Old 09-07-2013, 06:18 PM   #16
jengel451
1 Cool MotherF#$cker
Oddometer: 799
Resurrecting this one......they are still supplying the mount with this problem, screw is way too short, the link above was a god send today.
jengel451 is offline   Reply With Quote
Old 09-07-2013, 07:13 PM   #17
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,685
We have four Rugged Mounts here and they are all still working properly. Once in a while my wife complains that she can't get the screw to fasten but if I just push the movable part in, and jiggle the gps a little to make the teeth on the mount go right into the slots on the gps, it always works. Maybe that was your problem?
I'd be surprised if Garmin was putting shorter screws in now, unless you got one of the defective stock.
Old 09-10-2013, 02:36 AM   #18
JD
JD's Avatar
Oddometer: 393
I bought an AMPS mount direct from Garmin about 6 months or so ago, and the security screw wouldn't engage.
They replaced it with another one, but I have since fitted one of these: http://www.ebay.com/itm/50-Thumb-Scr...-/260684608371
When that link eventually dies the description was "50 Thumb Screw M3x10mm M3 For DIY Computer PC case Bl".
I just mounted it in a drill and used a file to grind down most of the threaded section, leaving a few mm of thread on the end and fitted the little spring and circlip from the standard screw.
And now I have 49 spares
JD is online now   Reply With Quote
Old 09-14-2013, 08:16 AM   #19
jengel451
Oddometer: 799
Trust me, I tried for about 20 minutes, different ways to get that thing to engage.
Garmin is sending me a new mount, I have to say, even though they may be slow to fix something in production, their customer service is pretty stinking good.
Times are GMT -7.   It's 03:17 AM.
