Old 12-26-2012, 09:58 AM   #31
Dan Kyle OP
Oddometer: 473
Originally Posted by TOTim View Post
Hello Dan
Could you send a price for front and rear set on a 2003 1150gs delivered to Canada.
Thanks, Tim.
PM sent
Thanks, Dan
Dan Kyle is offline   Reply With Quote
Old 12-26-2012, 10:03 AM   #32
Dan Kyle OP
Oddometer: 473
Originally Posted by tjt94 View Post
Dan, can you send me some options for my '01 R1150GS? I am more of a highway rider with occasional gravel roads. I weigh 230 and am 6'4". I typically put around 15K on the bike per year. Let me know if you have any other things necessary to put the quotes together.
PM sent
Thanks, Dan
Old 12-26-2012, 11:03 AM   #33
Dan Kyle OP
Oddometer: 473
Originally Posted by David37 View Post
Dan can you give me a price on a pair of OHLKA149 (Ohlin part #) for my Kawasaki ZRX1200
PM sent
Thanks, Dan
831 394 1330
Old 12-26-2012, 12:17 PM   #34
ST4s
Oddometer: 50
Ohlins "Skyhook suspension"
Dan, great offer on the Ohlins stuff, Thank You. Have any upgrade or improved parts been made available for the electronic suspension on the Ducati Multistrada 1200?
My understanding is that Ohlins is now offering an aftermarket suspension system similar to the Sacks Skyhook suspension on the 2013 Ducati Multistrada 1200. Any information on this new system? I understand that this was announced 07Dec12. If this system is still unannounced then I know nothing .
Cheers
ST4s
ST4s is offline   Reply With Quote
Old 12-26-2012, 01:51 PM   #35
Dan Kyle OP
Oddometer: 473
Originally Posted by NoiZboy View Post
Dan,
Looks like a great offer, but what are the differences between the options listed for the R1150GS? Is the external reservoir only a matter of convenience, or does it offer additional capabilities/features? Sorry if I'm asking a dumb noob question, and thanks for the remarkable opportunity!
-Marty
For the R1150GS there is One front shock and 4 rear shocks available
The front is a simple design Emulsion Type shock.
Emulsion type shocks are used for a lot of front BMW's and many HD rears.
They work very well for good ride quality when the amount of stroke is long such as on BMW fronts. They are the least expensive shock, as the use the least number of parts.
Rears Ohlins Offers these four shock:
BM542
BM940
BM942
BM045
The BM542 is the most expensive, it has adjustable Rebound Adjustable Compression, and a Hydraulic spring preload adjuster.
This shock is also special in that it has what Ohlins calls a Progressive Damping.
It uses 2 pistons, one like all the other 46 series Ohlins and the second additional damping need the end of the stroke. This is the best shock for any off road use.
This was first used by Ohlins in 2005/2006, I found it funny another brand is touting it as something new or unusal.
The BM940 is the standard road shock, not really made for off road use. It has the same Hydraulic spring preload adjuster but only Rebound adjustable.
The BM942 is the same as the BM940 but it is shorter to lower the back of the bike.
The BM045 is also the same as the BM940 but it does not have the Hydraulic Spring preload adjuster.
The rear shocks are one of three designs. Piggyback reservoir, Monotube with a remote reservoir, Monotube, or TTX.
Ohlins does not make a TTX for this bike, so for now I will skip that. Just let me say the TTX is the best of the bunch and the newest design as well.
The BM542 is a Monotube with a remote reservoir, The advantage is a little more oil, and easier to service (cheaper to service as well) than a Monotube.
The BM940, BM942, and BM045, are all Monotube shocks.
I prefer the Piggyback or remote reservoir.
All of these shocks are high pressure Nitrogen.
This is another one of the advantages of a TTX , it runs 1/3 to 1/2 the pressures of this design shock.
Dan Kyle screwed with this post 12-26-2012 at 02:08 PM
Old 12-26-2012, 04:20 PM   #36
Dan Kyle OP
Oddometer: 473
Cheers
ST4s
The first things we have been doing to the 1200S are stiffer front and rear springs, even for 150 lb riders the springs are too soft.
