Old 12-04-2012, 05:52 AM   #1
joe_soap OP
Oddometer: 4
temp gauge
On a couple of rides now, I have experienced this. The indication bars for the motor temperature disappear from the screen. All other indications are there, its just the moving temp blocks which disappear. Some times they come back after a while or if the bike stand for a while and started again they will appear. the heat sensor on the motor are still be working as the fan still comes on to cool the motor if it heats up too much.
Anyone had a similare problem on there 950?
joe_soap is offline   Reply With Quote
Old 12-04-2012, 09:14 AM   #2
Sacal
Sacal's Avatar
Oddometer: 132
Temp switch controls the fan, coolant temperature sensor is on the left side of the engine in the V just to the right of the starter. Cant post a pic at the moment but you should be able to find it on an online fiche...or i'm sure another inmate will have a pic soon....ish
Sounds like a broken wire or dodgy connection somewhere though, once everything heats up the connection expands and creates a gap cools down and connects again. Or possibly a wire rubbed its insulation and is grounding somewhere. Find the temp sensor and follow the wiring and check any connectors first..
To test the sensor, the book says:
Resistance at -20C 15 kΩ +/- 1.5 kΩ
Resistance at 20C 2.45 kΩ +/- 240 Ω
Resistance at 80C 318 Ω +/- 31 Ω
ad astra per alia porci
Sacal screwed with this post 12-04-2012 at 09:30 AM
Sacal is offline   Reply With Quote
Times are GMT -7.   It's 10:40 AM.
