Old 12-08-2012, 04:15 AM   #1
3Putt OP
Is that a gimmie?
3Putt's Avatar
Oddometer: 638
How can I prevent highway peg U-bolt from spinning on my crash bar?
I'm trying to install a set of Adventure Designs highway pegs on Tiger 800 OEM crash bars. I tightened them to the point that it appears I've put a small dent in bars but I can still spin them with just a small amount of pressure. I don't have the balls to tighten them any further.
In the past I've drilled a hole and put in a screw or even used Gorilla Glue. I really can't do that with this set.
Help?
Link to the pegs: http://www.advdesigns.com/pralhipebl.html
Tom
2013 RT
3Putt screwed with this post 12-08-2012 at 05:22 AM Reason: I can't spell tosave me ass.
3Putt is offline   Reply With Quote
Old 12-08-2012, 04:38 AM   #2
greer
Oddometer: 3,727
Use a strip of rubber around the bar as a shim?
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 12-08-2012, 04:48 AM   #3
3Putt OP
Is that a gimmie?
3Putt's Avatar
Oddometer: 638
Sarah
I tried that with a piece of heavy duty rubber hose, the bolt bit right through. Friction tape seemed to help it spin easier.
Tom
2013 RT
Old 12-08-2012, 05:04 AM   #4
greer
Oddometer: 3,727
With that U-bolt type mount I wonder if you have to get a cheater bar and just keep cranking? I'm stumped so I'll just hush now. We'll wait to see what some of the other folks suggest.
Sarah
'08 DR650
Old 12-08-2012, 05:23 AM   #5
3Putt OP
Is that a gimmie?
3Putt's Avatar
Oddometer: 638
Thanks. Since it looks like I've already put a dent in the bars I'm worried about the bolt cutting in.
If it was my buddies bike I'd have no problem with the keep cranking method
Tom
2013 RT
Old 12-08-2012, 06:02 AM   #6
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,600
Maybe you can line the U-bolt with a strip of metal to spread the clamping force over a larger surface area? Something in the neighborhood of 16ga, might be able to find something in the plumbing or elec. dept of your hardware store.
Too bad your crashbars don't have a short section of square tube to clamp to. Got any pictures?
Might also be able to make your own clamp blocks along the lines of handlebar mounts.
katbeanz is offline   Reply With Quote
Old 12-08-2012, 06:02 AM   #7
HeavyMetal
Oddometer: 48
I had this same problem. I cut a strip of sandpaper, doubled it over so there is abrasive on both sides and clamped it in. Voila!! No more slippy!
HeavyMetal is online now   Reply With Quote
Old 12-08-2012, 06:19 AM   #8
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,411
Quit chasing your tail get a BETTER clamp. http://www.kuryakyn.com/products/531...m-quick-clamps
Old 12-08-2012, 08:03 AM   #9
3Putt OP
Is that a gimmie?
3Putt's Avatar
Oddometer: 638
Thanks folks. I moved the pegs to my second choice location and it's looking like it's going to work.
Tom
2013 RT
Old 12-08-2012, 09:19 AM   #10
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,182
Careful not to over tighten the U bolts on the frame. You can damage the frame, cause a bend and/or a weak spot.
---Albert Einstein
Old 12-08-2012, 09:42 AM   #11
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,561
Cut up beer cans make excellent shim material.
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Old 12-08-2012, 01:08 PM   #12
ibafran
villagidiot
Oddometer: 1,287
Take a look at some of these accessory pegs. The bolts have a pair of spacers with a conical edge. The conical spacers help tighten the wrap of the clamp on the tubing. If the tubing isn't the right size to make the little spacers work well, see if a few washers under the spacers will help?
Also, try wrapping the tube or lining the clamp with some self-adhering grit strips like one would use on wooden steps/treads to prevent slipping when they are wet? The strips are cheap and if you tear one up in a get-off, it is easy to add another wrap.
"beware the grease mud. for therein lies the skid demon."-memory from an old Honda safety pamphlet
ibafran is offline   Reply With Quote
Old 12-08-2012, 08:58 PM   #13
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 1,974
Emory cloth works very well for this stuff but a good clamp is just a little out of round vs a u-bolt. It wont spin and it wont mark or dent your bars.
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 12-09-2012, 09:56 AM   #14
Pike Bishop
Pull Down the Ponzi.
Pike Bishop's Avatar
Oddometer: 10,313
Maybe put them where you want them and then braze them in place?
The nice thing about brazing is that you can un-do it fairly easily.
Pike Bishop is offline   Reply With Quote
Old 12-09-2012, 11:29 AM   #15
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,288
I'd ditch the U-bolt and fabricate up some SS strap in a saddle clamp shape, and use a couple of bolts instead, or if your material is thin enough you can have the clamp run under the U-bolt. The trick is to have it mechanically attached to your foot pegs. Originally I was thinking about welding pads to your u-bolts but I like this approach better.
GreaseMonkey is offline   Reply With Quote
Times are GMT -7.   It's 09:58 PM.
