra big girlfriend on the back or something?
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 06-21-2005, 12:02 PM   #7
Brick
Oddometer: 154
subframe
Scott,
I purchased a whole subframe assembly from Ernie at Overland Solutions. It is a work of art. The fit and finish is incredible and it is fitted out with my choice of TT panniers, but they will fit out just about any brand of pannier available.
The down side is of course, is cost.
I refit my R100GS for an africa trip to avoid exactly the problem you have experienced. There are also a number of people that have done basic re-inforcemnt jobs onn the stock subframes and have been very successful. Look for articles by Dr. Greg Fraizer (sp). He has done modifications for very little $$ and they are with in the technical ability of just about anyone.
Good Luck
Brick
Brick is offline   Reply With Quote
Old 06-21-2005, 04:59 PM   #8
scottw OP
Steppe Rider
scottw's Avatar
Oddometer: 291
Thanks for the advice guys. For repairs it sounds like I need a much better welder than the Mongolian guy down the street, but unfortunately he's all I have for the moment.
I will check out the overland solutions people and see if they can set me up with one of theirs.
-Scott
Old 06-22-2005, 07:58 AM   #9
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,420
-Scott
I had Ernie (Overland Solutions) build me a custom rear frame, racks with fitted TT bags. I love it. It'll be the last thing on the bike to break. Here are some pics. This was about 3 years ago. I think I was his first customer. We had two identical sets made for a world tour.http://tinyurl.com/6gymm
Back in YVR after riding around the world for 2 years. www.nohorizons.net
Malindi is offline   Reply With Quote
Old 09-30-2005, 11:02 AM   #10
bcostell
Oddometer: 192
Here's some photo's of how I've strengthened up the subframes on my bikes:
http://bcostell.smugmug.com/gallery/846325
bcostell is offline   Reply With Quote
Old 09-30-2005, 11:52 AM   #11
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,044
Any chance you retained the pattern to reproduce the reinforcement pieces you made? I'd love to make sume myself!
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 09-30-2005, 12:12 PM   #12
ChuckTaylor
I digress
ChuckTaylor's Avatar
Oddometer: 217
subframe
I have a "spare" R100GS subframe for sale if anyone is looking...
Shallow men believe in circumstances - it was somebody's name, or he happened to be there at the time, or it was so then, and another day would have been otherwise. Strong men believe in cause and effect.
Ralph Waldo Emerson
ChuckTaylor is offline   Reply With Quote
Old 09-30-2005, 10:25 PM   #13
bcostell
Oddometer: 192
Sorry, didn't make a pattern, didn't think of that (duh). The material I used was 1/8"Thk x 1.5" Wide. I think the stock side frame a bit more than half that thickness.
Old 10-03-2005, 04:11 PM   #14
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,044
Thanks for the thought, I'll use your photos and wing it from there!
R65LazaruS
Times are GMT -7.   It's 10:38 AM.
