Old 12-09-2012, 06:34 AM   #1
deserteagle56 OP
deserteagle56
Oddometer: 55
Question Montana AMPS Rugged Mount Fix?
The "Security Screw" on the new AMPS Rugged Mount I just received for my Montana is unable to engage the lock. From a quick search on the internet, apparently there was a whole batch of the mounts that were shipped with screws too short to do the job.
But my beef is this - I don't want to be packing around a special, tiny little tool to use on the security screw every time I want to mount or dismount the Montana. It wouldn't take me very long to lose that tool! Has anyone taken one of these mounts apart? How difficult would it be to replace that tiny little screw with something I could tighten with my fingers?
deserteagle56 is offline   Reply With Quote
Old 12-09-2012, 06:51 AM   #2
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,842
Here is the answer.
Old 12-09-2012, 07:26 AM   #3
deserteagle56 OP
deserteagle56
Oddometer: 55
Many thanks! Just the information I needed!
Old 12-12-2012, 09:32 AM   #4
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,614
Semi-related question:
I don't have any need or desire to torque down the tiny tamper-proof torx "security" screw when using my Montana in this mount. Is just letting the security screw flop around going to create any problem, even if minor?
Old 12-12-2012, 10:09 AM   #5
Bullwinkle58
Oddometer: 58
I've heard of them (the gps) working its way out of the mount without the screw tightened. To answer your question though, if you click on the link that Emmbeedee posted, you will see that the screw can't come out unless the e-clip that holds it in comes off somehow.
Bullwinkle58 is offline   Reply With Quote
Old 12-14-2012, 03:43 PM   #6
Mudcat
Unregistered
Mudcat's Avatar
Oddometer: 4,472
You bought a Montana?
I've got to be cool
Relax
Take a long long ride on my motor bike
Untill I'm ready
Mudcat is offline   Reply With Quote
Old 12-14-2012, 04:10 PM   #7
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,614
Old 12-15-2012, 12:38 AM   #8
Mudcat
Unregistered
Mudcat's Avatar
Oddometer: 4,472
I maybe wrong but what is called a mount here seems very similar to the cradle for my Zumo 450. The only times I need to remove the Zumo from its cradle is when I connect it to my home computer. The security screw isn’t much of an issue.
I just use a Ram mount for my Zumo and I have a short power cord on the cradle going to an accessory port on left-hand beak. On the road if I want to remove the unit from the bike it takes all of 30 seconds, cradle and all are gone.
I know if I eventually buy a Montana I will want to mount it in a similar manner. It looks as if I can, can I?
I've got to be cool
Relax
Untill I'm ready
Mudcat screwed with this post 12-15-2012 at 12:45 AM
Old 12-15-2012, 03:53 AM   #9
Hikertrash
Oddometer: 2,949
I called Garmin because I lost my security screw driver and wanted to buy a replacement. My AMPS mount screw is also hard to engage and lock down and I asked them if there was a recall on them or anything. They told me that they know nothing about any problems with the screws on the AMPS mounts and have no plans to recall/replace them. They also told me they don't sell the security driver separately, so they sent me out a new AMPS mount for free instead. Strange logic, but I'm not complaining since I've spent $1000 on Garmin GPS's in the last two months. I've been fiddling with the mount recently and found that if I push up on the Montana as I'm pushing down while turning the security screw, it locks all the time.
Hikertrash is offline   Reply With Quote
Old 12-15-2012, 04:22 AM   #10
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,614
Hikertrash, WOW! The "tool" is nothing more than what is called a "tamper proof torx" bit. They are a commonly available tool. I just don't know what the size is for the Montana, but a trip to Sears or anyplace that has a good tool selection where you can test the fit should do. When I have a reason to go to Sears, I will see if I can find the size and post it.
Example: http://www.sears.com/xbrdepot-deluxe...6&blockType=G6
Mudcat: You could do that. But, the way the power cord kind of snaps into the AMPS Rugged Mount, it might be a little fiddly to deal with every time. I haven't tried it yet, but it might be easier to deal with loosening the security screw, you'll have to try and see what your preference is.
I don't keep my Montana or Zumo in the mount all the time because as long as it is in there, it is charging the battery, and I don't want that constant(?) drain on the bike's battery.
Old 12-15-2012, 04:40 AM   #11
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,842
It's a T10 security screw size.
And rather than buy a whole screwdriver, just buy a bit in that size. One of my "precision" tool kits had the size so I just put that into my tank bag, in case I ever lost the Garmin tool.
Here's a set on Amazon.
Old 12-15-2012, 04:47 AM   #12
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,614
Thanks, Emmbeedee! Here is another option if one doesn't want to buy a whole set:
http://www.mcmaster.com/#tamper-resi...rivers/=klotfa
Item # 55525A25. $2.91
Old 12-15-2012, 11:53 AM   #13
Mudcat
Unregistered
Mudcat's Avatar
Oddometer: 4,472
How can it be charging the battery when there is no external electrical power? There is only power to the mount when I turn on the ignition switch.
My Zumo rarely is removed from its cradle, only when I need to connect it to my home computer.
The power cord stays connected to the Mount, (cradle), all the time. When I remove the unit from my bike, I unplug the short power cord from the accessory port on my beak. Power cord, cradle, and Zumo are removed as one package and placed into a saddlebag or my room for the night.
I've got to be cool
Relax
Untill I'm ready
Old 12-15-2012, 12:55 PM   #14
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,614
Oh, ok, I see. I failed to realize that the power outlet you use was switched. Apologies. So yes, in that case there would be no draining.
Old 12-18-2012, 05:41 PM   #15
jprovence
Oddometer: 67
Since other threads have pointed towards M3 being the size that the torx screw it, I went to looking through my computer parts bin.
The screw used to secure CD-ROM and Floppy drives is the exact size needed. An M3x5mm
Pull the rugged mount apart, put in the new longer screw. I didn't bother putting the clip back on the screw. Its about 1mm longer then the garmin screw and will secure the Montana easily using a philips screw driver. I didn't like to cleanness of the other methods.
jprovence is offline   Reply With Quote
Times are GMT -7.   It's 09:11 PM.
