Old 03-05-2013, 04:43 PM   #1
Bon Scott OP
Oddometer: 1
Suzuki ts 400
Hi, I have a suzuki ts a 400 1976, and I am not happy.
The question is , is the bike fundamentally flawed or although I think I've tried everything is there a fix , that I haven't.
List :
Rings
Crank seals
2 x carburettors rebuilt
Burnt out exhaust
CID checked
Points and timing
The bike looks very original, but won't run clean top end and misses on quarter throttle.
Any help would be appreciated.
Cheers rob
Bon Scott is offline   Reply With Quote
Old 03-11-2013, 06:00 AM   #2
wfopete
Suffer Fools; Gladly!
wfopete's Avatar
Oddometer: 476
I have one too. Ran better than yours. Are you running premix or injector lube? I just keep with the injector because to bypass it is a hassle. Mine didn't run great but it got the job done. Terrible fuel mileage and the motor ran all over the place from decent to crappy.
Suffer Fools; Gladly!....
RIDING the TAT? CHECK IT OUT: TAT SHAK
ARA - Adventure Riders of Arkansas
wfopete is offline   Reply With Quote
Old 03-12-2013, 08:31 AM   #3
mudgepondexpress
Oddometer: 1,151
Does it stutter on the top end or does is feel fat? Sounds like you need to do some jetting to me. I don't think I have ever seen a 70's 2 stroke from Japan that wasn't overjetted from the factory. If you haven't tried it yet, pick up 1 richer and 1 leaner main jet. Start with the richer (bigger) jet and see if it makes it worse or better, my bet is it will be much worse. If I am correct, go to the 1 step leaner and keep going until it runs out clean.
Once you have the main jet dialed in, then go to work on the pilot and/or needle. I would work the same system on the pilot and see how it affects the bike, then work from there.
Yes, you will have a handful of jets when you are done, but it will feel good when it runs correctly. You will also learn how to pull the carb quicly and how little you need to disconnect to do it. I became quite good at the parking lot pull...leave the fuel line and throttle hooked up, loosen the carb, put a rag under it, pull it out far enough to remove the bowl and replace the jet. All told I could do a Yamaha DT in less than 5 minutes, a XR650L in roughly 8 (by leaving off those ugly scoops).
If the bike is not consistant in its running...sometimes good, sometimes bad, you will need to look at the spark advance system to see if it is operating correctly. I believe this was a common issue to the big ts/tm series (though this is from memory...they could have fixed it by 76).
Kenny
mudgepondexpress is offline   Reply With Quote
Old 03-13-2013, 04:48 AM   #4
Aah5
russ
Oddometer: 59
I had TS400-K back in '75/76 when working at Suzuki dealer, bike was a tradein that had was absolutely gutless 80 kph/50 mph tops.
Picked it up at our traded price and proceeded to make it run properly. Opened up the air box intake vents, rejetted carby, burnt out the exhaust carbon, decoked the exhaust port etc.
Anyway after a lot a fussing around, mainly jetting, in the end I had a TS that was capable of a genuine 160kph/100mph, had a flat torque curve and was an absolute blast to ride on the street not so good on the trails.
Persist with jetting and make it breathe better.
Aah5 is offline   Reply With Quote
Times are GMT -7.   It's 01:25 AM.
