Old 12-06-2012, 03:48 AM   #1
paulk46 OP
Katoom
paulk46's Avatar
Oddometer: 227
Pop Bang stall
Morning all, so things, not sure if 1 is related to 2,
1, the other morning i notice that temp gauge is hitting the highBars and the fans not kicking in,
and 2 at low revs it sounds like popping in the airbox and then cuts out.
so seriously low coolant ( no idea where thats gone) no sign of leak.Fulids restored, still no sign of leak ( no its not in the oil) still pops n bangs, absolutely fine once up higher revs. any clues where to look.
It is big and it is clever!...and blooming heavy,
but the new ones a racing whippet
690 Enduro R
KTM 950 Adventure (05) (resting)
I'm not lost, just never been here before
paulk46 is offline   Reply With Quote
Old 12-06-2012, 05:20 AM   #2
Sadlsor
Oddometer: 691
Originally Posted by paulk46 View Post
1, the other morning i notice that temp gauge is hitting the highBars and the fans not kicking in, and 2 at low revs it sounds like popping in the airbox and then cuts out.
More info needed:
What do you mean "high bars"? Above 4 bars, or all the way to 7 bars?
And fan-S... so you have added a second fan to the stock one?
Questions based on 2005 950 Adventure - correct?
You must be the change you wish to see in this world.
Sadlsor is offline   Reply With Quote
Old 12-06-2012, 05:33 AM   #3
paulk46 OP
Katoom
paulk46's Avatar
Oddometer: 227
only one fan, and up to 6-7 bars
690 Enduro R
Old 12-06-2012, 08:53 AM   #4
drued
drued's Avatar
Oddometer: 62
About the coolant loss. On my 05.5 950, I had the same problem - loss of coolant and high temp with no visible signs of a leak. The problem turned out to be the coolant hoses had started to deteriorate from within. Coolant was getting onto the reinforcing fibers in the hose, traveling to the end of the hose and evaporating. Once the hoses were replaced, coolant restored, and radiator burped there was no more problems.
I now have a '12 990, It seems to heat up much faster in slow traffic than the 950. I have ordered a second fan and hope it works.
drued is offline   Reply With Quote
Old 12-06-2012, 09:46 AM   #5
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,789
Sure sounds like coolant disappearing into the oil. When the coolant goes away, the temp sensor can fail to get enough heat to kick-on the fan, so that would be related to the low coolant. But you're talking about a big coolant loss. It's got to be oing somewhere...
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 12-06-2012, 02:14 PM   #6
Dan950ser
NW Shredder
Oddometer: 472
I would look into your water pump shaft seal if you haven't addressed it yet. Mine was loosing coolant with no leaks and it ended up that the seal had failed. Common issue check go to http://www.ktm950.info/ section step by step instructions on replacement. I used the Cjdesigns kit. Good luck.
2015 KTM 690 Enduro R, 2007 KTM 990 SuperDuperEnduroR For Sale http://www.advrider.com/forums/showthread.php?t=1046431, 2014 KTM 250 XC-W
Dan950ser is offline   Reply With Quote
Old 12-06-2012, 03:28 PM   #7
paulk46 OP
Katoom
paulk46's Avatar
Oddometer: 227
thanks for the input guys, water pump seal was replaced around 6 months ago, so i hope its not that again. Ah well Saturdays were invented to strip down bikes............so you can go have fun on Sundays. and theres a Saturday coming soon.
690 Enduro R
Times are GMT -7.   It's 11:16 PM.
