Old 12-01-2012, 08:32 PM   #1
wantok OP
Oddometer: 164
need advice on symptoms - too lean or rich?
Hi people - need some advice on the following symptoms: I live in an area that is currently very hot & humid (close to sea level) My 950 ADV (2004) has stock carby jetting & 2 wings open mufflers. The hotter it gets, the worse the bike runs. It idles but has a big flat spot below about 3500 rpm, where on a steady throttle it misses a bit. It also backfires a bit on the overrun when you crank down a couple of gears. When the weather is cooler it runs better, without these symptoms. Whenever throttle opened right up, it runs fine regardless. Ive got a facet fuel pump & DNA air filter & run the bike on 98 octane.
Do these symptoms indicate too rich or lean?
Many Thanks
Nick (wantok)
wantok is offline   Reply With Quote
Old 12-01-2012, 09:13 PM   #2
Deepc
Oddometer: 299
Sounds lean to me. Stock jetting with a open wings exhaust! Also, Check for the usual vacuum leaks. Also, think about installing a second fan to cool her down. I have the black dog cycle works version and it makes a big difference in traffic.
Deepc is offline   Reply With Quote
Old 12-01-2012, 09:33 PM   #3
Deepc
Oddometer: 299
And pull your rear plug. It's easy to get to and it will tell you what your looking for.
Old 12-01-2012, 11:02 PM   #4
AdvGa
AdvGa's Avatar
Oddometer: 1,320
You may want to check some of these things:
1- Check your Battery (under a load tester)
2- See if your Carbs are Vented with the 10" Rear, 11" Front hoses and not the Running together in the Y configuration.
http://www.advrider.com/forums/showp...98&postcount=8
3- See if your Fuel is not Boiling -insulated Tanks
-Have you done the Flapendectomy?
http://www.ktm950.info/how/Orange%20...endectomy.html
- Also Run a Fuel Treatment -like SeaFoam
http://www.seafoamsales.com/gasoline-engine-faqs.html
AdvGa is offline   Reply With Quote
Old 12-02-2012, 05:58 AM   #5
akarob
Green Cantern
akarob's Avatar
Oddometer: 7,630
Precisely. Your spark plugs will tell you what's going on. A correct mixture will show as a light tan on the plug. If it's white and kind of burnt looking, it's lean. If it's wet and dark, it's rich.
akarob is online now   Reply With Quote
Old 12-02-2012, 07:51 AM   #6
StmbtDave
AKA Invisible Dave
StmbtDave's Avatar
Location: Loveland, CO summer - Green Valley, AZ winter
Oddometer: 2,989
I would say lean. We come to Arizona for the winters to get out of the Colorado cold. It's a lower elevation and much warmer here. My 950 goes through the exact same symptoms you are having and I found simply raising the needles one notch smooths it out. Of course anything involving the carbs can't be done "simply".
Dave
Why are we stopping? We don't have time for that!
StmbtDave is offline   Reply With Quote
Old 12-03-2012, 11:27 AM   #7
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,136
Lean?
I'm no carb man, but to me, running better when cold than when hot sounds like a rich condition.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 12-03-2012, 11:58 AM   #8
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,094
Originally Posted by wantok View Post
My 950 ADV (2004) has stock jetting...wings open mufflers...DNA air filter...
She's lean. Raise the needles one clip position and turn the fuel screws out to 2.5 or so...hang on tight.
2005.5 KTM 950 Adventure
2005 Ducati ST3
Chuckracer is online now   Reply With Quote
Old 12-03-2012, 12:15 PM   #9
MortimerSickle
Semi-Adventurer
Oddometer: 12,136
Originally Posted by Chuckracer View Post
She's lean.
I think that every time I learn something about carbs, I end up knowing even less than I did before.
G.H.W.S. 1878-1962
Old 12-03-2012, 02:43 PM   #10
wakked1
Aspiring Itinerant
wakked1's Avatar
Oddometer: 62
Hmm, everyone seems to have missed the temperature reference. The hotter it gets the less dense the air, so the higher the fuel/air ratio gets. If it runs fine in cold temps but rough in hot, it would suggest its running rich.
wakked1 is offline   Reply With Quote
Old 12-03-2012, 02:47 PM   #11
MortimerSickle
Semi-Adventurer
Oddometer: 12,136
Not everyone.
Originally Posted by MortimerSickle View Post
... running better when cold than when hot sounds like a rich condition.
G.H.W.S. 1878-1962
Old 12-03-2012, 11:54 PM   #12
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,925
And the answer is: rich. Cold = needs more fuel to run good. Hot = needs less fuel to run good. You need to lean it a little when it's hot out.
Pull the carbs. Check the float levels, set them 1/2 mm lower (leaner) than stock. I remember the setting is 3.0mm from gasket surface, so set them to 3.5mm. If they are warped, one is lower that the other, then do the best you can.
Buy and install the remote fuel screws. This allows you to set the idle-1/4 throttle mix as the conditions change. All bikes are different, some like 1.0 turns, some like 3.0 turns. These are an awesome addition.
With the open exhaust, you only need to increase the mains slightly, go up one step only. But, this is not needed if it's really hot and humid.
Set the throttle sensor to the correct voltage at closed throttle. I don't remember the value (0.6v?) If this is off, it can create that big flat spot at 3500 rpm.
Are the valves in spec? It will effect the mix also. Tight = leaner, loose = richer. It's a very small change unless the valves get very tight.
Good luck. dz
"Son, you can't do both"
Old 12-04-2012, 12:17 AM   #13
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
if stock jetting and no other modifications I would baseline verify that all of the jets are clean and float heights are set correctly. THEN test and re-jet if necessary.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 12-04-2012, 06:42 AM   #14
wantok OP
Oddometer: 164
Thanks for the advice
This is good stuff - thanks people
Nick (wantok)
Times are GMT -7.   It's 12:01 PM.
