Old 12-06-2012, 06:34 PM   #1
Dorito OP
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,385
Garmin Basecamp and Windows 8
Just "upgraded" Basecamp to 4.0.5. I am running windows 8 platform. Anyhow, routing now appears to be straight line (e.g direct) between waypoints. Changing the activity profile doesn't seem to affect it and make it correctly follow roads. What setting has gone haywire?
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito is offline   Reply With Quote
Old 12-06-2012, 11:04 PM   #2
mcnut
Oddometer: 1,378
I'm thinking that the 'Global Map" you have up is not auto-routing. Try it again with a map set that is.
Mine routs fine in CityNavigator but uses a direct (off-road) route when the Global Map is selected.
Bruce
mcnut is offline   Reply With Quote
Old 12-07-2012, 01:23 AM   #3
dlh62c
Oddometer: 1,603
+1
Did you have the gps connected to the PC via its usb connection?
BC will load the maps installed there.
daryl
Old 12-07-2012, 03:00 AM   #4
Dorito OP
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,385
The winning answer was the map set! BTW, you guys should work for Garmin Help support:)
BlastOff Adventures
Times are GMT -7.   It's 12:13 PM.
