Go Back   ADVrider > Riding > Face plant
Old 01-05-2013, 04:00 AM   #16
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,572
+1
RTB V- The Texas ADV Rally- Hurry before we fuck this up!
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is offline   Reply With Quote
Old 01-05-2013, 10:26 AM   #17
JZed
Oddometer: 44
Front forks
Originally Posted by UNO_RIDER View Post
You might want to make sure your suspension clickers and compression is dialed in correctly. Seems your front end compressed too much (on the second crash) causing the front tire to wash out. I'm not isolating it to suspension only because your tires are not the best. Nevertheless, make sure your suspension is set up for your riding ability, type and weight. It makes all the difference in the world, especially off road riding.
Keep practicing and the rubber side down.
UNO_RIDER is right. One easy thing to do is to change out the fork oil in the front forks. Seems like many of the Gen 1 KLRs did not get the forks properly serviced at the dealer when new. You could be riding on 10 year old fish oil. Check out the KLR650 FAQ pages (google BigCEE KLR650 FAQ). Lots of good information on the Gen 1bikes there. In my notes I found a reference that the fork oil level should be checked with the springs out with the forks fully compressed (some of the service manuals have errors on this). The oil level should be measured as 188 -192 mm ( 7.40 - 7.56 in) from the top of the fork tube. The volume of oil will be require about 355 cc (12 oz) per side for an oil change.
Others may chime in.
Good luck. Wearing the gear is a good idea.
BTW I had really good results on my GS using Heidenau K60 tires. Should be great on a KLR650. Good road and off-road performance, and 10,000 miles and still tread left riding 2up on GS. Very good 50 - 50 DS tire.
JZED
SC
'86 R80
'92 R100GS
'06 KLR650
JZed screwed with this post 01-05-2013 at 10:44 AM
JZed is offline   Reply With Quote
Old 01-09-2013, 04:03 PM   #18
DirtReeper
Oddometer: 508
or head on over to klrworld.com. come hang out with the rest of us KLRistas we'll teach you how to make hardboxes out of plywood
KLR 650 KLaiRe, dirty red head
Quoth the Darth Peach: "Must work to afford Bikethings"
Quoth Dorzok, it's a BMW. just activate the levitation function that's part of the optional accessory outer space adventure package.
DirtReeper is offline   Reply With Quote
Times are GMT -7.   It's 02:45 PM.
