Old 12-10-2012, 10:55 AM   #1
bigspillway85 OP
Oddometer: 1
Ducati E900 Elefant high mile
Looking at a 1994 Elefant.
Has 83,000 KM or about 52,000 Miles
Only mods are pod type filter and a rejet. Original owner.(older man now in a wheelchair). Bike cranks right up and sounds/idles fine. No lack of power from i can tell. Has no service records but he says everything was done at proper intervals.
Any real concerns when a Fant has this kind of mileage? Any telltale signs i should keep an eye out for?
Thanks for any help. Look forward to being a first time Ducati owner.
bigspillway85 is offline   Reply With Quote
Old 12-11-2012, 08:06 AM   #2
azcagiva
new orange flavor
azcagiva's Avatar
Oddometer: 1,154
Those engines go forever should be fine.
-John
An Elefant never forgets.
www.Raceforthewounded.com
azcagiva is offline   Reply With Quote
Old 12-12-2012, 12:41 PM   #3
Bevelhead
Bevelhead's Avatar
Oddometer: 72
If it ain't rattling very bad (with the clutch disengaged) and it ain't smoking, just put some fresh belts on and check the valve clearance. You'll most likely have plenty of life left. Check for snapped head studs also (oil leakage at head and the nuts will spin freely.) If they haven't broken by now they've either been replaced or are gonna be fine. Just don't wind it up over 7500 if it's the original studs. No need to anyway. It's a Ducati, and a tuned for grunt one at that. You're gonna love riding it.
'95 Elefant
'84 XL600R
'81 900 SD Darmah
Bevelhead is offline   Reply With Quote
Old 12-12-2012, 12:57 PM   #4
falcn
Squidless Soul
falcn's Avatar
Oddometer: 372
Just bought one with similar miles - I am not worried.
My wife's bike has almost 30K on it - running like a top.
Dead simple motors, easy to wrench. keep up with the valves and belts and you are good!
Rear suspension might need to be taken apart and greased and/or the bearings replaced.
If you haven't found it already www.elefantadventurebikes.com and check out the google group for the same. Also - Facebook Cagiva Elefant group - all excellent sources.
Loving the DS rides
falcn is offline   Reply With Quote
Old 12-14-2012, 07:39 AM   #5
jerdog53
Crop Dusting Everywhere
jerdog53's Avatar
Oddometer: 6,268
I have over 50K on my Cagiva Gran Canyon which has the air cooled 2V 900cc Ducati motor in it with out a problem.....
13 Hyperstrada 09 696 Monster
"Shorter of breath and one day closer to death"
jerdog53 is offline   Reply With Quote
Old 12-14-2012, 09:28 AM   #6
ZLTFUL
Optimistic Pessimist
ZLTFUL's Avatar
Oddometer: 512
PhilB over on the Ducati Monster Forum has over 200k miles on his 2V 900 Monster (same engine).
There are several other examples of >100k miles 900 2v motors.
As was stated above, maintain valve clearances and replace belts when due and the engine will outlast the other components of the bike.
2012 Ducati Multistrada 1200S Touring
2013 Husqvarna TE310R
Avatar courtesy of www.mybadco.com
Ducati in The Rockies 2014 RR
ZLTFUL is offline   Reply With Quote
Times are GMT -7.   It's 02:36 AM.
