Old 12-03-2012, 04:04 PM   #1
emti OP
Oddometer: 257
Question xr500/wiseco piston
Im installing a new piston in a 1980 xr500. Im using a Wiseco piston. The directions for fitting the rings do not match the rings, they show bevels and and dots, while I have a gray ring marked "n100" and a brown ring with a grey outer edge marked "n100". The gray ring is wider.I believe the markings go"up" but which is the top ring? I cant see any bevels on the inside of the ring. Thanks emti
emti is offline   Reply With Quote
Old 12-03-2012, 08:43 PM   #2
mcma111
mcma111's Avatar
Oddometer: 12,268
Markings go up and the ring with the different color side/edge is the top ring.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-03-2012, 09:29 PM   #3
redprimo
Oddometer: 460
I installed the same piston in the same motor 6 months ago and ran into the same issue. The rings will only fit one way. The depths of the grooves are different and match the rings.
redprimo is offline   Reply With Quote
Old 12-04-2012, 02:54 AM   #4
emti OP
Oddometer: 257
Thanks for the help, emti
Times are GMT -7.   It's 05:43 AM.
