Old 12-04-2012, 03:23 PM   #1
acejones OP
acejones's Avatar
Oddometer: 3,321
Question ZUMO 550 updates
I was just thinking of doing an update on my 550 since I haven't done one in a very long time.
Has anyone run into any unexpected surprises after doing an update ?
I don't want to do the update if its going to cause problems.
If I wasn't here, I'd be somewhere else
acejones is offline   Reply With Quote
Old 12-04-2012, 03:39 PM   #2
UnclebudinTX
UnclebudinTX's Avatar
Oddometer: 184
i recently updated maps and software,, no issues unless you count (mind you this was first time ever updatitng maps) not all of the united states will fit on the tiny hard drive.. If you want all of the United States you need to save them to your sd card.. and then point the zumo to read maps from sd card..
take a little longer for the zumo to boot up but once it going no problems.. just remeber it tkae at least three minutes for the zumo to boot up and start giving directions..
Unclebudintx
http://unclebudsadventures.blogspot.com/
2004 BMW R1150GS 2004 BMW R1150RT
1979 Kawasaki KZ1000st (sold)
1991 Harley XLHsporty 883 (sold)
UnclebudinTX is offline   Reply With Quote
Old 12-04-2012, 03:43 PM   #3
acejones OP
acejones's Avatar
Oddometer: 3,321
Thanks what size card are you using ?
Old 12-04-2012, 03:53 PM   #4
lhendrik
Truffle Rustler
lhendrik's Avatar
Oddometer: 1,942
I would recommend a 4GB card, as some of the City Navigator products are now over 2 GB. You can use the extra space for music files if needed.
Normal is just a setting on the dryer.
Armageddon was yesterday - Today we have a serious problem.
2009 R1200GS Adventure
2008 K1200GT
lhendrik is offline   Reply With Quote
Old 12-04-2012, 03:58 PM   #5
UnclebudinTX
Oddometer: 184
8gb but i was told you can go as high as 32gb,, but i have not tested that... i have about 9 hours of music and maps on the 8gb card...
do a seach on this site about updating maps... there is an old thread by some guy nemed zumoman or something like that...it is very helpful.. i thought i had the thread book marked but cant find it right now
Unclebudintx
Old 12-04-2012, 05:23 PM   #6
Twohondas
Twohondas's Avatar
Oddometer: 1,093
I run firmware 5.0 on the unit.
I put the CN North America maps on the 8 gig SD card along with 1000 mp3s. I use the "free" space on the unit itself for 24K Topo.
Twohondas is offline   Reply With Quote
Old 12-04-2012, 05:50 PM   #7
Phat
Oddometer: 55
A reply to me from Garmin support. "Thank you for contacting Garmin International.
I will be happy to help you with this. Garmin releases 4 map updates a
year, and with every map update more information is added. Because of
this you will have to select for a smaller region to be downloaded to
your device, and the rest of your update can be loaded to an SD card
using the MapInstall program. In order to download the rest of your
update to an SD card you will have to select for your maps to download
to your "device and computer". Below I have provided you with
instrucitons on how to use MapInstall.
Using MapInstall-
The map update installation will install the maps on your Garmin device
but will also install them to your computer. This is beneficial in
cases where there is not enough free space to install the map data to
the internal memory. After you have updated the Nuvi with a region
(i.e. West Region) you will need to insert a blank SD card. The SD card
must be at least 512 MB but no larger than 16 GB.
Once you are connected to the computer, open the MapInstall program.
You can open MapInstall from your Start Menu > All Programs > Garmin
folder.
When MapInstall opens it will ask you to select a device. Just verify
that the Nuvi is listed and select the 'removable disk' from the drop
down menu. After you have selected the 'removable disk', select Next.
Once the map page has loaded, simply select the states you want to
install onto the card. Be sure to remember that all of the states you
originally loaded do not need to be selected. You only need to select
the states that were not included in the region you installed.
If you need further assistance please reply to this email or contact us
at 1-800-800-1020 Monday-Thursday 8am-6pm and Friday 8am-5pm Central.
With Best Regards,
Tamara J" No 32gb support according to the reply I got.
Phat is offline   Reply With Quote
Old 12-04-2012, 07:42 PM   #8
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,817
Generally when you update a map it takes longer for the initial boot as the gps indexes and caches the new map, but subsequent bootup should not be slower than normal.
