Old 12-02-2012, 07:07 PM   #1
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,124
Dirt Floor Leaner
I started pivot brackets over Thanksgiving holidays and got the frame together yesterday and this morning. I would of worked on it during the week but I had to wait for the heim joints to come in before I could continue. This afternoon I took a test ride with a solid mount axle.
It works but I am going to move the pivots lower and more centered.
I did prove to myself that it will work for what I want.
I should get a lot less movement after changing the mounts.
In the stable now. '76 Moto Guzzi Convert Hack
'93 Moto Guzzi Calli 3 with Leaner turned rigid
Hack build: http://www.advrider.com/forums/showt...rt+floor+build
cleatusj is offline   Reply With Quote
Old 12-03-2012, 01:02 AM   #2
Pete-NZ
Pete-NZ's Avatar
Oddometer: 731
put the pivots on the centre line of the bike... with the front mount higher than the rear..that way the car will steer into the corner as the bike leans..but if the car goes up or down over bumps it will not steer...
theres a link to one of my leanner builds below....
Here.... my XR250 leaner side car build
http://www.advrider.com/forums/showthread.php?t=716993
Pete-NZ is offline   Reply With Quote
Old 12-03-2012, 04:01 AM   #3
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,124
Thanks Pete, I've read that and most every other thread on this and several other sites many times. I was hoping to keep some ground clearance but that will be reduced as it has been proven to me the reason to be centered with the pivots.
I will not have to rework the main frame as the axle mount is clamped on at this time. I will be loosing the center stand so that the rear mount can move toward center and the front bracket will en-circle the fowrard facing oil filter.
Old 12-03-2012, 04:03 AM   #4
Hellracer.nl
What the hack???
Hellracer.nl's Avatar
Oddometer: 406
I agree. Pivot point in centre line and the frame will stay much more horizontal. I've got a simple homebuild leaner as wel. There should be a thread somewhere on this board.
Found it:http://advrider.com/forums/showthread.php?t=836987
To beer or not to beer, that's no question.
My Leaner build: http://advrider.com/forums/showthread.php?t=836987
Hellracer.nl screwed with this post 12-03-2012 at 05:47 AM
Hellracer.nl is online now   Reply With Quote
Old 12-03-2012, 04:11 AM   #5
Precis
Maladroit malcontent
Precis's Avatar
Oddometer: 3,625
That works on something like the hybrid Armec Sidewinder, but at the cost of ground clearance; hybrid in that the bike leans but the sidecar doesn't.
On the fully-articulated Flexit, the mounts are off to the side and there is no loss of clearance.
I'd be very concerned by the camber-changes in the sidecar wheel your mock-up is showing.
"I would like to die on Mars; just not on impact." Elon Musk
Precis is offline   Reply With Quote
Old 12-03-2012, 06:03 AM   #6
Unstable Rider
Fart and run
Unstable Rider's Avatar
Oddometer: 2,503
Neat idea, I will give you that.
I am new to the ways of sidecar thinking, it's on my shopping list for 2013, so I am pretty much in the lurking stages so I thought I would stop and peak..
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline   Reply With Quote
Old 12-03-2012, 08:11 PM   #7
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,124
I'm going to loose a lot of ground clearance by moving the mounts to center line but I believe there will be less camber changes and that is a good thing. I also loose my center stand as that is where the rear pivot bracket will mount.
My biggest problem is that dam oil filter dead center front.
Thanks for all tips and concerns, as I have plenty of room to learn and question my thoughts.
cleatusj screwed with this post 12-03-2012 at 08:25 PM
Old 12-04-2012, 04:16 AM   #8
Precis
Precis's Avatar
Oddometer: 3,625
With a Cali, you don't really need a centre-stand - the sidestand you have is the envy of the entire planet!
How about fitting an old-style sump that has an internal filter - PITA at service-time I know, but it will allow you to put the front pivot where you want it.
Do a search on Armec Sidewinder-equipped Guzzis & you'll see how they do it.
Old 12-04-2012, 11:37 AM   #9
arbalest
Oddometer: 50
leaner sidecar wheel toe
Does the sidecar wheel on a leaner require toe in or out?
arbalest is offline   Reply With Quote
Old 12-04-2012, 04:57 PM   #10
Hellracer.nl
What the hack???
Oddometer: 406
I've tried toe-in and toe-out but currently my set up is pretty neutral.
I like to drive at higher speeds (+140kmh = 87mph ) and that works better with a neutral set up.
Old 12-04-2012, 08:07 PM   #11
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,124
After work today I got the front mount worked out and it looks like I'll have 5 inches of ground clearance.
I removed the center stand and will need to bend a piece of 1" bar to get a saddle under the exhaust and extend 5 inches. I still need to build a swing arm and turn a spindle.
Old 12-06-2012, 07:32 PM   #12
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,124
I got the mounts worked out and there is very little change it the frame level when leaned to each extreme.
Now back to my swingarm design.
Old 12-09-2012, 12:38 PM   #13
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,124
Still haven't build a swing arm as I have not found a scooter or moped wheel, but I did strap on a 8" trailer wheel and put it thru the a good run for 20 miles, up to 80 mph with no problems.
Old 12-10-2012, 04:31 AM   #14
Hellracer.nl
What the hack???
Oddometer: 406
This calls for photographic proof!
If it holds for 20 miles , it will probably hold for much longer too. Why not keep the 8" wheel?
Old 12-10-2012, 06:56 PM   #15
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,124
Hellracer, there wasn't much to show as the half axle is only u-bolted on, but here it is as ridden,
If I use this wheel I'll need to buy an axle stub and hub that is lighter than the 3500 pounder.
Also I would like to know how well your first shock design worked?
Times are GMT -7.   It's 02:43 AM.
