01-22-2013, 12:41 PM
#31 |
Oddometer: 80
tiger 800 xc
I am taking the 800 xc to Race Tech, going to have Terry@ race tech
put new springs and gold valves on front and rear suspension. Will give progress after installation rfmorris |
01-24-2013, 04:19 PM
#32 |
Oddometer: 41
Hi Terry,
I'm looking at getting the DR650 rear shock shaft upgrade. I currently have the stock rear shock with a 7.5 kg/mm aftermarket spring that uses the stock spring perches. I’m interested in buying a new shock shaft assembly but would like to forgo buying another spring. Does the shock shaft assembly come with a spring adapter that works with stock sized springs? Thanks!! Chris |
01-26-2013, 07:47 PM
#33 |
Oddometer: 10
Just a note, I am currently on the road doing the IMS shows so bear with me on quotes and service questions. I have not forgotten about anyone.
Thanks!! Terry |
01-27-2013, 10:48 AM
#34 |
Oddometer: 550
I had my Triumph Tiger 1050 back out to Racetech after a gold valve install so one of their techs could evaluate it. He was quite happy with the balance & compliance as was I. Looks like a super setup for those of you with this bike.
Larry If it ain't fun, I don't do it!!! Stuff - I need more Stuff.... |
04-17-2013, 05:23 PM
#35 |
Oddometer: 22
05-11-2013, 04:53 PM
#36 | |
armchair asshole
Oddometer: 2,573
05-12-2013, 12:14 AM
#37 | |
Oddometer: 180
It's not advertised for the front, but RaceTech has one. I bought all the front components and have yet to install them. I was told the rear kit is coming shortly. I got new springs, spacers and gold valve kits for rebound and compression. I've used RaceTech in the past on my DR650 and the results were night and day. Clearly more work if you are doing it yourself, but great results for the cost. I think I was in the $400 range for everything for the front end. Unknown on the rear. All that has held me off is that I need a headlift stand so I can remove the forks. Regards p3 p3 |
05-12-2013, 08:06 AM
#38 | |
armchair asshole
Oddometer: 2,573
05-16-2013, 10:16 PM
#39 | |
Oddometer: 180
p3 |
05-17-2013, 01:30 PM
#40 | |
armchair asshole
Oddometer: 2,573
05-18-2013, 04:29 PM
#41 |
digity digity
Oddometer: 913
sure wish i'd seen this post a month ago before i sent my shock out to you for a rebuild...
save $5 on a smugmug account with this coupon (1QtpdGzlZcw8s) ___________________________________________ stuck in time with no time to do it |
