Old 12-08-2012, 11:46 AM   #1
Hootowl OP
Oddometer: 1,268
Socket Head Cap Screw Problem
I've got a buggered cap screw (Allen) head bolt in a cramped location with very little room to maneuver tools around the head of the bolt.
The socket head isn't very deep. An easy out doesn't grab enough bolt material to do its job.
There isn't room around the outside of the bolt to use a tool that grabs the outside of the bolt
The only idea I have right now is welding a nut to the head of the bolt but that's going to be problematic as well due to the space constraints.
Any high tech tools out there in the market place that might work?
Ever use these? http://www.grahamtool.com/boltandscrewextractor.aspx
Richard
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is offline   Reply With Quote
Old 12-08-2012, 12:01 PM   #2
ABHooligan
The Flying Mythos
ABHooligan's Avatar
Oddometer: 1,156
Sometimes I use a cutting wheel on a dremel tool to make a slotted head, then remove the screw with a flathead screwdriver.
"I tried to move my mind there and nowhere else and imagine a single detail that, if I didn't see it that weekend, I never would... The world is easily lost."
James Dickey
ABHooligan is offline   Reply With Quote
Old 12-08-2012, 12:07 PM   #3
Midnightventure
Oddometer: 761
If you can get to the side of the head with a sharp center punch sometimes you can strike the center punch sharply and loosen it.
Midnightventure is offline   Reply With Quote
Old 12-08-2012, 12:12 PM   #4
Hootowl OP
Oddometer: 1,268
Thanks for the ideas so far.
I forgot to mention that the bolt is in way too tight hence the buggered head.
I hate fixing other people's FU's!
'07 990A
'12 Super Tenere
Old 12-08-2012, 12:17 PM   #5
gpounce
Oddometer: 122
If you can swing it, welding a nut on is a common technique, the sharp spike of heat also helps break loose any corrosion/locktite etc that may make removal more difficult. I've never yet had any of the magic tools work for me otoh using a left-hand drill to core out the screw shank often loosens it to the point where the torque imposed by the drill unscrews it. Of course getting a left hand drill into play and not wandering out the side of the bolt and not going too deep is the fun part...
gpounce is offline   Reply With Quote
Old 12-08-2012, 01:30 PM   #6
KeithinSC
KeithinSC's Avatar
Oddometer: 1,589
Get a Torx bit a little larger than the hex. Pound it into the cap screw. Hopefully the hammering will help break it free, and the fluted on the Torx have enough meat not to strip out further. Might ruin the torx
Heat it if possible the cool it quickly. Thermal shock.
Good luck.
KeithinSC is offline   Reply With Quote
Old 12-08-2012, 01:36 PM   #7
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,161
Three suggestions:
Cut a pc of shim stock to wrap arond the allen wrench and drive it into the socket. This may give enough grip to get it out.
Try a hand held hammer type impact. Again drive a over size allen ( inch size or Torx ) into the socket. The blows from the impact do wonders to loosen up stuck bolts.
From now on, try anti sieze to prevent reoccurance.
Wrap shim stock like this:
Drive it in there: ( is that what she said? )
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 12-08-2012, 02:04 PM   #8
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,553
Welding an allen hex bit into the cap screw is another (similar) option. The graham tool bolt extractor may work. Then, when it doesn't, weld it into the head of the cap screw. Good luck!
Stan_R80/7 is offline   Reply With Quote
Old 12-08-2012, 02:24 PM   #9
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,630
Vice grip?
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is offline   Reply With Quote
Old 12-08-2012, 02:32 PM   #10
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Occasionally a Torx bit driven into a bad allen will remove it.
you don't see luggage racks on a hearse..........act accordingly
Old 12-08-2012, 04:00 PM   #11
Hootowl OP
Oddometer: 1,268
Originally Posted by D.T. View Post
Vice grip?
Not enough room
'07 990A
'12 Super Tenere
Old 12-08-2012, 04:01 PM   #12
Hootowl OP
Oddometer: 1,268
Thought of that already but not enough room to wack it with a hammer
'07 990A
'12 Super Tenere
Old 12-08-2012, 04:29 PM   #13
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,279
drill it out with a bit slightly larger than the diameter of the shaft. the head will spin off, removing the pressure from the shoulder of the head. then remove part, and remove remnants of screw. or use a left handed bit. either way if it's seized from overtightening, once you remove the head, it will be simple.
current bikes
stainlesscycle is offline   Reply With Quote
Old 12-08-2012, 06:19 PM   #14
Benesesso
Benesesso's Avatar
Oddometer: 9,898
Can you post a good sharp pic of it?
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 12-08-2012, 06:56 PM   #15
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Well I'll be damned. A John Bircher sighting.
Times are GMT -7.   It's 09:12 PM.
