Old 12-29-2012, 12:09 PM   #46
Dan Kyle OP
Oddometer: 473
Originally Posted by madpuma13 View Post
I hope I didnt catch this thread too late! Im not very knowledgeable about the suspension system so must rely on suggestion.
I have an 08 gs that is ridden about 85% on road and 15% off road mostly farm roads but sometimes random backwoods trails I find that can become quite jarring sometimes. The serious trail riding is pretty rare like less than 2% of all riding but I dont want to break the shock when I find myself out there and not have the right one.
95% of all riding is done solo me weighing in at around 190 with gear on. The bike will usually have full cases installed. I wouldnt mind if the bike was lowered an inch or thereabouts but not higher. I barely touch the tiptoes of my feet if i dual foot and while I do use one foot most of the time, backing out of a slight incline in a parking space with the balls of your feet is a little annoying.
What would you suggest for my bike? Will an occasional two-up ride be an issue? If it's not too much, let me know the worst all the way through to the absolute best option (besides ESA as I am not about to convert my bike for that).
Thanks a bunch !!
The best option are the New Ohlins TTX shocks, the BM676 and BM677.
These are very good for ride quality, very good for both on road and off road, and do have a Hydraulic spring preload adjuster for adding luiggage or a passenger.
The Next best are the Ohlins BM543 and BM437. The BM543 can be used both on and off road, it Uses a progressive damping system with twin pistons like the BM542 listed in post 35.
The next pair are the BM436 and BM437, these are meant for road use only
All the shocks above are the same length as the stock shocks, and are not going to be any lower than the stock shocks. And on the BM543 rear and BM437, a little higher.
Ohlins does make a shorter set of shocks for the R1200GS, they are the BM508 and BM509, these are the same as the BM436 and BM437 with a reduced stroke, less rear wheel travel, these are abouut the same ride height as the stock shocks.
Thanks, Dan
Dan Kyle is offline   Reply With Quote
Old 12-29-2012, 01:31 PM   #47
madpuma13
Oddometer: 109
Pm'd
madpuma13 is offline   Reply With Quote
Old 12-29-2012, 02:08 PM   #48
Dan Kyle OP
Oddometer: 473
Pm'd
PM answered, Thanks. Dan
Old 12-29-2012, 06:23 PM   #49
Ironwood
Friday Harbor, WA
Oddometer: 753
G650X Challenge
What is available to the G650X Challenge, front and rear? Joe
Ironwood is offline   Reply With Quote
Old 12-30-2012, 09:37 AM   #50
Dan Kyle OP
Oddometer: 473
I do not have anythng for the front.
For the rear Ohlins makes the BM636
G 650 X Challenge2007-09BM 636S46HR1C1163608900698-39
Old 12-31-2012, 08:02 AM   #51
shashankmittal
shashankmittal's Avatar
Oddometer: 96
Hi Dan
I am 5'6", 155lbs and my riding is 80/20 street/dirt. Couple questions for you regarding my 2013 F800GS (factory lowered):
1. Is the Ohlins USA/Sweden fork cartridge compatible with the lowered F800GS? I am not sure whether the fork tubes on the lowered GS are the same as standard GS. The BMW parts fische doesn't list the fork tube part numbers, so I cannot confirm.
2. In combination with the S46DR1B shock, will there be any height increase? I am not looking to increase the height as the current seat height of 32.3" is more than what I can handle. In fact, lowering it further by an inch or less would be better.
Thanks,
Shanks
Currently - '15 Versys 1000, '15 KTM Duke 390, '09 Daytona (track only) Previously - '13 Multistrada, '13 F800GS, '13 MV F3, '10 S1000RR...and many more.
shashankmittal is offline   Reply With Quote
Old 12-31-2012, 08:26 AM   #52
Dan Kyle OP
Oddometer: 473
Originally Posted by shashankmittal View Post
Hi Dan
Thanks,
Shanks
I do not know either.
If they are shorter we should be able to shorten the Ohlins USA cart kit.
The Ohlins shock is the same eye to eye measurement as the Stock shock on the Standard height bike, so yes it will be much taller.
Plus These bikes stock have a huge amount of both static and rider sag making the bike even lower. This also uses up a lot of the rear wheel travel.
The Ohlins shock will not have as much sag also raising the ride height of the bike.
Dan
Old 12-31-2012, 09:09 AM   #53
Dan Kyle OP
Oddometer: 473
Just a quick note, as there were many Holidays and Ohlins was late telling us about the 5% price increase they have agreed to go until Jan 4 (Friday) on the old prices.
Thanks, dan
Old 01-02-2013, 08:13 AM   #54
icebox
Oddometer: 1,035
F650gs
Went through the whole thread looking for F650GS possibilities. The SO has both a twin, new, and single,old. The single is really ready for a new shock, and seems to sit a bit to low on the rear. Could also use fork springs. Can the back be raised a bit and what are the possibilites? The single is much easier for her to handle on dirt, and cuses less hand wringing when dropped.
motorcycles are like fly rods, you need way more than one.
icebox is offline   Reply With Quote
Old 01-02-2013, 04:26 PM   #55
Dan Kyle OP
Oddometer: 473
Ohlins does make a rear shock for the F650GS Dakar 2000-2007, in fact they make 2 one for the ABS version (BM750) and one for the Non ABS (BM048)
They are both the same price, click here for pricing or send me a PM or email (dan@kyleusa.com)
http://www.bmws1000rr.net/pics/advforum.pdf
Ohlins does not offer any fork springs for this model.
Dan
Old 01-28-2013, 04:29 PM   #56
CalGSer
Robust Adventurer
Oddometer: 79
Ohlins for 1150 GS
Hi Dan,
Thanks for the group buy opportunity, looks like I missed the cutoff to avoid the price increase. Looking to replace the rear on my 2001 1150GS. I ride 50/50 road/off road and always solo. For weight, 215 lbs in gear, and another 40-50 lbs in equip off road.
It seems that the BM542 is the model to use for my purposes from what I've seen on this thread. Do you know how much this raises the height of the bike or additional ground clearance? At 6'5" this isn't a worry and there will be a benefit as it could provide some additional ground clearance.
Can you pm a price please.
2007 G650 X Challenge - work in progress
2001 1150GS
You can't always get what you want, but if you try sometime, you just might find, (that) you'll get what you need. Ancient British philosopher
CalGSer is offline   Reply With Quote
Old 01-29-2013, 05:25 PM   #57
Dan Kyle OP
Oddometer: 473
Originally Posted by CalGSer View Post
Hi Dan,
PM sent.
Thanks, Dan
Old 02-01-2013, 09:02 AM   #58
craigv
Oddometer: 37
'07 gsa
Hi Dan,
Could you send me a price on a set BM678 & BM679, shipped to NJ.
I'm 208lbs fully geared, quite a bit of off road w side cases - add'l 65lbs
rest of time, topcase only commuting
Thanks, Craig
craigv is offline   Reply With Quote
Old 02-01-2013, 09:09 AM   #59
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,729
Dan, did Ohlins ever release their fork kit for the Tiger 800 Roadie?
swimmer is online now   Reply With Quote
Old 02-01-2013, 10:47 AM   #60
Dan Kyle OP
Oddometer: 473
Originally Posted by craigv View Post
Hi Dan,
Thanks, Craig
PM sent
Thanks, Dan
831 394 1330
Times are GMT -7.   It's 09:17 AM.
