Old 12-07-2012, 09:25 AM   #1
HisMajesty400 OP
Oddometer: 21
Kymco Super 8 wobble
Hi Everyone,
A friend of mine has a Super 8, which she bought new. One day, after it was broken in, I took it out on the freeway to see how fast it will go. At about 55 mph or so, there is a violent wobble coming from the front tire. It is an up and down movement, very much like dribbling a basketball. It was violent enough that I would worry the front end would break off if ridden like this far enough.
It feels normal below 55.... 2 motorcycle places have looked at it and say the tire does not need to be balanced! The dealer she bought it from said it was normal. I disagree, and suspect he didn't drive it fast enough. In any case, even with small tires I would think a scooter would be designed to be safe up to it's max speed.
If it is not a balance problem, what could it be? Could the tire be out of round? The bike has less than 1000 miles on it, and is still under warranty.
HisMajesty400 is offline   Reply With Quote
Old 12-07-2012, 10:11 AM   #2
wannabe1
Oddometer: 558
If the dealer is close by I say take it back and let the tech take a 55mph test drive. My zuma 125 has 12 inch wheels and is smooth at 55mph. Has anybody checked the balance of the tire or are they just saying it doesn't need balancing. I would think you could tell if the tire is out of round just by jacking up the front end and giving it a good spin. The dealer test ride seems most logical to me. Maybe you could follow along side to see it for yourself in case he comes back and says it was normal.
wannabe1 is offline   Reply With Quote
Old 12-07-2012, 01:19 PM   #3
bvardi
Probably not Deciduous
bvardi's Avatar
Oddometer: 299
Also worth mentioning to make sure the tire pressure is correct. It may also behave a little differently depending on the weight of the rider.
Member, Canadian Sidecar Owners Club (CSOC)
Member, CURD (Canadian Ural Dnepr Riders)
bvardi is offline   Reply With Quote
Old 12-07-2012, 01:52 PM   #4
klaviator
klaviator's Avatar
Oddometer: 6,622
My Super 8 did get a little front end vibration near top speed when it was new but it now it is pretty smooth up to around 70 on the speedo (as fast as it will go) I've got 9200+ miles on mine and the original front tire still has plenty of life left.
It sounds like the tire might need to be balanced. Also, check the tire pressure. Recommended pressure is only 29 PSI. Too high of pressure might also cause the problem.
I ride, Therefore I Am.
klaviator is online now   Reply With Quote
Old 12-10-2012, 02:05 AM   #5
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 7,120
Originally Posted by HisMajesty400 View Post
Hi Everyone,
Kenda/Maxxis tires?
Get rid of them.
'08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125, '12 Kymco Downtown 300i ABS
My Flickr gallery --- My 500px gallery
Cortez is offline   Reply With Quote
Old 12-10-2012, 02:51 AM   #6
MODNROD
Perpetual ponderer
MODNROD's Avatar
Oddometer: 2,128
Originally Posted by Cortez View Post
Kenda/Maxxis tires?
Get rid of them.
......or Cheng Shin, like on my little 125?
+1.
Who the hell would drag race a Ducati?!?!?!?!
http://www.dragtimes.com/Ducati-Mons...lip-10329.html
MODNROD is offline   Reply With Quote
Old 12-10-2012, 03:44 AM   #7
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 7,120
+1.
Yeah, CST = Maxxis, same thing, dump it!
Old 12-10-2012, 04:03 AM   #8
Warney
Warney's Avatar
Oddometer: 568
If you can get the front tire off the ground and have a piece of chalk handy, give the tire a healthy spin and mark the low point each time it stops. Repeat several times. If the tire is out of balance the chalk marks will be bunched up instead of randomly distributed.
Warney is offline   Reply With Quote
Old 12-10-2012, 04:32 AM   #9
Mucka
Oddometer: 225
My Super 8 does not have this kind of issue. Not normal at all.
Russ
Mucka is offline   Reply With Quote
Old 12-10-2012, 04:46 AM   #10
gogogordy
gogogordy's Avatar
Oddometer: 1,963
Hi Everyone,
A violent up and down motion as you describe sounds like an out of balance tire, and not a wobble which is typically a side to side effect.
Sounds to me like a tire balance, or better yet replacement is in order.
Isn't it past your bedtime?
gogogordy is offline   Reply With Quote
Old 12-11-2012, 08:55 PM   #11
HisMajesty400 OP
Oddometer: 21
Hi Everyone,
Thanks for your replies. I may just have the friend come over, and take the wheel off and take it down to be balanced. I think what is happening is no one is test driving it over 55 mph. Below 55 it is fine. Also, I don't think my friend has the nerve to just tell them to balance it anyway.
Thanks again.
Old 12-12-2012, 06:13 PM   #12
S/W
S/W's Avatar
Oddometer: 396
wobble
The only way to really know if the tire needs balancing, is to put the wheel on the balancer.If the dealers didn't do this, they don't know if the tire needs balancing or not. But, when you look for a problem , look for all of them; bearings, out of round, loose axel nut, tire delamination, etc..
The dealers might not know what they are doing, or the service writers don't know any better. A mechanic needs to check this out.
S/W is offline   Reply With Quote
Old 12-12-2012, 07:52 PM   #13
gogogordy
gogogordy's Avatar
Oddometer: 1,963
This.
Typically from easiest to eliminate, to the hardest.
Times are GMT -7.   It's 07:26 PM.