The OEM fronts are 6.0 Nmm we install mostly 7.0 Nmm but have 7.5 Nmm and stiiffer.
The Rear is a 85 Nmm stock, we use a 100 Nmm as the replacement.
This mod alone is usually enough to fix both ends.
It really make a huge difference.
We can install different valve specs into the front forks, fo anyone how has done the springs and still ewants to reduce brake dive, I do not think it is necessary.
I do not think you will see Ohlins on the 2013 1200S, but that is still just a Rumor.
Old 12-26-2012, 07:20 PM   #37
Shred Head Fred
Captain Amstel
Shred Head Fred's Avatar
Oddometer: 54
'07 GSA 1200 ADV Options
Hi Dan,
I'm currently running what I bought from previous owner. Elka front with stock rear. I'm 175 lbs w/o gear. I ride on and off highway with camping gear. What are the options for my ride. I saw the promotion about the BM606/607 is that my best option?
Thanks,
Fred
PM sent
Shred Head Fred is offline   Reply With Quote
Old 12-27-2012, 04:50 PM   #38
Harold Waikiki
oldfatdumbbrokeoutof
Harold Waikiki's Avatar
Oddometer: 395
Dan--i have a '11 multi s touring. is it poosible to upgrade to skyhook? thanks!
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
'09 KTM 950 SE Erzberg
'15 KTM 1290 SA ordered.
Harold Waikiki is offline   Reply With Quote
Old 12-28-2012, 10:40 AM   #39
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,710
PM sent
PM and email sent
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 12-28-2012, 04:39 PM   #40
Dan Kyle OP
Oddometer: 473
Originally Posted by Shread Head Fred View Post
Hi Dan,
Thanks,
Fred
PM sent
Talked on the Phone, Thanks. Dan
Old 12-28-2012, 04:39 PM   #41
Dan Kyle OP
Oddometer: 473
Talked on the phone, thanks, Dan
Old 12-28-2012, 04:40 PM   #42
Dan Kyle OP
Oddometer: 473
Originally Posted by Hotmamaandme View Post
PM and email sent
Talked on the phone, thanks. Dan
Old 12-29-2012, 08:27 AM   #43
madpuma13
Oddometer: 109
I hope I didnt catch this thread too late! Im not very knowledgeable about the suspension system so must rely on suggestion.
I have an 08 gs that is ridden about 85% on road and 15% off road mostly farm roads but sometimes random backwoods trails I find that can become quite jarring sometimes. The serious trail riding is pretty rare like less than 2% of all riding but I dont want to break the shock when I find myself out there and not have the right one.
95% of all riding is done solo me weighing in at around 190 with gear on. The bike will usually have full cases installed. I wouldnt mind if the bike was lowered an inch or thereabouts but not higher. I barely touch the tiptoes of my feet if i dual foot and while I do use one foot most of the time, backing out of a slight incline in a parking space with the balls of your feet is a little annoying.
What would you suggest for my bike? Will an occasional two-up ride be an issue? If it's not too much, let me know the worst all the way through to the absolute best option (besides ESA as I am not about to convert my bike for that).
Thanks a bunch !!
madpuma13 is offline   Reply With Quote
Old 12-29-2012, 08:42 AM   #44
wmfleet2
Oddometer: 910
2001 cbr 929 rr
stock front and rear ,,,need info on what you can do for it ?? 225 lb rider,mostly back roads in Pa ,WV .
wmfleet2 is offline   Reply With Quote
Old 12-29-2012, 12:57 PM   #45
Dan Kyle OP
Oddometer: 473
The Ohlins rear shock for the CBR929 is no longer available.
We do have Ohlins springs and 20 MM Ohlins valves for the CBR929 front forks.
The springs are $140 a set, the 20 MM Valve kit, all 4 valves preassembled is $259, and the Ohlins fork oil is $26.
Or we install all of it with labor it is $675.
Thanks, Dan
831 394 1330
Times are GMT -7.   It's 04:25 PM.
