Old 12-03-2012, 07:56 PM   #1
JGroves OP
Late
JGroves's Avatar
Oddometer: 1,242
Circuit Breaker Question
nt
JGroves screwed with this post 02-01-2013 at 02:46 PM
JGroves is offline   Reply With Quote
Old 12-03-2012, 09:14 PM   #2
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,039
Your on the right track, replace the breaker. Breakers are mass produced and you will often find one that will not work correctly after tripping or being turned off and several times. Also a breaker can be damaged when it trips and as such manufacturers will not warranty one which has been tripped because there is no way to tell how much short circuit it has taken.
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Old 12-03-2012, 09:18 PM   #3
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,475
Yup, replace the breaker.
Or just swap it with another one in the panel that has the same rating and see if the problem follows the breaker. Then you'll know.
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 12-03-2012, 10:02 PM   #4
D.T.
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,670
+1 on the Swap.
Don't F around with the Buss Bars. Dead front is best if you can.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 12-11-2012, 11:35 PM   #5
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,938
Yeah, they go bad after a number of trips. Often, they won't even reset after one good trip.
Saw a store owner try to reset a breaker that had a dead short still on line. He reset it several times only to have it trip. Then he reset it and HELD IT. It stuck closed no doubt because the contacts were welded shut. Then we heard a lot of shouting from the back room where the short was. Took an electrician most of the day to fix the melted wires.
"Son, you can't do both"
Times are GMT -7.   It's 02:36 AM.
