12-11-2012, 07:21 AM
#1 |
Oddometer: 74
Need a Decent HORN <(((
The horn on my R1150RT sounds like a duck with laryngitis. Any suggestions? I've tried Chloraseptic but it didn't help!
12-11-2012, 07:24 AM
#2 |
Oddometer: 101
Try the banshee horn.
Try the screaming banshee
screaming-banshee.com/ I had it on my V-Strom and it is LOUD.
Mark A. |
12-11-2012, 07:29 AM
#3 |
Oddometer: 2,426
Help the Italian economy...
12-11-2012, 08:08 AM
#4 |
bikes, booze, broads...
Oddometer: 8,306
+! on the Steble...loud and clear!
'08 R1200R / '10 WR290X/R '81 R100RS Rattlecandy Red '06 950 ADV Orangeboom '05 R12GS Wedding Bike '91 R100GSPD Derelict |
12-11-2012, 09:14 AM
#5 |
Oddometer: 67
Yep, Stebel. It's the way to go.
----------------------------------- 2006 Suzuki V-Strom DL650K |
12-11-2012, 09:37 AM
#6 |
Lost in Georgia
Oddometer: 558
Stebel sounds like a little screaming girl. Yes, loud, but still......
I prefer the dual Fiamm Freeway Blasters. Sounds like a big a$$ed Buick. Rated at 130dB. Gets their attention as they yak on the phone. Nothing odd and confusing about it, just LOUD. Confusing the brain dead cage drivers with odd sounds and lights isn't a good thing. |
12-11-2012, 10:22 AM
#7 |
Screwed the Pooch
Oddometer: 493
I'm with worwig, the Fiamms or Hella equivalents get people's attention without freaking them out. Loud and familiar.
If your gonna be dumb, you gotta be tough When you get knocked down you gotta get back up, I ain't the sharpest knife in the drawer but I know enough, to know, If your gonna be dumb, you gotta be tough |
12-11-2012, 10:32 AM
#8 |
Location: 40 Square Miles Surrounded By Reality (Madison Wi)
Oddometer: 1,462
I'll third that. I had the high pitched twin Fiamm air horns on a previous car. They were extremely, unbelievably, ear-splittingly loud. But they were so high pitched that as often as not, people would not recognize it as a horn.
For the Freeway Blasters, on a typical Japanese bike could you wire it right to the existing horn lead, or would you need a relay?
Dave in WI 2002 ZRX1200R 1975 XL100 1988 DT50 "Daddy, it's five o'clock sometime!" |
12-11-2012, 11:15 AM
#9 |
Oddometer: 305
I have these on my 919, very loud, well build, and durable. Used a relay wired to the factory horn wiring.. works like a charm.
http://www.amazon.com/85112-115db-50...HZ+Sports+Horn |
12-11-2012, 11:20 AM
#10 |
whosaberg?
Oddometer: 566
4th for the freeway blasters. Nothing beats a loud dual tone.
And to answer Dave; Replace the old horn with a relay, and pull a dedicated lead from the battery to the new ones. Good dual horns may draw 15 amps or more. |
12-11-2012, 04:42 PM
#11 |
Oddometer: 1,575
STEBEL, anything else is girly sounding and only girly men would like!
12-11-2012, 05:28 PM
#12 |
Dilbert
Oddometer: 391
I have a pair of German quality Hella supertone car horns [painted black] mounted in front of my lowers, fed by a relay that gets it's fused power directly from the battery. The orig horn circuit runs the relay.
15 amps worth of Freight Train loud. Loud pipes don't saves lives [they actually suck] but loud horns help mitigate dangerous conditions. Typically they work better than the adv salute and other means of retaliation...in most cases. They do scare old ladies and sometimes make mean cagers meaner, but that's what the other tools are for.
I ride alone...with nobody else |
12-11-2012, 05:33 PM
#13 |
Lost in Georgia
Oddometer: 558
Unless you know the factory horn wiring is capable of the load, add a relay.
12-11-2012, 05:38 PM
#14 |
British Hooligan
+1 on the screaming banshee. It lets you keep the stock horn for polite "the light's green you texting moron" peeps then kicks in the eardrum-melting horn for the "I'm already in this lane you texting moron" use mine often... for both purposes
The problem with having an open mind, of course, is that people will insist on coming along and putting things in it. |
12-11-2012, 05:41 PM
#15 | |
Oddometer: 1,594
Most horn kits include the appropriate relay, and if not it's not a problem to find one. If you want a sanitary ready-made relay setup, there's always Eastern Beaver. |
