Old 12-04-2012, 03:00 PM   #1
sweetwater OP
Oddometer: 169
Solar Battery Tender
I am looking for a reliable, safe, solar option for a "battery tender" I can use with my 2010 Concours. I've used little 5watt panels in the past for deep cycle RV and marine batteries, but I want "Battery Tender" level reliability and confidence. Any thoughts or experience?
BTW, I've combed the internet and not found any encouraging packages, so I'm guess DIY.
sweetwater is offline   Reply With Quote
Old 12-04-2012, 03:16 PM   #2
GreaseMonkey
Rhymes w/piecejunkie
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 4,757
Well here is one already put together:
http://batterytender.com/5-watt-solar-panel.html
Or if you want to go DIY and already have a solar panel, you can purchase a float charger with the wall wart and just replace that with your panel and save about $65 from the above item:
GreaseMonkey is offline   Reply With Quote
Old 12-04-2012, 05:00 PM   #3
jon_l
Southern Ontario
jon_l's Avatar
Oddometer: 1,974
Maybe I misunderstood your question?
How about a solar battery tender?
'09 Honda CBF1000; '09 Yamaha WR250R
jon_l is offline   Reply With Quote
Old 12-04-2012, 11:35 PM   #4
sweetwater OP
Oddometer: 169
Laugh
Well, I feel stupid. My work firewall didn't allow battery tender to display or I would have seen this. Looks like a good prepacked set with panel and controller...
Old 12-05-2012, 07:45 AM   #5
ttpete
Rectum Non Bustibus
Oddometer: 3,508
Solargizer. http://www.tstonramp.com/~rhinocharge/pulsesol.html
09 Kaw Versys
"The problem with Socialism is that you eventually run out of other people's money" _____ Margaret Thatcher
Old 12-06-2012, 02:56 AM   #6
sweetwater OP
Oddometer: 169
That's another quality option. I just need to figure out how much distance I need to cover in this outbuilding while my garage is filled up with junk...what a hassle, but being able to keep two bikes on tenders will make me happy.
Old 03-17-2013, 06:51 AM   #7
sweetwater OP
Oddometer: 169
Quick follow up:
Deltran 15amp Solar Battery Tender, one for each bike, working very well in my storage area. I would recommend this product to friends.
Old 03-17-2013, 07:57 AM   #8
Gramp-Z
Gramp-Z's Avatar
Oddometer: 637
Sweetwater , how long of a wire run did you have to go ? The reason I ask is i have been maintaining my van battery for maybe 10 years with a 1.5 watt solar battery charger . Starts every time (even in the cloudy , dark northwest) , so I am thinking you have a crapload of extra power there .
Save yourself $5 us my SmugMug coupon b87YWgTeSWxEc
Couple volcanos , stonehenge and some peg scraping
http://www.advrider.com/forums/showthread.php?t=620436
Old Man plays with his Wee
http://www.advrider.com/forums/showthread.php?t=608068
Gramp-Z is offline   Reply With Quote
Old 04-13-2013, 06:16 PM   #9
sweetwater OP
Oddometer: 169
You're spot on that I've got gobs of extra! The side story is that I'm using the extra to power my radio station too! Direct answer though, is that I'm running 31' of total wire...
Keeps bikes happy and runs 1 gallon Yaesu "all channels" and a 50 watt 2m/440 Yaesu base station.
Times are GMT -7.   It's 05:54 AM.
