Old 12-03-2012, 10:38 PM   #1
mrfortynine OP
Oddometer: 65
Effective way to make a handlebar slightly thinner?
Hello,
I'm trying to make a chrome handlebar slightly thinner, so that I can fit it to a 92 BMW airhead, which originally comes with 22mm handle bar. The one I'm trying to modify seems only a tiny bit larger on diameter. Does anyone have any suggestion regarding the most efficient method to do this?
Thanks a lot.
jia
mrfortynine is offline   Reply With Quote
Old 12-03-2012, 11:18 PM   #2
griffo1962
griffo1962's Avatar
Oddometer: 1,486
Originally Posted by mrfortynine View Post
Hello,
Thanks a lot.
jia
Unless it's a "Fatbar" then it is 22mm (or the imperial equivalent 7/8") there should be no need to make it smaller.........
griffo1962 is offline   Reply With Quote
Old 12-03-2012, 11:24 PM   #3
mrfortynine OP
Oddometer: 65
7/8" is actually 22.225mm. I tried for about 15 minutes before I gave up. It seems other bmw handle bar parts really don't tolerate that much difference.
Old 12-04-2012, 01:42 AM   #4
Benesesso
Benesesso's Avatar
Oddometer: 9,898
1" wide belt sander. Use where belt isn't backed up by a platen.
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 12-04-2012, 01:57 AM   #5
PeterW
Oddometer: 2,596
I'd be tempted to use one of the fabric backed sanding strips used on power sanders and work it down by hand. Tape off the areas each side.
Belt sander will do it no doubt, but it's also more likely to overdo it as well.
Whatever, you will ruin the chrome ?
Pete
PeterW is offline   Reply With Quote
Old 12-04-2012, 06:07 AM   #6
Daryl_Stamp
Daryl_Stamp's Avatar
Oddometer: 785
.225 is about .008", taking that much off w/ abrasive is no doubt do-able but doing so uniformly by hand over the width of the 2 clamps seems like a really tall order. Possible to remove the clamping halves & have some one with a mill or lathe to bore out the .008" required? Seems like a big pita either way. May also try setting up a 'turning' arrangement by making clamping block (wood gobbled up with grease) that fits loosely enough to rotate bars around axis of motorcycle clamping bolt then carefully grinding down with abrasive tool of some type. Would aid in more uniform material removal, but still pretty hokey.
Live while you're alive.
Daryl_Stamp is offline   Reply With Quote
Old 12-04-2012, 06:18 AM   #7
VStromTom
Oddometer: 1,579
Maybe working on the clamps would be better than paring down the handlebar? Not sure what the mounting system is on the bike you cite. Seems an enlargement of the clamp could be done invisibly?
VStromTom is offline   Reply With Quote
Old 12-04-2012, 06:45 AM   #8
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,197
Jebus just buy handlebars the correct size. Trust me on this -- the amount of time and effort required to get the ones you have to fit will far outweigh just spending some $ on the right ones! Quit while you're ahead!
I'd also be somewhat worried about the decrease in bar strength from thinning the walls.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 12-04-2012, 07:28 AM   #9
GearHeadGrrrl
Oddometer: 336
We can be our own worst enemy...
No point in buggering up a part to make it fit when the right size part isn't that expensive.
blogging @ www.gearheadgrrrl.com
GearHeadGrrrl is offline   Reply With Quote
Old 12-04-2012, 08:08 AM   #10
mrfortynine OP
Oddometer: 65
Thank everyone for the advices. After trying a bit more, I decided to give up. That said, its actually quite difficult to 22mm M bar (some call it clubman) here in US.
Old 12-04-2012, 08:55 AM   #11
GearHeadGrrrl
Oddometer: 336
Same decision I made 2 decades ago...
When I tried to fit my favorite bar off my Yamaha RD400 to my BMW airhead. Put the 7/8" bar back on the RD and bought a proper 22 mm. Fehling bar for the airhead.
Old 12-04-2012, 09:10 AM   #12
mrfortynine OP
Oddometer: 65
Interestingly, the bar i got is from Fehling. On their website, it says "22mm (7/8")". So I took my chance. Well.
Old 12-04-2012, 11:48 AM   #13
GearHeadGrrrl
Oddometer: 336
Wonder if they shipped the wrong bar?
I think they sell some of the same bar shapes in both sizes...
Old 12-04-2012, 04:40 PM   #14
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,184
I have filed & sanded down the bars twice now to 22mm. Doesn't need to be precise. Generally the bars I use (Protaper & Sunline) are knurled on the clutch side (& fatter), & smooth on the right. Be careful not to use any force sliding on the clutch perch, as this fractures easily. I've found that the right (throttle) side needs no work.
I've got fat bars on Rox Risers on Gus. They taper down to normal sizing anyway. I crashed fairly heavily last week, & they stood up to that well.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits screwed with this post 12-04-2012 at 06:16 PM
Box'a'bits is offline   Reply With Quote
Old 12-04-2012, 05:43 PM   #15
boxerkuh
Oddometer: 230
Only place where I have found decent BMW 22 mm bars is from Flanders handlebars in California. Great stuff. I have always been told that it is much easier to "ream" out the controls to fit a 7/8 bar than to make the bar smaller.
boxerkuh is offline   Reply With Quote
Times are GMT -7.   It's 01:26 PM.
