Old 12-21-2012, 10:46 AM   #1
nwcolorider OP
NWCOLO
nwcolorider's Avatar
Oddometer: 1,691
Dual Sport light kit question
My son has a 06 WR 450 and is looking at kits for the bike to make it street legal. He is seeing one on procycle and one at Baja Designs I see there is a bit over a 100 bucks difference in the costs. Any input on these two? Or are there other better ones, or is it easier and cheaper to build his own.
Civilization exists by geological consent, subject to change without notice.
Will Durant
http://nyoast.weebly.com/
nwcolorider is offline   Reply With Quote
Old 12-21-2012, 03:16 PM   #2
beernutt
This space for rent
beernutt's Avatar
Oddometer: 255
All you have to add to a WR to make it CO legal is-
A brake light switch wired into your existing 3 wire taillight.
A horn of some kind.
DOT tires.
A mirror.
That's really about it. Maybe $30, minus tires.
Alan
06WR450
Plated since, well, 06.
beernutt is offline   Reply With Quote
Old 12-21-2012, 03:18 PM   #3
jcbikes1
Oddometer: 62
Very easy to do if it is being registered in Colorado. If it has the stock lights all you have to do is get it inspected after you get the rear brake light working, mirror, horn, DOT tires. Do a search on here for more details. Its been covered many times.
jcbikes1 is offline   Reply With Quote
Old 12-21-2012, 07:48 PM   #4
nwcolorider OP
NWCOLO
Oddometer: 1,691
Looking for input on the kits, I know what it would take if it was stock, it is not. It has no headlight. Previous owner took it off, for bigger light he had, but kept the light. It has a YZ rear fender, no tail light. SO he is looking for a complete wiring harness, rear light, break switch, good quality head light, horn. I know he does not need blinkers, but mom wants them. I know exactly what it needs, just looking for input on those two kits.
Will Durant
Old 12-21-2012, 08:43 PM   #5
pfb
Skiing, not riding.
pfb's Avatar
Oddometer: 5,060
I think the input is few use these kits these days, as Colorado law is lax, the kits are overpriced and not terribly innovative in their design and are typically overpriced and clunky.
I you are set on using a kit, the trickdualsport kits are a little less clunky than some of the others and sicasss racing makes a decent kit.
950 Adventure 950 Super Enduro 450 XC-W Six Days
pfb is offline   Reply With Quote
Old 12-21-2012, 09:10 PM   #6
Skeeter1981
Finding myself
Oddometer: 26
Check out Performance Cycle on Broadway - they carry Baja Design products and some other aftermarket options. You can find it cheaper on the web but if you want to see it first hand the guys there are very helpful.
Skeeter1981 is offline   Reply With Quote
Old 12-22-2012, 05:07 AM   #7
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 1,650
Or Sicass racing at sicassracing.com . They make one that matches right up to your harness and plugs right in! All LED and the best prices you will find on light conversions that are complete.
buls4evr is offline   Reply With Quote
Old 12-22-2012, 07:48 AM   #8
RideFreak
Torque Junkie
RideFreak's Avatar
Oddometer: 3,634
The BD kits use very small guage wiring, and get around it by using a relay. It's an overly complex design which works but it's very common to be chasing down wiring and connection problems with them after a season or two. I never understood why they didn't model it after an OE street legal harness. IMO they aren't up to the rigors of off-road use, the XR650R Electricity forum is full of questions on how to fix broke DS lighting kits. I can't speak for the Procycle kit. Most of us do it from scratch on the dirtbikes and leave off the blinkers. If a plug-n-play kit is what you're after then one of those are probably the best route. From the prices, those companies are very proud of their systems.
Chris
VIDEOS
RideFreak is online now   Reply With Quote
Old 12-22-2012, 01:44 PM   #9
SnowMule
SnowMule's Avatar
Oddometer: 16,133
Not sure if Trick Dual Sport has offerings for that bike, but I'm quite happy with the products and support from them.
Spewer of the poignant non sequitur
SnowMule is offline   Reply With Quote
Old 12-22-2012, 02:23 PM   #10
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 12,362
I've used Baja Designs on more bikes, they are very easy to install and offer a nice package....but on my first KTM 520 I used the Trick kit, and it was a great solution for that bike. Elegant and simple.
They do make one for the WR450
http://www.trickdualsport.com/yamaha.php
'12 VFR 1200 . '13 TR650 Terra . IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 12-22-2012, 05:00 PM   #11
pfb
Skiing, not riding.
pfb's Avatar
Oddometer: 5,060
Originally Posted by Blakebird View Post
.but on pfb's first KTM 520 I used the Trick kit, and it was a great solution for that bike.
Fixed.
Old 12-22-2012, 05:37 PM   #12
hook0924
hook0924's Avatar
Oddometer: 135
Procycle
I built my own using the parts from procycle with some polysport and some acerbis using the LED signals and tail light. Then wired it all myself using 18ga and wireloom for extra vib resistance. Remember most of these kits will work with either an AC or a DC system or both (can be split), but the horns only like DC.
Caio
EngineerSteve
I promise to tell the truth, nothing but the truth, but not the whole truth, so help me God!
Member NMOHVA, AMA
hook0924 is offline   Reply With Quote
Old 12-27-2012, 07:57 PM   #13
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 7,098
I also have used Baja Designs kits on several bikes and found them easy to install and they seem to work very good. I hate to agree with Blake but do.
Marc
04 R1150RT,06 KTM 450EXC, 84 R100RS LE, 89 XL600V, 2012 Stelvio, 72 Guzzi Eldorado
http://s22.photobucket.com/albums/b327/lomaxcm/?sc=3
Lomax is offline   Reply With Quote
Old 12-27-2012, 08:11 PM   #14
yukonjon
yukonjon's Avatar
Oddometer: 123
I used the Tusk brand on my wr450. It was cheaper than baja and in my opinion still a very good product. I mainly use my bike for rough single track with road jumping between trails. After at least 10 good crashes all my lights and signals are still attached and work fine. Just something to consider. Buy at rockymountainatv.com. Baja is better but I'm a cheap bastard and couldn't be happier with tusk. Good luck with your search. If you want some pics of the tusk kit on my 450 just let me know.
yukonjon is offline   Reply With Quote
Old 12-28-2012, 07:10 AM   #15
nwcolorider OP
NWCOLO
Oddometer: 1,691
He went with the Tusk Kit, I left it up to him. It is his bike and his money, he works hard for it raising and selling pigs (BACON!). He wanted to do it himself, he is like that. It is great because he wants to learn what to do, and how to fix it. His street riding will be very limited on the WR, mainly connecting dirt routes, he also has DR. So we will be starting his project Monday and I am starting mine on the shock rebuild, valves and such on the DR Monday. Off to Denver Saturday for the Broncos game, so if any of you want to meet for a beer let me know.
Will Durant
Times are GMT -7.   It's 10:04 PM.
