Old 12-10-2012, 06:09 PM   #46
Hootowl OP
Oddometer: 1,263
Originally Posted by stainlesscycle View Post
you can screw around with all these other methods, or spend 30 seconds with a hammer and chisel. you can even cut the slot with the chisel. you don't even need a 1/4 turn. you don't need to be at an exact right angle to it - even a bit of an angle and downward, and enough to turn the head left just a bit.
I'll try that tomorrow.
My only concern is that if the bolt was over torqued enough to cause the socket to strip is a hammer & chisel going to be enough?
I'll find out
Richard
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is offline   Reply With Quote
Old 12-10-2012, 08:36 PM   #47
pennswoodsed
lizards,bugs and me
pennswoodsed's Avatar
Oddometer: 748
my vote
Am I missing something about dropping motor ? I wouldn't risk sending chips and shards into something like this 990 engine. Drop motor , remove fastener(s all needed) clean area thoroughly. Reinstall engine, Change oil,Ride!
Regards,Ed
pennswoodsed is offline   Reply With Quote
Old 12-10-2012, 09:06 PM   #48
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,621
dunno if it's been suggested yet:
An extractor that has been ground down at the tip so it won't bottom out in the socket before getting a solid bite on the walls. Worked for me more than once.
Edit: the greasey monkey on post 29 beat me to it...
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 12-10-2012, 09:13 PM   #49
Hootowl OP
Oddometer: 1,263
Regards,Ed
Everything but the bolt head is covered with rags. I'm extremely obsessed with cleanliness around any open engine area.
Even if the engine is removed from the frame the problem of contamination remains.
The bolt that I'm working on is inclined steeply from vertical so that any metal chips will tend to fall away from any openings into the engine. No so with the bolts on the front of the cylinder.
I wouldn't do anything that would jeopardize the longevity or mechanical integrity of the 990 engine
'07 990A
'12 Super Tenere
Old 12-10-2012, 09:17 PM   #50
D.T.
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,957
Question
Haven't got it out yet?? What is the torque spec of that bolt?
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 12-11-2012, 04:19 AM   #51
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,263
I'll find out
Richard
yes a hammer and chisel will be enough. you may have to wack it a few times. you have so much more force applied with the hammer and chisel method. you may want to use a flat ended punch first directly on the head to shock the threads free. i really should make a video of this method, i use it 99% of the time when i'm splitting cases on vintage motors.. - i can't believe i couldn't find a good one on youtube. here's one (although not a very good shot) http://www.youtube.com/watch?v=Ci7l_Ir5gso countersunk screws are by far the hardest to get out..
current bikes
stainlesscycle is offline   Reply With Quote
Old 12-11-2012, 10:14 AM   #52
D.T.
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,957
A guy I work with had a set of these yesterday and told me to get a set. Seems pretty handy, and expensive.
http://www1.mscdirect.com/cgi/NNSRIT...-SearchResults
Old 12-11-2012, 11:04 AM   #53
Smoke Eater 3
Oddometer: 692
Screw pliers
Screw pliers are life savers. I've used them on more than one occasion.
Smoke Eater 3 is offline   Reply With Quote
Old 12-11-2012, 12:11 PM   #54
dmn0507
dmn0507's Avatar
Oddometer: 352
18nm
BTDT, in a friend's engine one of those bolts was so damn tight i've almost bent a wrench to remove it.
I had luck with a good quality allen insert, the fit was really tight so i wasn't afraid to apply torque.
I would hit it with a punch in the center, but I don't remember how beefy is the head there.
Instead of dropping the engine completely, if you swing it down you should have enough room to grab the bolt with a vicegrip, but still some stuff needs to be removed.
dmn0507 is offline   Reply With Quote
Old 12-11-2012, 04:54 PM   #55
Hootowl OP
Oddometer: 1,263
you can screw around with all these other methods, or spend 30 seconds with a hammer and chisel. .
Tried it today. No workie.
The chisel just pealed away part of the cap. The bolt didn't budge.
I thought these bolts were hardened steel? Didn't act like they were.
'07 990A
'12 Super Tenere
Old 12-11-2012, 07:15 PM   #56
Benesesso
Benesesso's Avatar
Oddometer: 9,898
Try reading post #44.
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 12-11-2012, 07:18 PM   #57
Hootowl OP
Oddometer: 1,263
Right. the next step.
'07 990A
'12 Super Tenere
Old 12-12-2012, 02:24 AM   #58
stainlesscycle
Oddometer: 2,263
dull chisel or flat punch for turning it then. or slot was not cut deep enough.
current bikes
Old 12-12-2012, 05:22 AM   #59
griffo1962
griffo1962's Avatar
Oddometer: 1,507
I find a centre punch works really well.....
griffo1962 is online now   Reply With Quote
Old 12-12-2012, 06:19 AM   #60
anotherguy
anotherguy's Avatar
Oddometer: 6,209
Seems like it may be time to drop the engine. If you'd done that at first this would be a done deal. Sometimes what seems to be the hard way isn't in the long run.
you don't see luggage racks on a hearse..........act accordingly
Times are GMT -7.   It's 01:54 AM.
