Old 04-22-2013, 07:14 PM   #106
Queen of Spades OP
tall drink of water
Queen of Spades's Avatar
Oddometer: 1,003
After getting the lights working, I decided it was time to press the Red Button. Performed a cursory check of all connections and fittings, and put the tank back on thinking I'd be riding down the street in a few minutes. Rolled bike outside and hit the starter. No spark. Confirmed with timing light on plug wire (made sure timing light worked by testing on my car). No spark, no joy..
So I've rewired half the bike, replaced a $$$ CDI, and am back where I started. I'm convinced the old CDI was bad or going bad because it was buzzing when I turned the key on. The new one is silent.
If anyone is reading this in the Atlanta area who is A) an electrical whiz and B) eager to make a few bucks and C) more eager to help a fellow inmate.. please PM me.
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=fifXkDQpda4 (January 2014 snow ride)
Queen of Spades screwed with this post 04-22-2013 at 07:24 PM
Queen of Spades is offline   Reply With Quote
Old 04-22-2013, 07:39 PM   #107
bmwktmbill
Traveler
Oddometer: 5,219
Sweet Jesus!!!
Check the ground for the CDI box...or you have lost power.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 04-23-2013, 04:11 AM   #108
Queen of Spades OP
tall drink of water
Oddometer: 1,003
Originally Posted by gunnerbuck View Post
A few pages back I mentioned for you to visually inspect the stator and pickup coil, have you done that?
I hadn't checked this yet as I was sure the CDI was culprit. I'm going to slip out in the shop before work this morning for a quick visual inspection.
Old 04-23-2013, 04:11 AM   #109
Queen of Spades OP
tall drink of water
Oddometer: 1,003
Originally Posted by bmwktmbill View Post
Sweet Jesus!!!
bill
Will do. Everything looked tight there but I didn't actually put my fingers on the green wire.
Old 04-23-2013, 05:57 AM   #110
Queen of Spades OP
tall drink of water
Oddometer: 1,003
Bill: coil screws were snug.
On to the next step:
Ignition cover.
Cover removed. Gasket broke, so added one to my cart:
Pulser coil and wires appeared to be in good shape externally.
Stator & wires looked OK as well.
I pulled the pulser coil from the case and noticed two small cracks - probably from bending the wires during removal. KTM Parts Warehouse sells replacement pulsers for $45, so that's on order as well.
Old 04-23-2013, 07:42 AM   #111
Kawidad
Kawidad's Avatar
Oddometer: 5,076
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is online now   Reply With Quote
Old 04-23-2013, 07:58 AM   #112
Queen of Spades OP
tall drink of water
Oddometer: 1,003
Originally Posted by Kawidad View Post
Thanks for your contribution.
Old 04-23-2013, 09:02 AM   #113
Droptarotter
Oddometer: 1,304
C'mon.......you gotta have good popcorn when you are reading these threads
I hope the cracked wires sort the problem!
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 04-23-2013, 07:57 PM   #114
bmwktmbill
Traveler
Oddometer: 5,219
Somebody shake Luke loose from where ever he is and let's get him to help.
LUKE..LUKE???
bill
Bill Shockley
Old 04-26-2013, 06:15 PM   #115
Queen of Spades OP
tall drink of water
Oddometer: 1,003
Bluhduh
With the bike leaning to the left, is it safe to remove the two oil hose flanges on the right side of the engine without losing oil? I have to disconnect these two to replace the pulsar coil.
Old 04-26-2013, 08:08 PM   #116
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,354
Yes, you can remove those lines, very little oil will flow out from there as it needs the oil pump working to bring it up from the sump...
gunnerbuck is offline   Reply With Quote
Old 04-27-2013, 12:22 AM   #117
mountaincadre
Oddometer: 364
Those wires dont look good, whether its those two that are the culprits remains to be seen, but i would replace it anyway as those are bound to go leaving you stranded.
mountaincadre is offline   Reply With Quote
Old 04-27-2013, 12:29 PM   #118
Queen of Spades OP
tall drink of water
Oddometer: 1,003
Well, it finally runs.
Damage list:
New CDI (old one made buzzing noise)
New pulse coil (old one had a couple cracks in wiring)
New ignition coil (old one may have been OK, got a new one just in case/spare)
New plug cap
New plug
New internal oil filter
New rear brake switch (old one bad)
New molex connectors in rats nest behind headlight
New bullet connectors throughout
Additions:
Water resistant USB charger
Hyperlight brake lights with custom mounting brackets
To do:
Valve adjustment
Oil change with new external oil filter
New fork seals
Foldable mirrors
Squadron LED headlight with dimmer switch
New front tire
LIke I mentioned earlier, I've never worked with electrical issues other than changing bulbs. This was frustrating and tried my patience. But it's finally running and hopefully I won't have to worry about electrical issues again!
Thanks to everyone who chimed in to help.
Old 04-27-2013, 02:40 PM   #119
dolphins13
orange rules
Oddometer: 138
Cool2
Damage list:
New plug cap
New plug
Additions:
To do:
Valve adjustment
New fork seals
Foldable mirrors
New front tire
Thats cool it runs. How's it run? Does the carb need to be cleaned, and or rejetted? I believe you have the same bike as mine? 99 lc4e. No snorkel, 157.5 main jet, and open exhaust, and it really runs good. Oh ya and moved the needle 1 notch up. kenda 270's are ok all around tire?
dolphins13 is offline   Reply With Quote
Old 04-27-2013, 09:39 PM   #120
bmwktmbill
Traveler
Oddometer: 5,219
Happy for you.
b
Bill Shockley
Times are GMT -7.   It's 06:58 AM.
