Old 12-06-2012, 08:14 PM   #1
eakins OP
Butler Maps
eakins's Avatar
Oddometer: 18,606
Motion Pro bead breaker & tire iron tool
sweet combo tool for off-road and dual-sport riding.
breaking the bead can be a challenge.
if you have a friend you can use their kickstand on your wheel, but what if you're alone?
i have a bead breaker tool that is a plastic wedge. it works but you need a hammer or a rock and it's kinda brutal as you need to whack the crap outt of it many times before the bead pushes away from the rim. these levers are 1/2 the size of this too.
http://www.motorcycle-superstore.com...ad-Popper.aspx
there are other bead breaker clamp designs out there but these are heavy and bulk to bring with you. they work great for home use.
i also have a harbor freight tubeless tire changer & bar system. this is my go to at home, but these 2 levers are ideal on the road.
this is a nice simple 2 piece lever system
it's pricey but they did it right and used top shelf alum. for weight and strength.
i'll be getting a set at some point soon.
http://www.motionpro.com/motorcycle/partno/08-0519/
i also use this to keep my work area clean on the road
http://www.trailmasteradventures.com/mat.html
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 12-06-2012 at 08:25 PM
Old 12-06-2012, 11:19 PM   #2
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,255
In the last 40 years I have had my share of flat tires. I don't recall breaking the bead afterwards to ever be a problem. Seems like the bead is usually already broken by the time I get the bike stopped. Now that time that happened at about 70MPH, well that was a little more exciting than I care to repeat any time soon.
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 12-07-2012, 06:54 AM   #3
Speedo66
Transient
Oddometer: 6,743
Would have been nice if the video actually showed you how they worked, rather than just staring at them for 46 seconds.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 12-08-2012, 11:39 PM   #4
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,687
3 irons does the same job. 2 outside push down, 1 middle push up. easy
http://www.advrider.com/forums/showt...hanging+thread
none of us is as dumb as all of us
clapped_r6 is offline   Reply With Quote
Old 12-09-2012, 07:10 PM   #5
Motomedic
Motomedic's Avatar
Oddometer: 2,481
I have a set of the BeadPros- they work well on the 21" on the front of my 950, not very well at all on the 159/70-18 on the back. Even though I removed the safety bead on the inside of the rim to facilitate road-side tube swaps, I still have to use the centerstand/sidestand trick to break the bead.
So, in my real-world experience, it's a draw. Smaller wheels? Say, what you would find on a dedicated or plated dirt bike/dual sport? Sure. Big Bike? Better confirm whether they'll work for you BEFORE you have to depend on it.
Feike
I don't have to agree with you to like you or respect you. -Anthony Bourdain
Motomedic is offline   Reply With Quote
Old 03-10-2013, 02:37 PM   #6
Herr Bae M. Vae
Insurgent Squirrel
Herr Bae M. Vae's Avatar
Oddometer: 18
Any other opinions?
So we have one less than enthusiastic endorsement. Anyone else actually had the pleasure of using these to break the bead on a rear tire?
Squirrels of the world unite!
Herr Bae M. Vae is offline   Reply With Quote
Old 03-11-2013, 07:06 AM   #7
jar944
jar944's Avatar
Oddometer: 668
I cant see what these have over std irons?
jar944 is online now   Reply With Quote
Old 03-26-2013, 04:59 PM   #8
fatboy
Oddometer: 311
I am not as good as others in fixing flats. For me these irons would mean I could leave my bead breaker home and carry fewer tools.
fatboy is offline   Reply With Quote
Old 03-27-2013, 07:13 AM   #9
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,783
Originally Posted by fatboy View Post
i am not as good as others in fixing flats. For me these irons would mean i could leave my bead breaker home and carry fewer tools.
+1
You can always count on the Americans to do the right thing, after they have tried everything else.
-Winston Churchill
ausfahrt is online now   Reply With Quote
Old 03-30-2013, 01:29 AM   #10
Plaka
Brevis illi vita est
Oddometer: 4,609
Originally Posted by eakins View Post
/snip
/snip
If you are alone you carry a little A frame support to replace the removed wheel and use your own kickstand. $15 worth of heavy alumnum angle.
Old 03-30-2013, 01:49 AM   #11
GoNOW
Oddometer: 1,588
We got a set in the shop to test out. I tried them on many different wheels. I was even able to pop the bead off a Harley tire with them. It was not easy or quick but it was doable. I just changed the rear tire on a TW200 and it's ATV style with a large bead lock lip. Once again, not easy, but I managed it. With dirtbike tires, it makes the job quick and easy.
I now own a set of BeadPros.
GoNOW is offline   Reply With Quote
Old 03-31-2013, 09:59 AM   #12
eakins OP
Butler Maps
eakins's Avatar
Oddometer: 18,606
easy enough.
Alaska
Old 03-31-2013, 10:01 AM   #13
eakins OP
Butler Maps
eakins's Avatar
Oddometer: 18,606
thanks for the feedback.
i have looked and still can't find a video of anyone actually using a bead pro in action.
Alaska
Old 03-31-2013, 10:06 AM   #14
eakins OP
Butler Maps
eakins's Avatar
Oddometer: 18,606
this seems more of a shop tool kinda tool.
for the shop you'll want any tool or advantage you can have at your disposal.
some beads are brutal to break and larger bead breaking specific tools really help here.
it's not about toughing out what you have and making work, but rather using all the tools to make your job easier.
if these are faster then taking the tire bead breaker tool (you keep the tire on the changing stand the whole time) then they are a valuable tool to a shop. start with these and then move to the big breaker if need be.
on the trail, you need to keep tools and weight to a minimum so maybe these are overkill.
they still seem to offer a nice leverage tool to get the job done either way and could match up with 1 more tire iron to give you 3 irons. if you already have 3 irons and know how to break a bead with them no worries. if you're new to this and buying tools for the 1st time then these could make a great option to help you along. using 3 irons at once for noobs can be harder to do so this tool is welcomed. if you're a old pro then continue with what you do.
I'm always looking for new tools and easy ways of getting things done.
I plan on getting a set for shop use at some point...who knows it must just end up going out with me on rides and pulling out 2 of the 3 levers plus the wedge bead whacker i have in the kit now. at home, these plus a tire changing stand are look to be key to easily change tires.
Alaska
eakins screwed with this post 03-31-2013 at 10:20 AM
Old 03-31-2013, 11:27 AM   #15
GoNOW
Oddometer: 1,588
They are more trail tools then shop tools. At the shop, I use my HF bead breaker to pop the bead, then larger tire spoons MP 08-0409 to spoon off the tires. The BeadPros are not that easy on the hands when spooning.
On the trail, the BeadPros are great. I don't have to put the KTM on the centre stand, lean the bike over and pop the bead using the side stand. All while hoping I don't drop the bike.
Times are GMT -7.   It's 09:07 AM.