"Don't play a lute to a cow" (Old Chinese Idiom)
Old 12-05-2012, 11:35 AM   #9
acejones OP
acejones's Avatar
Oddometer: 3,321
FOLLOW UP
Thanks for the responses ! I did have a problem with some sort of glitch that Garmin resolved at their end. Once that was done the update proceeded. I was only on hold for ten minutes and the tech was polite and knowledgeable.
Old 12-06-2012, 10:24 AM   #10
Twohondas
Twohondas's Avatar
Oddometer: 1,093
I used to split the CN maps updates between the SD and unit but now just dump the whole thing on the SD card.....don't think it really makes a diff on performance.
Make sure you update the firmware too.
Twohondas screwed with this post 12-25-2012 at 12:20 PM
Old 12-25-2012, 08:51 AM   #11
Gillus
High Desert Rat
Oddometer: 418
I hooked my 550 up to the computer and started to do the Garmin update for grins. It first installed the map installer or did something that updated the 550 so it now says 2012 when it boots up when started. So far that didn't cost a thing so I stopped right there. Hopefully it updated the firmware or software or whatever makes it work and seems to work good but I haven't had in on the road yet.
My thinking is that they haven't changed the road system much since the 2009 maps mine has on it. Maybe to find a new street address or someplace new but I'll try it this way for a while. I am cheap and considering a 660 anyway.
The biggest hassle I had was riding down a state or back road highway and the GPS not showing the road. What's up with that?? I always have a paper backup in the tank bag. Maybe the free 2012 issue/update will fix that.
Gillus is offline   Reply With Quote
Old 12-25-2012, 01:51 PM   #12
UnclebudinTX
Oddometer: 184
Actually the road have changed alot in the last few years.. I thought the same a you for a while, then while traveling fron Tx to Indianapolis in 2011 the zumo has me take an exit in St. Louis... I found my self in a industrial area at 5 pm rush hour.. zumo was still dertimined we going the right way so i follwed her till she wanted me to go left and there was no left... I pulled over by an the building in the shade.. JULY it was about 100 degrees. Then a relized there was a homless guy hanging out over there too.. so pulled out in the middle of a big empty parking lot and reexamened where i was.. I could see the St Louis Arch so rode that direction.. got there and pulled out my paper map.. reprogramed my zumo... enjoyed the arch for a while and headed on.. I updated the maps asap... In 2012 i took the same trip and mrs zumo got me through St Louis with no problems..
Unclebudintx
Old 12-25-2012, 06:21 PM   #13
Effjay
Effjay's Avatar
Oddometer: 67
OK, I just copied the entire latest version NA.2013.30 file download (yikes - 6.83GB total) to an 8GB SD card with objective of being able to select that latest map version with SD inserted into my original Zumo 550. As clarification, I own 2/ea Zumo 550, SP2730 and SP2720 units. The other Z550 and both SP2730 feature LM subscriptions, so my hope is to piggyback off those for my original Zumo unit. I figured Zumo would prompt me if I'd like to import newly found data, but no dice. I even detached the files from the NA.2013.30 folder in case that was an issue but no dice.
Some of you mentioned much smaller file sizes, so I'm thinking only a subset of files within 6.83GB total are required? Some clarification would be helpful. What file names/extensions/sizes are you using successfully? I'm not a Garmin novice and I'm actually proficient in creating custom MapSource routing, but this has me stumped. TIA...
Oday ouyay eakspay igpay atinlay?
2004 R1150RT - Biarritz Blue
2004 R1100SA - Pacific Blue
Effjay is offline   Reply With Quote
Old 12-25-2012, 08:13 PM   #14
DennyIndy
Old F@rt
DennyIndy's Avatar
Oddometer: 347
It doesn't work like that.
You must use mapinstall or one of Garmins map updaters to install maps on your GPS.
If you simply copied the downloaded file from your computer to the SD card that just will not work.
The install programs compile the maps into a different format than the file that you downloaded from Garmin.
Originally Posted by Mac View Post
Fret about bigger issues, like whether a neighbor's dog is pooping in your yard.
Cheers, Denny
DennyIndy is offline   Reply With Quote
Old 12-27-2012, 07:59 AM   #15
Gillus
High Desert Rat
Oddometer: 418
Thanks for the info, maybe I will update the maps and then it might find the roads I am on. The $50 or $90 is worth not getting mugged or shot at somewhere I shouldn't be.
Beware those with no sense of humor as they will cause you misery.
Disclaimer: I am only responsible for what I said, not what you understood or how you interpreted my words!!
'11 GSA supertanker/mothership, '07 Tiger 1050, Suzuki Burgman 400, wanting a D/S
Times are GMT -7.   It's 05:34 AM.
