Old 03-15-2013, 10:53 PM   #61
Beezer OP
Oddometer: 5,742
somebody asked me when I know that I am done with a piece of work, or how do you know what direction to take on a certain bit....
simple answer is.... when I look at it and laugh... that's it
Beezer screwed with this post 03-23-2013 at 11:30 PM
Beezer is online now   Reply With Quote
Old 03-15-2013, 11:22 PM   #62
MisterShandy
Oddometer: 85
This is really awesome.
MisterShandy is offline   Reply With Quote
Old 03-23-2013, 09:10 PM   #63
Beezer OP
Oddometer: 5,742
almost done. the stained glass windshield isn't working out as hoped so it's off to the back burner & a plain one goes on at least for a while.
finally got the saddle bags the right color & mounted them today:
the fuel strainer, tap, & lines are done too:
looks like I need to shorten the plug lead so it goes in front of the fuel line.
waiting on some materials to etch the data plates... and thats the last project
Old 03-24-2013, 04:50 AM   #64
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,158
Wicked!
My KLR650
Matt's Trippin' in Peru
sandalscout is offline   Reply With Quote
Old 03-24-2013, 06:34 AM   #65
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,647
How about a tutorial on how you are making/modifying this stuff? I diggit just wondering a bit more about how things are modified, where you are buying this stuff etc.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 03-24-2013, 11:58 AM   #66
Beezer OP
Oddometer: 5,742
the copper and brass are fittings from either plumbing or welding fixtures. a lot of the stuff is too big so it is turned on the lathe, cut filed, etc for a fit. for instance on the fuel strainer thats 1" copper pipe with an end cap, and a 1" x 1 1/4 " adapter. the fittings were cut so there is only about 20% left, then assembled with solder. the fitting that goes into the carb is an old valve guide soldered to a 90* compression fitting. the top of the fuel filter is actually 3 pieces of brass soldered together (10 pieces total to build the whole strainer)
the copper exhaust... same deal, just bigger parts. well... I had to cut & solder strips for the brackets and build a tool to flair the exhaust ports, but it's all plumbing stuff. actually, some of the exhaust is copper braze not solder (special rod).
the turn signals were made from turn of the century chandelier parts along with some antique aircraft parts and some Salvation Army glass candle holders. the holders were cut down and then stained.
the tin work on the tank & cowl is welding and riveting. paint is... painting. all that is just work & knowing how to fix your mistakes
dunno... anything somebody really interested in I could prolly do a blow by blow. thanks for the interest
Beezer screwed with this post 03-25-2013 at 03:29 AM
Old 03-24-2013, 12:54 PM   #67
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,431
Beezer, ya crazy mo-fo. I assume this is headed to the bike show next month? Don't forget to bring some Brasso!
Tom S is offline   Reply With Quote
Old 03-24-2013, 03:27 PM   #68
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Is the issue with the stained glass that it breaks apart with the motorcycle vibration?
If that is the case, maybe using a clear epoxy and sticking the colored glass pieces to a piece of clear acrylic, or plexi windshield might work?
If not, what is the issue with the SG?
Cool idea that I would love to see on the bike.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 03-24-2013, 04:15 PM   #69
Beezer OP
Oddometer: 5,742
I cut into the plastic to make room for the baubels (cut glass diamonds, etc) & foiled all the edges. well when you get all that hot enough to solder it works for a while.... then expansion starts putting hairline cracks the plastic. right from the start I did as much of the soldering as I could before inserting into the plastic & tried to work small bits at a time but can't stop it. I covered some, but it stared to look too crappy..... (not laughing.... thats the signal to go a different way). I think I can do it but will have to start from a different angle. I havn't given up totally yet, but as Tom S noted... the bike show looms & I want it to be in there.
Old 03-24-2013, 05:43 PM   #70
schnutzy
schnutzy's Avatar
Oddometer: 395
what did you do for stuff like the valve covers, and other little engine bits to give them a copper appearance?
"While it may be to early to drink scotch, it is never to early to think about drinking scotch."
2012 Suzuki TU250x
schnutzy is offline   Reply With Quote
Old 03-24-2013, 09:15 PM   #71
Beezer OP
Oddometer: 5,742
I got some Caswell stuff & plated the covers.... it's ok but not great. the radiator cover and most of the nuts & bolts that look copper were soaked with a copper sulphate solution you can get at stained glass supply. it actually puts a plating of copper on lead, steel, and even some stainless. it reacts with zinc & cad plating though & turns black. the plating has to go before you get the copper look. I've been burning it off & hitting it with the wire wheel (obviously, do not breathe this stuff) actually, you can just soak it & keep buffing it until the copper takes. then polish it with some Mothers billet polish...
I always tried to use brass hardware when possible but it is getting harder to find... it's all turning to plated steel, and I don't think the plating is even brass because it looks wrong. BTW, there is no metric brass. I converted to SAE where possible & helicoiled the brass dome nuts where metric was required
Old 03-25-2013, 12:20 AM   #72
Texas Aggie
Texas Aggie's Avatar
Location: Nanjing, China and sometimes..... Dallas, Texas
Oddometer: 103
One word says it all about this project........"cool"!
Regarding the Stain Glass windshield, if that does not work out, perhaps you might consider looking at some old cab forward steam train windshields for inspiration in a different direction.
http://www.trainweb.org/oldtimetrain...connaught4.jpg
I thought of the train on the right when I saw your headlight setup photos.
DT
Keeping the rubber side down........most of the time!
Texas Aggie is offline   Reply With Quote
Old 03-25-2013, 03:34 AM   #73
Beezer OP
Oddometer: 5,742
even with a plain windshield it looks very "train" (no pix sorry). thats what I'm going with unless events align and I can do a decent stained glass look
Old 03-25-2013, 02:39 PM   #74
Yooper_Bob
Yooper_Bob's Avatar
Oddometer: 2,719
Really cool!
Can't wait to see the finished bike.
Yooper_Bob is offline   Reply With Quote
Old 03-26-2013, 11:02 AM   #75
kellymac530
motorcycle addict
Oddometer: 1,052
I have one last idea on the Stained Glass if you do not mind...
I LOVE that idea, so I hate the thought of giving up on it. Maybe later, after this bike show, you could play with a JB weld type of gray epoxy to attach the colored baubles into the plexi/acrilyc/lexan windshield.
That would still give a gray colored, kind of solder look but not require the heat that cracks the wind screen...
Maybe mask up all of the baubels and plexi to keep the JB lines fairly straight, pull the tape before it sets fully hard...play with some test samples?
Not trying to tell you what to do of course, just throwing out a thought. The SG would REALLY finish of that look and give it that POP.
Great job Beez!
Times are GMT -7.   It's 12:27 AM.
