Old 12-03-2012, 08:42 AM   #1
fullmonte OP
Reformed Kneedragger
fullmonte's Avatar
Oddometer: 4,382
Tiger 800XC Tubeless Converts?
For those of you who have converted your rear wheel to tubeless, how has it worked out for you? Pros, cons, leakage issues? Is 3M 5200 fast cure THE sealant to use in this application? Any pointers and input is appreciated.
"If you are looking for the typical ride to a restaurant, eat tacos, hold the middle finger over the food, stop and take a picture of a gravel road type ride, you probably won't be interested." - dlrides
"A guy I know was the lead researcher for the University of Utah federally funded study of cellphone and texting use while driving. He found that your twice as dangerous as a drunk while using your cell phone and I think it was up to six times worse if the driver was texting."-dakardad
fullmonte is offline   Reply With Quote
Old 12-03-2012, 08:03 PM   #2
levain
STILL Jim Williams
levain's Avatar
Oddometer: 5,953
Yeah. What he said
Click Here!
2012 Triumph Tiger 800 XC
1971 Lambretta DL
levain is offline   Reply With Quote
Old 12-08-2012, 09:00 AM   #3
fullmonte OP
fullmonte's Avatar
Oddometer: 4,382
Bump. So far, two inmates have contacted me with positive tubeless Tiger results.
Old 12-08-2012, 12:36 PM   #4
yukonjon
yukonjon's Avatar
Oddometer: 121
What have they used for the conversion?
yukonjon is offline   Reply With Quote
Old 12-08-2012, 07:12 PM   #5
fullmonte OP
fullmonte's Avatar
Oddometer: 4,382
3m 5200 sealant, but I am leaning towards the fast cure 5200.
Old 12-10-2012, 05:20 PM   #6
cyclingtom
Sim Sala Bim
cyclingtom's Avatar
Oddometer: 3,378
Here's a few requested pics from the process with 3M 5200 sealant. Good prep, vinyl tape over the spoke heads, about 1/8" of sealant and a tubeless valve stem. There's not a lot of skill involved, just follow the directions on your sealant of choice.
10k problem free miles and several tire changes on this rear tire 800XC setup. Thinking seriously about doing the front. Some advise against it due to the rapid rate the front might deflate and not having "tubeless lips" on the front rim.
I've had a front puncture with a tube as well as tubeless. I can attest to the fact the front can go down quickly in either case so I may give it a go in the near future.
Inconsequential Adventurer
Upon us all a little rain must fall. L.Z.
cyclingtom is offline   Reply With Quote
Old 12-11-2012, 12:55 PM   #7
X1Glider
X1Glider's Avatar
Oddometer: 205
What about that liquid rubber in a rattle can that we've all seen on TV with the boat with a screen door bottom?
Bob Krzeszkiewicz - 2013 Christini 450E - 2011 Kawasaki Ninja 1000 - 2000 Harley Davidson FXDX - 1999 Buell X1
X1Glider is offline   Reply With Quote
Old 12-11-2012, 09:36 PM   #8
av_mech
Risk Taker
av_mech's Avatar
Oddometer: 1,105
Totally didn't work for me. Did the prep, did the sealant, 1 psi a minute leak after I was done. Took the tire off. The 5200 didn't adhere at all. It all pulled out in one big strip of 5200. It never sealed the rim completely and never adhered to the rim. I should have trusted my gut feeling and just used the pro seal we use in aviation. Maybe with some better prep it would have worked better, but in my experience, I wouldn't recommend the 5200. Back to tubes for me. Maybe a winter project to try it with pro seal.
Some have had great success with this. I would highly recommend taping along the safety lip of the rim. That's the point of contact where the scraper is touching the rim in the above pic. Tape off anywhere you don't want this stuff! It's a bitch to clean.
I'll admit where I probably screwed up. I prepped with Mineral Spirits. Then I realized that leaves a residue. Cleaned the mineral spirits with MEK. Thought I had it all off. Guess not. But it didn't stick ANYWHERE! So I wonder...
2011 Triumph 800 XC
2007 Honda CRF 250X
1994 Kawasaki KLX 650R
THE ADVENTURES OF TYSON AND HOBBES
THE BACKCOUNTRY PURSUIT- Boise, Idaho's consignment specialist for ADV gear!
av_mech is offline   Reply With Quote
Old 12-12-2012, 08:37 AM   #9
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 1,446
this is an option up front
http://www.motorcycle-superstore.com...liss-Core.aspx
"I refuse to tiptoe through life only to arrive safely at death"
2009 Buell XB12X(sold), 2006 Triumph Sprint ST, 2006 Tiger 955i, 01 XR650L replaced by a KLR, and now a 2010 Honda NT700V for the wife.
Drunk_Uncle is offline   Reply With Quote
Old 12-12-2012, 09:03 AM   #10
slider162
slider162's Avatar
Oddometer: 142
I'm surprised it didn't stick. That stuff was the defacto sealent in the marine world and stuck to anything.
slider162 is online now   Reply With Quote
Old 12-12-2012, 01:34 PM   #11
X1Glider
X1Glider's Avatar
Oddometer: 205
Originally Posted by Drunk_Uncle View Post
Nope. A couple months back, I asked about using Tubliss on a KTM LC4 640 E and possible road use. This is the reply to my question from Jeff Douglass @ Tubliss:
The short answer is that TUbliss is for off-road use only. It is NOT dot and we have NOT tested for on-road use. Also we don't want to incur the liability that comes with on-road use. AND = I also believe that standard tubes are NOT safe for on-road use, so I'm also trying to stay consistent with my beliefs!
With all this being said, please also know that we ARE working on a different product that accomplishes what TUbliss does that will be for on-road use. However this is at least 6-9 months away still.
Old 12-13-2012, 07:12 AM   #12
fbj913
fbj913's Avatar
Oddometer: 1,842
send it to woddys and be done with it.
Ride 365 LLC
Braaaap!
fbj913 is offline   Reply With Quote
Old 04-06-2013, 12:24 PM   #13
bross
Where we riding to?
bross's Avatar
Oddometer: 3,524
For those of you that are having success with the tubeless sealing, does it make tire changes any harder? You're loosing a good chunk of your drop center to sealant?
Old 04-06-2013, 12:55 PM   #14
Riot
Tiger Rider
Oddometer: 64
Have not tried it but OUTEX Tubless kit seems popular.
http://www.youtube.com/watch?v=ikKeVNBAmQQ
Riot is offline   Reply With Quote
Old 04-06-2013, 12:56 PM   #15
cyclingtom
Sim Sala Bim
cyclingtom's Avatar
Oddometer: 3,378
Tire changes- no more difficult than before. The thickness of the sealant is approx. 1/8" (3mm) so it doesn't have a dramatic effect on pulling that bead over the rim for removal/installation.
BTW: 13,780 miles and counting on seal job...no problems.
Gonna start doing a little research on a front seal job. There seems to be two camps on doing the front.
Times are GMT -7.   It's 12:47 PM.
