12-06-2012, 09:38 AM
#1 |
With Gusto!
Oddometer: 9,896
Thumb operated rear brake.
I've searched the net to no avail.
I have a Revloc clutch in my 300 EXC. I love it. I had a Rekluse in my previous 450 EXC, awesome! I had that set up with a left hand rear brake instead of the clutch lever and really liked teh set up. With the smoker, I'd like to keep the clutch lever for adding some clutch slip in less than stellartraction situations, but would like a thumb operated rear brake to help initiate slides, holding on a hill, and other misadventures. Has anyone come across either an affordable thumb brake option, or a home made job? I know Spiegler made one for superbikes, but I'm not gonna spend $600 for a doo dad for a $1000 dirt bike. |
12-06-2012, 01:19 PM
#2 | |
WFO for 41 years
Oddometer: 3,993
Too much is just barely enough..... 2007 Tiger 1050 2005 Royal Star Tour DeLuxe 1973 Yamaha TX750 1974 Norton 850 Commando Roadster |
12-06-2012, 06:21 PM
#3 |
Oddometer: 504
pretty sure one of the Colorado inmates PM shearboy, if my memory is correct he tried one and couldnt get it to provide enough braking power
http://www.gptechllc.com/products/gp-tech/thumbrakes mpatch screwed with this post 12-06-2012 at 06:38 PM |
12-07-2012, 12:53 PM
#4 |
With Gusto!
Oddometer: 9,896
I saw the GP tech thing and am thinking along those lines, but I don't need the gold palted platinum version. It's almost $500!
I don't need a lot of braking power for the back, it's going to work in conjunction with the foot pedal, not in place of. Sleds use a left hand lever too. I don't want 2 full size levers in front though, that's why I want a thumb activated thing. |
12-07-2012, 04:41 PM
#5 |
Oddometer: 3,243
could you rig something using a decomp lever?
When i die bury me upside down so the whole world can kiss my ass. |
12-07-2012, 08:44 PM
#6 |
dennism
Oddometer: 91
It seems to me that one of the GP racers...Mick Doohan perhaps?....switched to a thumb brake when he buggered-up his right foot in a crash.
Then as he got used to it, he kept it on all his bikes. Somebody did anyway. You might see if you can find anything tied to him or Honda Racing on the subject. |
12-07-2012, 08:57 PM
#7 |
Iron Collector
Oddometer: 229
Try this:
http://www.youtube.com/watch?feature...&v=Mh2ezYmkjSo or this: http://advrider.com/forums/showthrea...=782942&page=7
Life is short, don't waste it....now get out there! |
12-08-2012, 10:14 PM
#8 |
Zoob
Oddometer: 988
Rekluse has an adapted Mt Bike brake master they hook to the rear brake master or directly to the rear caliper. It's tiny and not much money. Not DOT.
"Dad, can I get a motorcycle when I grow up?" "Son, you can't do both" |
12-08-2012, 10:47 PM
#9 |
The Spoad Warrior
Oddometer: 2,192
i remember a guy who fabbed one up using a hot start lever:
http://www.thumpertalk.com/topic/861...Bhand+%2Bbrake
none of us are as dumb as all of us |
12-09-2012, 02:49 PM
#10 | |
Retired
Oddometer: 328
With two mater cylinders on a hydraulic system .. it won't work too well as each master cylinder has a bleed hole. So you'd need to remove the original ... or Have a cable (bowden cable) from the hand leaver to the foot pedal, the hand lever will operate the foot leaver that operates the master cylinder... You can set the travel/forces by setting where the cable pulls on the rear leaver. All to do with leverage, pivot points. The MTB bike brake leavers tend to be small, an advantage for your application, and cheap say $30. You'll need to figure out how to connect it mechanically to the foot pedal. I like this idea as you will still have the original system in place and any failure of the new bits will not fail the original.The MTB bike brake leavers tend to be small, an advantage for your application. Good luck. |
12-09-2012, 04:43 PM
#11 | |
Oddometer: 504
12-09-2012, 10:01 PM
#12 |
Zoob
Oddometer: 988
No check valve. Rekluse has an adapter for KTM's that forces fluid through the bleed hole in the foot master. So, the hand brake now has the resevour and both brakes work independantly.
When you use the hand brake, it tries to force the foot master piston out, but the snap ring holds it. The bicycle master is very small. You can put it above the clutch lever or below. Or, spin it and use your thumb.
12-09-2012, 10:24 PM
#13 |
Retired
Oddometer: 328
KISS. My thoughts
If the handle bar has the master cylinder then the foot pedal cannot have a effective resevour (think about the height difference). Meaning your present foot pedal master cylinder would need replacement or have careful modification. Leaving the present reliable system intact would be best (and cheaper). The easiest, simple, fail safe additional handle bar system is a cable based system. Fiddly on the bottom pedal. But still easier than mucking around with your original master cylinder. And much easier to adjust the leverage ratios. Warin screwed with this post 12-09-2012 at 10:38 PM |
12-11-2012, 11:58 PM
#14 |
Oddometer: 100
My plan that I never finished was to use a hydro MTB for the clutch on my Gasser since the clutch pull is so light with the Rekluse and continue using the LBRB.
99 KTM 640e 07 GasGas 3 stroke 02 MZ Skorpion Traveller |
12-12-2012, 01:27 PM
#15 | |
Oddometer: 210
97 TL1000S 2010 690 EnduroR 2013 500 Exc 20+ years, 100k+ miles, 15 state's, 5 Countries, 3 years on asphault looking for the checkered flag, 7 dirt trying to stay on my minute. |
